At some random points X.org locks up and does not respond to keyboard and mouse input. This usually happens after a considerable period of uptime (like a few days), during which the system is loaded with various desktop apps (web browser, email client, text editor, etc.), ffmpeg for video transcoding and occasional games via Wine/DXVK. The lock up may happen when the display is off for powersaving or when it is active. In any case, there is no particular user activity that leads to the problem, it just happens by itself at seemingly random points.
When the lock up happens, in the kernel log I can see a backtrace involving Nvidia kernel module and an error saying:
Xorg: page allocation failure: order:4, mode:0x40cc0(GFP_KERNEL|__GFP_COMP), nodemask=(null),cpuset=/,mems_allowed=0
Kubuntu 19.10, x86_64, Nvidia driver 440.48.02.
nvidia-bug-report.log.gz (116 KB)
kern.log.gz (7.7 KB)
generix
January 28, 2020, 9:30am
#2
Well, there was plenty memory available (both host RAM and presumably VRAM) when the error took place. The system was not running any GPU-intensive tasks aside from idle KDE desktop. It was running CPU-intensive ffmpeg (without hwaccel), which utilized all CPU cores.
When you say “fast enough”, does it mean there’s some sort of timeout for the allocation operation? If so, that might explain the crash even if there is enough free memory.
generix
January 28, 2020, 10:25am
#4
The question is how much contiguous memory was available at the time of the allocation attempt and how much the nvidia driver wanted. Since it’s a blackbox, I can only speculate from observation. The linked threads (there are more) all had the same situation, no CPU/GPU intensive but large memory consuming tasks and grown caches and then the driver needed to do something.
There’s enough memory available but the kernel needs some time to free it up from caches and the driver doesn’t seem to ask twice.
Still happens with 440.59, which had a release note about fixing crashes on wake up. This time the crash happened when I tried to switch the primary display from DisplayPort to HDMI.
kern.log.gz (30.3 KB)
Still happens on 440.66.08. I tried enabling KMS by setting “options nvidia-drm modeset=1” in modprobe.d/nvidia.conf, it doesn’t help. Please fix.
kern.log (165.0 KB)
Still happens with 440.66.11.
I may have found a workaround. If I disable HardDPMS in xorg.conf (Option “HardDPMS” “False”), the crashes don’t seem to happen. At least they have not happened in a few days for me.
The problem with HardDPMS off for me is that my display turns on backlight twice, with 5 minute interval, after it was turned off. I suspect, this is because the GPU is switching between DPMS modes (Display turns on twice after being turned off for powersaving ).
This happened to me for the first time just now.
It is weird, since i use the intel igp as the primary gpu and nvidia via prime render offload!
After the time passed since my last post I have been running with HardDPMS off and have not had a single crash. So it looks like HardDPMS is the culprit.
I would really like it to work though, since, as I described earlier, my NEC MultiSync EA272UHD display doesn’t work well with DPMS. I also remember my older Samsung display didn’t work with DPMS when connected via DisplayPort (the backlight wouldn’t turn off), so I imagine this is not a one off problematic display model.
Nvidia, is there any update on this problem?
Lastique
September 18, 2020, 11:07pm
#10
Here’s a fresh report log from a crash, Kubuntu 20.04, Nvidia driver 455.23.04.
nvidia-bug-report.log.gz (106.2 KB)
I’m having this problem too. It just started a few months ago.
I noticed that it may be happening when the screen blanks and the Yamaha receiver and LG TV connected to the GTX1050 have been turned off.
I’m hoping the fix posted in here will work around the issue for me as well.
Thanks Lastique.
I still had another failure after setting harddpms false… Bummer.
