I’m using a valid personal API key (nvapi-…) to call I’m using a valid personal API key (nvapi-…) to call I’m using a valid personal API key (nvapi-…) to call I’m using a valid personal API key (nvapi-…) to call I’m using a valid personal API key (nvapi-…) to call I’m using a valid personal API key (nvapi-…) to call I’m using a valid personal API key (nvapi-…) to call I’m using a valid personal API key (nvapi-…) to call https://integrate.api.nvidia.com/v1/chat/completions but always get 403 Authorization failed. The same key works on NGC portal. I suspect my personal organization lacks “Public API Endpoints” permission as mentioned in other threads (e.g., but always get 403 Authorization failed. The same key works on NGC portal. I suspect my personal organization lacks “Public API Endpoints” permission as mentioned in other threads (e.g., but always get 403 Authorization failed. The same key works on NGC portal. I suspect my personal organization lacks “Public API Endpoints” permission as mentioned in other threads (e.g., but always get 403 Authorization failed. The same key works on NGC portal. I suspect my personal organization lacks “Public API Endpoints” permission as mentioned in other threads (e.g., #364127).).).). but always get 403 Authorization failed. The same key works on NGC portal. I suspect my personal organization lacks “Public API Endpoints” permission as mentioned in other threads (e.g., but always get 403 Authorization failed. The same key works on NGC portal. I suspect my personal organization lacks “Public API Endpoints” permission as mentioned in other threads (e.g., but always get 403 Authorization failed. The same key works on NGC portal. I suspect my personal organization lacks “Public API Endpoints” permission as mentioned in other threads (e.g., but always get 403 Authorization failed. The same key works on NGC portal. I suspect my personal organization lacks “Public API Endpoints” permission as mentioned in other threads (e.g., #364127).).).).
Could you please enable this permission for my account? My email: [84zzl@163.com]Could you please enable this permission for my account? My email: [84zzl@163.com]
Thanks.Thanks.
