404 Error / Missing API Endpoint Code for cosmos3-nano on build.nvidia.com
Hi NVIDIA Team,
I am trying to test the newly released cosmos3-nano model using the free cloud credits on build.nvidia.com.
The model page UI indicates that it is available as a free cloud endpoint, but the actual integration tab is missing the endpoint URL / code generation snippet for Node.js/Python, and manually constructing requests using standard NIM endpoints results in a 404 Not Found error.
Steps to reproduce / What I checked:
  1. Checked catalog.ngc.nvidia.com and build.nvidia.com for the cosmos3-nano container endpoints.
  2. Formulated a standard OpenAI-compatible NIM request using Node.js / Axios pointing to:
    https://ai.api.nvidia.com/v1/gr/nvidia/cosmos-3-nano/chat/completions (as well as trying the /v1/infer routes).
  3. The server consistently responds with a 404 Status Code.
Could someone please provide the correct base URL or confirm if the cloud inference router for Cosmos 3 Nano is still being provisioned globally?
Thank you!
I’m hitting the same issue with cosmos3-nano. The model page on build.nvidia.com shows it as a free hosted endpoint, but there’s no API code snippet and no “Try it” option, so there’s no way to actually call it.
I’ve already generated an API key (nvapi-...) on my account.
Could you confirm:
  1. Is the hosted endpoint for cosmos3-nano live yet, or still rolling out?
  2. Is the “Public API Endpoints” permission enabled on my org? I’ve seen this cause the run button and code snippet to be missing even when a model is available — if that’s it, please enable it for my account.
Account email: simeonmachin@gmail.com
I am also having issues with this, seems like we can activate it in the vidia website window to generate a demo video with one of the demo videos.. is “THIS” the only intended use atm?
I’m unable to use this over api at all, json formatting doesn’t seem to be the problem, it seems to be a wrong-endpoint problem since every one of the 8x urls I tried returned a generic Go-server “404 page not found” text, not a nvidia-style json error body (NVIDIA api normally returns structured json even on errors- invalid model, bad auth ect). A raw “404 page not found” plaintext response means I’m hitting a path that doesn’t exist on their router at all, before the request even reaches model-routing logic. That’s consistent with your the forum report here: the model page UI indicates it’s available as a free cloud endpoint, but the integration tab is missing the actual endpoint URL/code snippet, and manually constructing requests against standard NIM endpoints results in 404.
pretty sure its probably still in rollout phase, thats why we dont have one yet.
Running into the same issue:
email: lawrenceliang@eastworlds.io
I’ve tried many methods too, but I couldn’t use them.
Hi. I’m running into the same issue reported in this thread — testing cosmos3-nano on the build.nvidia.com playground consistently returns a 500 error, regardless of input.
Subject: Cosmos 3 Nano API returns HTTP 404 with valid NVIDIA API key
Hello NVIDIA team,
We are integrating Cosmos 3 Nano into the FixSimple visual editor for image-to-video generation.
We followed the official API Quickstart and tested:
POST https://ai.api.nvidia.com/v1/cosmos/nvidia/cosmos3-nano
Using a configured NVIDIA API key and the official text-to-video request payload.
The response is consistently:
  • HTTP/2 404
  • Content-Type: text/plain
  • Body: 404 page not found
We also tested GET and requests with an invalid key. The same 404 response was returned.
The Cosmos 3 Nano Playground is accessible, but the documented API endpoint is not working.
Could you please confirm:
  1. Is the public Cosmos 3 Nano API currently operational?
  2. Is the documented endpoint correct?
  3. Does our NVIDIA account require additional API permissions?
  4. Is there an alternative hosted endpoint available under the free API trial?
We would appreciate guidance on restoring API access without deploying or hosting the model ourselves.
Thank you.
bende de aynı sorun var cevabı bulabildiniz mi?
