4 Sparks with switch vs ring?
Thinking about this because the Mikrotik CRS804 is perpetually out of stock.
Can you get the same results by using them in a ring, instead of using a switch?
Or using CRS504 instead? Worried it’ll be much slower, but can’t find any data on this.
@ccl using a switch is the preferred way. A switch/star topology gives you direct paths at 200 Gb/s on each Spark. The ring setup adds hops for non-adjacent traffic consuming bandwidth. Node-to-node traffic has to compete with forwarded through traffic, etc. A ring might avoid switch latency for adjacent nodes, but the extra hops will out-weight that advantage.
Several Spark users reported setting a four-node ring, so it works! However, if you’re clustering more than two Sparks a switch is recommended. Even a MikroTik one!
