Hello NVIDIA Support,
I am experiencing an authorization issue with the NVIDIA hosted API.
My NVIDIA API key successfully authenticates against the models endpoint:
GET https://integrate.api.nvidia.com/v1/models
HTTP 200
The response includes both of the models I tested:
moonshotai/kimi-k3
moonshotai/kimi-k2.6
However, inference requests consistently fail:
POST https://integrate.api.nvidia.com/v1/chat/completions
HTTP 403 Forbidden
“status”: 403,
“title”: “Forbidden”,
“detail”: “Authorization failed”
I tested the API directly with curl, without LiteLLM or Claude Code, using the official NVIDIA endpoint and a Bearer token.
I tested both:
moonshotai/kimi-k3
Both return the same HTTP 403 authorization error.
I also generated/replaced the API key and confirmed that the key is loaded correctly in my environment. The key begins with nvapi-.
For additional testing, I am using LiteLLM as a local proxy for Claude Code. LiteLLM itself starts correctly and receives requests from Claude Code, but the NVIDIA upstream request fails with the same 403 error:
Nvidia_nimException - Error code: 403
{‘status’: 403, ‘title’: ‘Forbidden’, ‘detail’: ‘Authorization failed’}
Therefore, the issue appears to be with NVIDIA hosted inference authorization rather than my local LiteLLM or Claude Code configuration.
Could you please check whether my personal NVIDIA organization/account has the required Public API Endpoints / hosted NIM inference entitlement or permission enabled?
I have seen other recent reports describing the same behavior: /v1/models returns HTTP 200 while /v1/chat/completions returns HTTP 403, with users asking NVIDIA to enable the Public API Endpoints permission.
I am not posting my API key publicly. I can provide my account information or API-key prefix privately if required.
Thank you.
