ros launch for each cam $ roslaunch astra_camera astra.launch
when launching 4th cam, ROS core crashed but lsusb still show everything
multi cam $ roslaunch astra_camera multi_astra.launch
when launching multi_astra.launch, ROS waits some cam permanently.
And IR indicating Red LEDs do not ON at random Cams.
About power feeding issue, I tested a powered USB 3.0 hub as well, but not resolved.
Each cam consumes < 2.4W.
Hi @Mt.Hiker, I’m not familiar with the Astra camera or it’s ROS nodes, but are you able to test these cameras outside of ROS to narrow down if it’s an issue related to ROS or not? Is the any relevant dmesg kernel log when you try running multiple cameras?
Hi @dusty_nv
I’m trying to test it as you said too.
When it comes to ROS, this combination works at some kind of x86 mini PC.
Would you let me know USB bandwidth of JNX devkit?
The USB design is same for Jetson Nano and Xavier NX developer kits, that there is embedded USB bub connecting to one USB3 roothub. For having 5Gbps bandwidth, we would suggest use USB3 cameras.
