404 Function Not Found for /v1/chat/completions on Personal Organization
Hello NVIDIA Support, I am using the NVIDIA hosted API from a personal NVIDIA Build account. My API key is active and newly generated. The following endpoint works successfully: GET https://integrate.api.nvidia.com/v1/models It returns the model catalogue successfully. However, attempts to use the hosted chat-completion endpoint fail with HTTP 404: POST https://integrate.api.nvidia.com/v1/chat/completions The response is: HTTP 404 - 404 page not found I have tested this independently of my application using Python. The request reaches the NVIDIA API, and /v1/models works correctly. Current model being tested: nvidia/llama-3.1-nemotron-nano-8b-v1 The model appears in the /v1/models catalogue. Endpoint: https://integrate.api.nvidia.com/v1 Diagnostics performed: - API key is active. - /v1/models returns successfully. - The model appears in the model catalogue. - Network connectivity is working. - Direct Python testing produces the same 404 on /v1/chat/completions. - The failure occurs specifically on the chat-completion request. Could you please check my personal organization’s access/entitlement for Public API Endpoints and verify that the hosted inference/chat-completion function is enabled for my account? Thank you.
Account access issues are not handled here through the forums.
Please check the pinned posts:
for details.
Thank you!
