Hello all, I purchased a used PC less than a year old with Nvidia Tuf 4080 Super graphic card. When the PC is powered ON, I noticed the fan on the right side (3rd fan) runs at a max speed above 1000rpm. I used a few software to try to control the fan but it seems like fan #2 and #3 are tied together that I can’t adjust the speed of #3 fan (see picture attached).
**Noticed: Fan Speed (Center) (RPM) with current: 1060rpm while the other two fans set at 32.
Regardless of what I do, I can’t seem to calm down the 3rd fan. When I use Afterburner or other controlling fan software, I can only see two fans.
I’m able to control fan#1, fan#2 to stop them from running but fan#3 just ALWAYS on with max speed. Adjust fan#2 should technically controlling fan#3 as well because they are both tied together, however like I said setting fan#2 does work but fan#3 seems not cooperating.
Question: Do I have bad GPU, bad fan#3? What can I do further to troubleshoot this?
Any suggestions/recommendations greatly appreciated.