Seth_T
October 9, 2020, 12:21am
#13
I had the same lock up today (after locking my screen) with 440.100
Oct 8 12:23:25 five kernel: [1149767.359221] Xorg: page allocation failure: order:4, mode:0x40cc0(GFP_KERNEL|__GFP_COMP), nodemask=(null),cpuset=/,mems_allowed=0
Oct 8 12:23:25 five kernel: [1149767.359226] CPU: 18 PID: 2585978 Comm: Xorg Tainted: P OE 5.4.0-47-generic #51-Ubuntu
Oct 8 12:23:25 five kernel: [1149767.359227] Hardware name: System manufacturer System Product Name/TUF GAMING X570-PLUS, BIOS 2407 07/01/2020
Oct 8 12:23:25 five kernel: [1149767.359227] Call Trace:
Oct 8 12:23:25 five kernel: [1149767.359234] dump_stack+0x6d/0x9a
Oct 8 12:23:25 five kernel: [1149767.359237] warn_alloc.cold+0x7b/0xdf
Oct 8 12:23:25 five kernel: [1149767.359238] __alloc_pages_slowpath+0xe07/0xe50
Oct 8 12:23:25 five kernel: [1149767.359240] ? get_page_from_freelist+0x6b/0x390
Oct 8 12:23:25 five kernel: [1149767.359242] __alloc_pages_nodemask+0x2d0/0x320
Oct 8 12:23:25 five kernel: [1149767.359243] alloc_pages_current+0x87/0xe0
Oct 8 12:23:25 five kernel: [1149767.359245] kmalloc_order+0x1f/0x80
Oct 8 12:23:25 five kernel: [1149767.359246] kmalloc_order_trace+0x24/0xa0
Oct 8 12:23:25 five kernel: [1149767.359257] ? _nv000491kms+0x50/0x50 [nvidia_modeset]
Oct 8 12:23:25 five kernel: [1149767.359258] __kmalloc+0x220/0x280
Oct 8 12:23:25 five kernel: [1149767.359266] ? _nv000491kms+0x50/0x50 [nvidia_modeset]
Oct 8 12:23:25 five kernel: [1149767.359273] nvkms_alloc+0x24/0x60 [nvidia_modeset]
Oct 8 12:23:25 five kernel: [1149767.359284] _nv002521kms+0x16/0x30 [nvidia_modeset]
Oct 8 12:23:25 five kernel: [1149767.359285] WARNING: kernel stack frame pointer at 000000003bcd4f23 in Xorg:2585978 has bad value 00000000b371c8d7
Oct 8 12:23:25 five kernel: [1149767.359287] unwind stack type:0 next_sp:0000000000000000 mask:0x2 graph_idx:0
Oct 8 12:23:25 five kernel: [1149767.359288] 00000000cf9c8690: ffffbd8e8252f848 (0xffffbd8e8252f848)
@btmckee9 Did you put the HardDPMS option in the Device section? Here is how my section looks, and it doesn’t crash:
Section "Device"
Identifier "Default nvidia Device"
Driver "nvidia"
Option "NoLogo" "True"
Option "CoolBits" "28"
Option "TripleBuffer" "True"
Option "HardDPMS" "False"
EndSection
nvidia-bug-report.log.gz (409.5 KB)
The system is mostly headless and I only turn on the connected external TV to consume media.
When I don’t use the gpu, it either sits idle at the lightdm login window or I shut down lightdm and unload the driver completely.
It started since about a year. Happens randomly. IIRC it never occured when I was actively using the GPU, but only when idling, except for the most recent hang which occured when I opened Vivaldi browser.
Has my card become physically defective or is this a software issue?
What I also observed is if using the opensource nouveau module, I am seeing a thread sitting constantly at 100% on one of the cpus.
I don’t remember seeing any hangs on kernel 4.x series.
reddaly
December 2, 2020, 2:43am
#16
Same problem here.
Relevant section of dmesg output seems to be…
: ffff9fad9f2d7080 (0xffff9fad9f2d7080)
[82168.611834] 00000000a45e458c: 0000000200000000 (0x200000000)
[82168.611834] 00000000084051b6: 0000000000000000 ...
[82168.611834] 00000000d3005ea0: 32ea54c056890b00 (0x32ea54c056890b00)
[82168.611834] 0000000034628dac: 0000000000000001 (0x1)
[82168.611835] 00000000e9d70e4b: 0000000000040cc0 (0x40cc0)
[82168.611837] 00000000c7345f5b: ffffffffb36cb1c0 (policy_zone+0x20/0x20)
[82168.611837] 0000000068424bbc: 0000000000000004 (0x4)
[82168.611838] 00000000c86e76ac: 0000000000000000 ...
