Hello cin,
This is a strange problem. In my test, Max 2024.1 works well with Omniverse 3DS Max Connector. I guess it is something goes wrong with the settings of 3DS Max. How about you rename two 3DS Max folders and try again.
C:\Users\user name\AppData\Local\Autodesk\3dsMax\2024 - 64bit
C:\Users\user name\Documents\3ds Max 2024
You can rename the above two folders. Then 3DS Max will generate right settings.
If it does not work for you, you can delete the new generated folders and rename your folders back.
You do not have to reinstall Windows and Max 2024.1. You can uninstall Connector and make sure Max runs well.
You do not have to go to Launcher. You can go the the installation path of Connector in the above picture. At the root of Connector, you can run MaxSetup.exe to uninstall Connector.
Maybe you have one old Max Connector on disk. You can run UninstallOld.exe which is at the same path as MaxSetup.exe.
And please run UninstallOld.exe with Admin. It will help remove old Connector.
After uninstallation with MaxSetup.exe and UninstallOld.exe, you can run Max and quit. Then you can install Connector again with MaxSetup.exe.
Which new version of connector available? I have 3dsmax-connector-201.1.0 for 3ds max 2024.1.
It not work on fresh installation of 3ds max 2024.1 which installed on fresh Windows 11.
Hi Cin,
I tested with Windows Russian and Japanese. But I did not reproduce the problem. I guess it could be special build of 3DS Max, e.g. Max for Russian.