Hello NVIDIA team,
Please help restore or identify the supported programmatic route for the free Cosmos3 Nano endpoint advertised on NVIDIA Build.
On 21 October 2026 we verified the following with the same existing personal key and organization:
  1. NVIDIA’s documented caller-info endpoint returned HTTP 200. The account has PUBLIC_API_ENDPOINTS_USER and ORG_OWNER; the key includes ai-foundations and nv-cloud-functions products. Working Nemotron and Magpie calls also returned HTTP 200. We therefore have no evidence that the key is globally invalid or that the general Public API Endpoints role is missing.
  2. NVIDIA Build currently publishes POST https://ai.api.nvidia.com/v1/cosmos/nvidia/cosmos3-nano. A valid image-to-video attempt did not provide a usable HTTP result. Separate schema-invalid {} routing controls, with and without the existing valid key, both returned HTTP 404, text/plain; charset=utf-8, and 404 page not found at approximately 20:10 UTC. No valid generation was requested by those empty-body controls.
  3. The current public model metadata identifies function d09cd49d-d7f2-4361-928f-ea22af707249. A separate new request through the documented NVCF dispatcher returned structured HTTP 404: Function 'd09cd49d-d7f2-4361-928f-ea22af707249': Not found for account [REDACTED].
  4. The existing key can list 234 authorized/public NVCF functions, but the advertised Cosmos3 Nano function was not present. The API list is not being treated as a universal entitlement inventory.
  5. The signed-in Build Playground displayed a five-second image-to-video output after a custom prompt using NVIDIA’s automotive assembly reference. The retained MP4 fully decodes: VP9, 832×480, 121 frames at 24 fps, 18,374,015 bytes. The left industrial arm visibly moves. This bounded UI result is not a successful public API call or an end-to-end production test.
  6. We traced the publicly shipped Playground JavaScript without reading/replaying session credentials or CAPTCHA tokens. The Cosmos V3 component passes its model payload to modelAPIUrl(e.id), resolved as /v2/predict/models/qc69jvmznzxy/cosmos3-nano. The shared request helper selects an NGC gateway origin at runtime, uses credentials: 'include', and supports an nv-captcha-token header. The component displays the parsed response’s b64_video; it has no local selected-example output fallback in that V3 response branch. The runtime gateway host and server-side function/version mapping remain unverified. We have not called this browser gateway directly or treated it as a supported bearer-key API.
Could you confirm the current supported bearer-key API URL, request contract and function/version identifier for this model, and whether our existing organization requires model-specific provisioning? In particular, does the free Playground currently have a corresponding public programmatic generation endpoint? If the advertised route is not currently served, please correct the integration example or restore the route. We want to use the existing NVIDIA free/developer access, without a replacement key, paid GPU deployment or an external inference provider.
We can provide account identifiers privately through an official secure support channel if required. No key should be shared or requested in a public reply.
Thank you.
Hello NVIDIA Developer Support,
We are testing the free development endpoint with an existing verified NVIDIA Developer account and API key.
Please confirm the supported public bearer-key API route for Cosmos3 Nano and whether model-specific provisioning is required.
Tests on 2026-10-23:
  1. The existing key successfully lists models via GET https://integrate.api.nvidia.com/v1/models (HTTP 200, 84 entries), and Nemotron returns a real text response.
  2. GET https://api.nvcf.nvidia.com/v2/nvcf/functions returns HTTP 200 with 236 entries. No Cosmos video generator is identifiable by the names/descriptions in that response. We do not assume this list proves all model entitlements.
  3. NVIDIA Build and the Cosmos3 Nano model card publish POST https://ai.api.nvidia.com/v1/cosmos/nvidia/cosmos3-nano. A text2video request using the published example schema returns HTTP 404 with Content-Type: text/plain; charset=utf-8 and 404 page not found.
  4. Separate schema-invalid {} routing controls, with and without the same key, return the identical plain-text 404. These controls did not request valid generation.