[82168.611838] 00000000d1d35ea0: ffffc25f40f17a38 (0xffffc25f40f17a38)
[82168.611838] 000000009d43f5e8: ffffffffb1c99077 (alloc_pages_current+0x87/0xe0)
[82168.611839] 000000004638ba20: 000000000000ac48 (0xac48)
[82168.611839] 00000000edec7fc2: 0000000000000004 (0x4)
[82168.611839] 0000000084003584: 0000000000000cc0 (0xcc0)
[82168.611840] 0000000012062f3f: 0000000000000004 (0x4)
[82168.611840] 00000000a02800da: ffffc25f40f17a58 (0xffffc25f40f17a58)
[82168.611841] 000000005af4311e: ffffffffb1c4f27f (kmalloc_order+0x1f/0x80)
[82168.611841] 00000000f39d9e8a: 000000000000ac48 (0xac48)
[82168.611841] 0000000016f4de52: 000000000000ac48 (0xac48)
[82168.611842] 0000000010b8b329: ffffc25f40f17a98 (0xffffc25f40f17a98)
[82168.611842] 00000000a3034163: ffffffffb1c4f304 (kmalloc_order_trace+0x24/0xa0)
[82168.611843] 00000000a4d1cd2c: 000000005b6a4908 (0x5b6a4908)
[82168.611843] 000000009786390d: 0000000000000001 (0x1)
[82168.611843] 0000000081626f36: 000000000000ac48 (0xac48)
[82168.611844] 00000000c96ec2e2: 0000000000000cc0 (0xcc0)
[82168.611844] 00000000a4933053: 000000000000ac48 (0xac48)
[82168.611844] 00000000c4596db0: 0000000000000001 (0x1)
[82168.611845] 000000007d17a35c: ffffc25f40f17ad8 (0xffffc25f40f17ad8)
[82168.611845] 00000000f34bd41f: ffffffffb1ca835b (__kmalloc+0x22b/0x290)
[82168.611845] 000000006c47310e: 3f8000003f800000 (0x3f8000003f800000)
[82168.611846] 00000000e7a28edc: 0000000000000001 (0x1)
[82168.611846] 00000000f4e21769: 000000000000ac48 (0xac48)
[82168.611846] 0000000075763438: 0000000000000000 ...
[82168.611847] 000000003419d3de: ffff9fad4c73fa08 (0xffff9fad4c73fa08)
[82168.611847] 00000000eb3cd35b: 0000000000000001 (0x1)
[82168.611847] 00000000ee1e4cc8: ffffc25f40f17af8 (0xffffc25f40f17af8)
[82168.611853] 000000004fc05fd9: ffffffffc22e03b4 (nvkms_alloc+0x24/0x60 [nvidia_modeset])
[82168.611854] 00000000d7db44d7: 000000000000ac48 (0xac48)
[82168.611854] 00000000c85fffb6: 0000000000000000 ...
[82168.611861] 00000000b69dd9de: ffffffffc2323a96 (_nv002718kms+0x16/0x30 [nvidia_modeset])
[82168.611861] 00000000d22017ee: ffff9fa1ed8b0008 (0xffff9fa1ed8b0008)
[82168.611869] 00000000b66d06e6: ffffffffc230ef5e (_nv002593kms+0x4e/0x1610 [nvidia_modeset])
[82168.611869] 000000001eabc8d8: ffff9fa1ed8b01c8 (0xffff9fa1ed8b01c8)
[82168.611869] 00000000725911d4: ffffc25f40f17c38 (0xffffc25f40f17c38)
[82168.611870] 0000000086e01d68: 0000000000000000 ...
