We are starting to use Omniverse for 3dsmax. 3dsmax opens for users just fine. But when deadline launches 3dsmax for a render job it looks like it loads some of the materials just fine, but then when it gets to presets it cant load them and it can find the assets along with them.
Has anyone else had this problem ? and has anyone else solved it ?
Thanks in advance for any help
This is a example of the error from deadline:
2022-06-07 18:32:22: 0: STDOUT: error: DB element “mdl_OmniSurfacePresets_OmniSurface_Ceramic(float,texture_2d,_OmniSurface_OmniImage_alpha_mode,color,texture_2d,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,color,texture_2d,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,_OmniSurface_OmniShared_ior_presets,float,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,bool,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,color,texture_2d,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,color,texture_2d,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,bool,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,_OmniSurface_OmniShared_scattering_colors_presets,color,texture_2d,color,texture_2d,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,color,texture_2d,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,_OmniSurface_OmniShared_ior_presets,float,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,float3,texture_2d,bool,bool,bool,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,color,texture_2d,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,_OmniSurface_OmniShared_emission_mode,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,color,texture_2d,bool,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,bool,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,_OmniSurface_OmniShared_ior_presets,float,bool,bool,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,float,float3,texture_2d,bool,bool,bool,_OmniSurface_OmniImage_tangent_bitangent_mapping,float3,_OmniSurface_OmniShared_displacement_mode,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,texture_2d,_OmniSurface_OmniImage_alpha_mode,float,_base_texture_coordinate_system,int,bool,color,bool,float2,float,float,_OmniSurface_OmniImage_wrap_mode,_OmniSurface_OmniImage_wrap_mode,float,float,bool,bool,bool,_OmniSurface_OmniImage_projection_mode,float3,float3,float3)” is still referenced while transaction 117 is committed.