  5. The signed-in official Playground generated a downloadable MP4 after a custom prompt using NVIDIA’s public automotive assembly reference image, at the 480 resolution tier, 25 frames requested, 24 fps. The returned video fully decodes with FFmpeg. This is a successful browser UI result, not a successful public API call.
Questions:
  • Is the advertised public API route live? What is the supported invocation URL and request schema?
  • If model-specific access is needed, how can it be enabled for the existing free developer account?
  • If Cloud Functions is the supported route, what function/version identifier should this account use?
  • Does the Playground currently have an equivalent supported public API, or is its availability separate?
We want to use the existing free development API, without paid partner endpoints or a paid GPU deployment.
We will not share the API key publicly. Account identifiers can be supplied privately through your official secure support process if needed.
Official references:
I’m integrating NVIDIA Cosmos3 Nano with Claude Code through a Python MCP server for automated technical video generation.
The MCP server connects successfully, but the officially documented API endpoint returns HTTP 404:
Response:
HTTP/1.1 404 Not Found
404 page not found
I reproduced the issue using a direct PowerShell/curl request with the documented text2video payload, independently of Claude Code.
Could NVIDIA confirm whether the hosted Cosmos3 Nano API is operational, whether model-specific permissions are required, and whether there is a working public API endpoint available for developer accounts?
Thank you.
We reproduced the Cosmos3 Nano API issue on 4 November 2026 using a fresh, ACTIVE NVIDIA Build key. Please help identify or enable the supported route for custom image-to-video evaluation.
Verified results:
  1. The new key returned HTTP 200 for real Nemotron embedding inference (14 input tokens, 2,048 dimensions) and HTTP 200 for Cloud Functions discovery.
  2. The model card advertises POST https://ai.api.nvidia.com/v1/cosmos/nvidia/cosmos3-nano. Our earlier request to that documented route returned plain-text HTTP 404.
  3. The live official endpoint specification at https://api.ngc.nvidia.com/v2/endpoints/qc69jvmznzxy/cosmos3-nano/spec identifies function d09cd49d-d7f2-4361-928f-ea22af707249 and inference path /v1/infer.
  4. With the new key, POST to the documented NVCF function dispatcher for that exact function returned structured HTTP 404: Function not found for account [REDACTED]. The image2video payload passed the current OpenAPI schema: 720_9_16, 121 frames, 24 fps, 35 inference steps. No accepted invocation ID or video was returned.
  5. The key lists 263 functions; the advertised Cosmos3 function is absent. We understand that listing alone does not prove invocation entitlement.
  6. The live Build configuration at https://build.nvidia.com/api/runtime/killswitches/media/select-example.models.yaml includes nvidia/cosmos3-nano. The official client uses this flag to hide custom file upload. The signed-in Experience can return an example-conditioned clip, which does not establish custom-reference API access.
Could you confirm whether custom-reference inference is enabled for this free development endpoint, the exact supported URL/function/version, and whether model-specific provisioning or additional permissions are required? If the preview is currently limited to examples, please clarify its API availability.
We are evaluating the existing development route without activating a paid partner deployment. No key, cookie, image, private account identifier, analytics or billing information is included here. Account details can be supplied privately through an official secure support channel if needed.
Thank you.
Hello NVIDIA Support,
I’m trying to connect Cosmos 3 Nano to my Python application using an NVIDIA Build API key.
My results:
  • NVIDIA Models API: HTTP 200
  • NVIDIA Cloud Functions API: HTTP 200
  • Cosmos 3 Nano hosted inference endpoint: HTTP 404
  • Cosmos 3 Nano Function Versions API: HTTP 404
  • Cosmos 3 Nano is not visible in my accessible functions list.
Could you please confirm whether Cosmos 3 Nano requires additional account permissions or whether the hosted API endpoint is currently unavailable?
I would like to use the free hosted API without deploying a paid GPU instance.
Thank you!
