Dear community,
Because of the project deadlines, I need to urgently understand what cable options work in my case. I would really appreciate your help.
- 3x1 Mosaic,
- 4K 60hz each projector (3 projectors total),
- Cable lenght - 15m each,
- 1x Blackwell PRO 5000 GPU
GPU has DisplayPort outputs, projectors are HDMI only.
What cable types/options will 100% work in this case?
I found these 3 options options:
- Hybrid optic cable: Lindy 38491 - 20m Fibre Optic Hybrid DisplayPort 1.2 to HDMI 18G Cable
https://www.lindy.eu/Cables-Adapters/Audio-Video/DisplayPort/20m-Fibre-Optic-Hybrid-DisplayPort-1-2-to-HDMI-18G-Cable - Active copper cable: Purelink PI5110-150 - Aktive 4K DisplayPort/HDMI-Kabel - 15.00m
Aktives 4K DisplayPort/HDMI-Kabel - 15.00m | PureLink | Deutsch - Active adapter (Purelink PI156 - DP / HDMI ) + Active Optic Cable (Purlink FX-I350-015 - HDMI | HDMI)
Active 4K DisplayPort / HDMI Portsaver Adapter | PureLink | English
4K Premium High-Speed-HDMI-AOC-Glasfaserkabel – 15.0m, Silber | PureLink | Deutsch
Need your advice on what options (from described above) WILL and WILL NOT work?
Which options have more chanses to work and which less?
Are there any other more suitable 15m ready options (with or without adaptors)?
Thank you in advance!