[82168.611878] 000000006db059c3: ffffffffc23802d5 (_nv000550kms+0x365/0x3c0 [nvidia_modeset])
[82168.611879] 000000007f89a4aa: ffff9fad4c497008 (0xffff9fad4c497008)
[82168.611879] 00000000d3b476fc: ffff9fa1ed8b0488 (0xffff9fa1ed8b0488)
[82168.611879] 000000004d3f0b2a: 0000000000000001 (0x1)
[82168.611880] 000000008025159a: ffff9fa1ed8b0018 (0xffff9fa1ed8b0018)
[82168.611880] 000000008a742919: ffff9fa1ed8b0018 (0xffff9fa1ed8b0018)
[82168.611880] 00000000b7d98932: ffff9fad4c490008 (0xffff9fad4c490008)
[82168.611881] 00000000b44541cb: ffff9fa1ed8b0008 (0xffff9fa1ed8b0008)
[82168.611881] 00000000d4ab6a81: ffff9fa1ed8b01c8 (0xffff9fa1ed8b01c8)
[82168.611881] 00000000889bb910: 0000000000000005 (0x5)
[82168.611882] 00000000c3d8d38b: ffff9fa1ed8b3bd8 (0xffff9fa1ed8b3bd8)
[82168.611882] 0000000072ee647f: 0000000100000000 (0x100000000)
[82168.611882] 00000000fc624782: ffff9fa1ed8b0018 (0xffff9fa1ed8b0018)
[82168.611883] 000000009f44e464: 0000000000000000 ...
[82168.611883] 0000000003206cc9: ffffc25f40f17ca8 (0xffffc25f40f17ca8)
[82168.611883] 00000000d68f0ae7: 0000000000000000 ...
[82168.611884] 0000000043edaa77: 0000000400000000 (0x400000000)
[82168.611884] 00000000797e0249: 0000000000000005 (0x5)
[82168.611884] 00000000fd215675: 0000ff0101080001 (0xff0101080001)
[82168.611885] 00000000f70c643c: ffffffff00000000 (0xffffffff00000000)
[82168.611885] 0000000086b4663c: ffffffffffffffff (0xffffffffffffffff)
[82168.611885] 0000000042805cf4: ffffffffffffffff (0xffffffffffffffff)
[82168.611886] 00000000119344cd: 0000000000000000 ...
[82168.611886] 00000000681d7799: ffff9fa52d3fb508 (0xffff9fa52d3fb508)
[82168.611886] 00000000b6cdacd9: 0000000000000000 ...
[82168.611886] 0000000078153efd: ffff9fad2da921c8 (0xffff9fad2da921c8)
[82168.611887] 000000004d9c7ca4: 0000000100255a00 (0x100255a00)
[82168.611887] 0000000096ae70cb: 0000000000004000 (0x4000)
[82168.611887] 00000000edac4a99: 0000000000000000 ...
[82168.611888] 00000000a9a369eb: 0000048800001ac5 (0x48800001ac5)
[82168.611888] 0000000042fb66d4: 0000000000000000 ...
[82168.611894] 00000000a890e1db: ffffffffc22e04b2 (nvkms_memset+0x12/0x20 [nvidia_modeset])
[82168.611894] 00000000a9c4a7fe: ffff9fad4c73fa08 (0xffff9fad4c73fa08)
[82168.611904] 00000000639db5af: ffffffffc232b599 (_nv002680kms+0x309/0x3c0 [nvidia_modeset])
[82168.611904] 0000000045f09a61: 0000000000000001 (0x1)
[82168.611904] 00000000449e6845: ffff9fa1ed8b0488 (0xffff9fa1ed8b0488)
[82168.611905] 00000000d0f10804: 0000000000000000 ...
[82168.611905] 0000000029925d41: ffff9fad4c73fa18 (0xffff9fad4c73fa18)
[82168.611905] 00000000ab6afe68: ffff9fa1ed8b0008 (0xffff9fa1ed8b0008)
[82168.611906] 00000000abf72c0d: 0000000000000000 ...
[82168.611906] 0000000015f5e538: ffff9fad4c73fa08 (0xffff9fad4c73fa08)
[82168.611906] 0000000025144d9c: 0000000000000001 (0x1)
[82168.611914] 00000000d9f8e653: ffffffffc232b8ef (_nv002698kms+0x29f/0x540 [nvidia_modeset])
[82168.611914] 00000000c440bfe6: 0000000000000000 ...
