System works fine (in fact it performs really well with OpenGL) - however when I try to use vkcube - the cub starts spinning as normal for a few seconds - then my entire desktop freezes - I have to hard reboot to go back to the desktop…
I can’t see any useful logs.
Here is my vulkaninfo output : (not the initial error →
WARNING: [Loader Message] Code 0 : loader_icd_scan: Can not find 'ICD' object in ICD JSON file /usr/share/vulkan/icd.d/nvidia_layers.json. Skipping ICD JSON
INTEL-MESA: warning: ../src/intel/vulkan/anv_device.c:1250: FINISHME: Implement pop-free point clipping
A bit more info… If I run vkcube and leave the mouse alone it works fine, as soon as I click the mouse (anywhere on the screen) it freezes (it feels like when you have a massive load - i.e you move the cursor and nothing happens…)
This time I was able to got to a TTY and kill vkheads…
There’s nothing suspicious to be found in the logs, only the notice
[ 19202.561] (WW) NVIDIA: Wait for channel idle timed out.
but that’s rather a symptom since the driver/gpu seems to be blocking. I also can’t reproduce it, vkcube runs fine on driver 440.44 for me.
Maybe two things to check:
It doesn’t freeze - however the cude is spinning really fast (like insanely fast and looks wrong.)
edit :
After re-enabling 2nd monitor (after using the above “PRIME Synchronization” “0” command without 2nd display) the same thing works - i.e its spinning really fast (to the point you can’t tell if its a cube)
I’ve also got this same problem, I’m running Manjaro 18.1.5, Kernel 5.3.18-1, with Nvidia drivers 440.44 (from the manjaro extra repo) with X.Org X Server 1.20.6
I tried the aforementioned
and had the same outcome, with the ridiculously spinny cube. (also have screen tearing after running that, but yeah.)
If I can help troubleshoot this, ping me. myvulkaninfo.txt (34.6 KB) nvidia-bug-report.log.gz (320 KB)