[82168.611915] 00000000b3be658e: 000000013e5f2e80 (0x13e5f2e80)
[82168.611915] 000000000aa47bd3: 00000000000001c0 (0x1c0)
[82168.611915] 00000000a715fae6: ffff9fad4c73fa08 (0xffff9fad4c73fa08)
[82168.611916] 000000000f189df0: 0000000001010001 (0x1010001)
[82168.611916] 00000000ff442cc3: ffff9fad4c497008 (0xffff9fad4c497008)
[82168.611916] 0000000061356cf4: 000001005e92ad00 (0x1005e92ad00)
[82168.611917] 00000000bab3316d: ffff9fad3e5f3858 (0xffff9fad3e5f3858)
[82168.611917] 00000000867a566a: ffff9fad5e96adc0 (0xffff9fad5e96adc0)
[82168.611917] 00000000c4718f31: 0000c25f40f17e28 (0xc25f40f17e28)
[82168.611918] 0000000089cc3bed: ffff06400a000000 (0xffff06400a000000)
[82168.611918] 00000000e79066b9: 0000000000000000 ...
[82168.611918] 00000000ab818d60: ffff9fad3e5f2e80 (0xffff9fad3e5f2e80)
[82168.611919] 00000000b645b70c: 7fffffffffffffff (0x7fffffffffffffff)
[82168.611919] 000000001e41219c: ffff9fad3e5f38f8 (0xffff9fad3e5f38f8)
[82168.611919] 00000000a1742c42: ffff9fad57a93200 (0xffff9fad57a93200)
[82168.611920] 00000000b29be635: ffffc25f40f17dd8 (0xffffc25f40f17dd8)
[82168.611921] 000000006a871361: ffffffffb24d7222 (schedule+0x42/0xb0)
[82168.611921] 0000000094a7f944: ffff9fad3e5f2e80 (0xffff9fad3e5f2e80)
[82168.611928] 0000000065ac88e7: ffffffffc23e9db8 (nvkms_kthread_q+0x18/0xfffffffffffa1260 [nvidia_modeset])
[82168.611929] 00000000bd3e4659: ffffc25f40f17e40 (0xffffc25f40f17e40)
[82168.611929] 00000000e33fba65: ffffffffb24daa5e (schedule_timeout+0x10e/0x160)
[82168.611930] 000000006642d8d6: 7fffffffffffffff (0x7fffffffffffffff)
[82168.611930] 000000005c3c0696: 0000000000000000 ...
[82168.611930] 000000009fec41b7: ffff9fad57a93200 (0xffff9fad57a93200)
[82168.611931] 000000001d534d23: 000000000d802c00 (0xd802c00)
[82168.611931] 000000005b4b4be1: 0001000000000000 (0x1000000000000)
[82168.611931] 0000000047be7539: 32ea54c056890b00 (0x32ea54c056890b00)
[82168.611932] 0000000052e6d475: ffff9fad3e5f2e80 (0xffff9fad3e5f2e80)
[82168.611939] 00000000c21abe5b: ffffffffc23e9db8 (nvkms_kthread_q+0x18/0xfffffffffffa1260 [nvidia_modeset])
[82168.611939] 00000000ced799e0: 7fffffffffffffff (0x7fffffffffffffff)
[82168.611939] 00000000259af119: ffffc25f40f17e98 (0xffffc25f40f17e98)
[82168.611940] 0000000011652ddb: ffffffffb24d9ab1 (__down_interruptible+0x91/0xf0)
[82168.611940] 0000000064ccde7b: dead000000000100 (0xdead000000000100)
[82168.611941] 00000000b00a1b9d: dead000000000122 (0xdead000000000122)
[82168.611948] 00000000d4f88b7a: ffffffffc232a151 (_nv000528kms+0x71/0x80 [nvidia_modeset])
[82168.611954] 0000000058c7b2c7: ffffffffc22e0901 (nvkms_kthread_q_callback+0x71/0xe0 [nvidia_modeset])
[82168.611955] 00000000b4e31e15: 0000000000000000 ...
[82168.611955] 00000000d3340337: 0000000100000000 (0x100000000)
[82168.611962] 0000000087187d94: ffffffffc23e9da0 (nvkms_deferred_close_kthread_q+0x40/0xfffffffffffa12a0 [nvidia_modeset])
[82168.611962] 000000001006e710: ffffc25f40f17ec0 (0xffffc25f40f17ec0)
[82168.611963] 000000009be0caf4: ffff9fad57a93200 (0xffff9fad57a93200)
[82168.611970] 0000000068c71736: ffffffffc23e9db0 (nvkms_kthread_q+0x10/0xfffffffffffa1260 [nvidia_modeset])
[82168.611970] 000000009885208d: ffff9fad3e5f38f8 (0xffff9fad3e5f38f8)
[82168.611970] 00000000611145b7: ffff9fad57a93200 (0xffff9fad57a93200)
[82168.611976] 00000000284be84f: ffffffffc22e091a (nvkms_kthread_q_callback+0x8a/0xe0 [nvidia_modeset])
[82168.611983] 0000000093dadf5c: ffffffffc23e9db8 (nvkms_kthread_q+0x18/0xfffffffffffa1260 [nvidia_modeset])
[82168.611984] 00000000d0b6e7c8: ffffc25f40f17f00 (0xffffc25f40f17f00)
[82168.611990] 00000000ac1353ee: ffffffffc22e12dc (_main_loop+0x8c/0x140 [nvidia_modeset])
[82168.611990] 00000000bb975bf8: ffff9fad3e5f2e80 (0xffff9fad3e5f2e80)
[82168.611991] 0000000007d01246: ffff9fad3e5f2e80 (0xffff9fad3e5f2e80)
[82168.611991] 0000000012145100: ffff9fad56e9d9c0 (0xffff9fad56e9d9c0)
[82168.611991] 000000006e61bed0: ffff9fad3c70c500 (0xffff9fad3c70c500)
[82168.611998] 000000001c3a5136: ffffffffc23e9da0 (nvkms_deferred_close_kthread_q+0x40/0xfffffffffffa12a0 [nvidia_modeset])
[82168.611999] 00000000a6ae3e04: ffffc25f40b3bb20 (0xffffc25f40b3bb20)
[82168.611999] 00000000ce9e149e: ffffc25f40f17f48 (0xffffc25f40f17f48)
[82168.612000] 0000000027ebe15d: ffffffffb1ac84c4 (kthread+0x104/0x140)
[82168.612006] 00000000b0dadeb8: ffffffffc22e1250 (_raw_q_schedule+0x70/0x70 [nvidia_modeset])
[82168.612006] 00000000411a061d: ffff9fad56e9d9f8 (0xffff9fad56e9d9f8)
[82168.612007] 000000002cda4957: ffffffffb1ac83c0 (kthread_park+0x90/0x90)
[82168.612007] 00000000ee08cc4a: ffff9fad3c70c500 (0xffff9fad3c70c500)
[82168.612008] 000000002b259ab2: 0000000000000000 ...
[82168.612009] 00000000b371f718: ffffffffb2600202 (ret_from_fork+0x22/0x40)
[82168.612009] 000000005cb64339: 0000000000000000 ...
[82168.612017] ? _nv002593kms+0x4e/0x1610 [nvidia_modeset]
[82168.612026] ? _nv000550kms+0x365/0x3c0 [nvidia_modeset]
[82168.612033] ? nvkms_memset+0x12/0x20 [nvidia_modeset]
[82168.612040] ? _nv002680kms+0x309/0x3c0 [nvidia_modeset]
[82168.612047] ? _nv002698kms+0x29f/0x540 [nvidia_modeset]
[82168.612048] ? schedule+0x42/0xb0
[82168.612049] ? schedule_timeout+0x10e/0x160
[82168.612050] ? __down_interruptible+0x91/0xf0
[82168.612057] ? _nv000528kms+0x71/0x80 [nvidia_modeset]
[82168.612063] ? nvkms_kthread_q_callback+0x71/0xe0 [nvidia_modeset]
[82168.612070] ? nvkms_kthread_q_callback+0x8a/0xe0 [nvidia_modeset]
[82168.612076] ? _main_loop+0x8c/0x140 [nvidia_modeset]
[82168.612077] ? kthread+0x104/0x140
[82168.612083] ? _raw_q_schedule+0x70/0x70 [nvidia_modeset]
[82168.612084] ? kthread_park+0x90/0x90
[82168.612085] ? ret_from_fork+0x22/0x40
[82168.612085] Mem-Info:
[82168.612090] active_anon:12642989 inactive_anon:589068 isolated_anon:0
active_file:2586398 inactive_file:275187 isolated_file:190
unevictable:84 dirty:23 writeback:0 unstable:0
slab_reclaimable:64674 slab_unreclaimable:101586
mapped:263518 shmem:136711 pagetables:52067 bounce:0
free:82012 free_pcp:1178 free_cma:0
[82168.612093] Node 0 active_anon:50571956kB inactive_anon:2356272kB active_file:10345592kB inactive_file:1100748kB unevictable:336kB isolated(anon):0kB isolated(file):760kB mapped:1054072kB dirty:92kB writeback:0kB shmem:546844kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 8108032kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
[82168.612094] Node 0 DMA free:15884kB min:16kB low:28kB high:40kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15996kB managed:15884kB mlocked:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[82168.612096] lowmem_reserve[]: 0 3364 64143 64143 64143
[82168.612097] Node 0 DMA32 free:246644kB min:3540kB low:6984kB high:10428kB active_anon:958300kB inactive_anon:0kB active_file:2408320kB inactive_file:212kB unevictable:0kB writepending:0kB present:3616108kB managed:3615528kB mlocked:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[82168.612100] lowmem_reserve[]: 0 0 60779 60779 60779
[82168.612101] Node 0 Normal free:65520kB min:64024kB low:126260kB high:188496kB active_anon:49615840kB inactive_anon:2354348kB active_file:7936428kB inactive_file:1100804kB unevictable:336kB writepending:0kB present:63425536kB managed:62246504kB mlocked:336kB kernel_stack:33168kB pagetables:208268kB bounce:0kB free_pcp:4712kB local_pcp:904kB free_cma:0kB
[82168.612102] lowmem_reserve[]: 0 0 0 0 0
[82168.612103] Node 0 DMA: 1*4kB (U) 1*8kB (U) 0*16kB 0*32kB 2*64kB (U) 1*128kB (U) 1*256kB (U) 0*512kB 1*1024kB (U) 1*2048kB (M) 3*4096kB (M) = 15884kB
[82168.612107] Node 0 DMA32: 47*4kB (UM) 43*8kB (UM) 34*16kB (UM) 26*32kB (UM) 18*64kB (UM) 3*128kB (UM) 2*256kB (UM) 2*512kB (UM) 2*1024kB (UM) 1*2048kB (M) 58*4096kB (M) = 246644kB
[82168.612111] Node 0 Normal: 854*4kB (MEH) 2331*8kB (UMEH) 888*16kB (UMEH) 801*32kB (UMEH) 83*64kB (UME) 2*128kB (UM) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 67472kB
[82168.612116] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB
[82168.612117] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
[82168.612117] 477403 total pagecache pages
[82168.612118] 931 pages in swap cache
[82168.612119] Swap cache stats: add 11462, delete 10529, find 61/277
[82168.612119] Free swap = 951292kB
[82168.612119] Total swap = 999420kB
[82168.612119] 16764410 pages RAM
[82168.612120] 0 pages HighMem/MovableOnly
[82168.612120] 294931 pages reserved
[82168.612120] 0 pages cma reserved
[82168.612120] 0 pages hwpoisoned
[82172.112001] server invoked oom-killer: gfp_mask=0x100dca(GFP_HIGHUSER_MOVABLE|__GFP_ZERO), order=0, oom_score_adj=0
[82172.112004] CPU: 1 PID: 238880 Comm: server Tainted: P OE 5.4.0-57-generic #63-Ubuntu
[82172.112004] Hardware name: Gigabyte Technology Co., Ltd. X570 AORUS ELITE/X570 AORUS ELITE, BIOS F11 12/06/2019
[82172.112005] Call Trace:
[82172.112012] dump_stack+0x6d/0x9a
[82172.112015] dump_header+0x4f/0x1eb
[82172.112016] oom_kill_process.cold+0xb/0x10
[82172.112017] out_of_memory.part.0+0x1df/0x3d0
[82172.112018] out_of_memory+0x6d/0xd0
[82172.112020] __alloc_pages_slowpath+0xd5e/0xe50
[82172.112022] __alloc_pages_nodemask+0x2d0/0x320
[82172.112023] alloc_pages_vma+0x7f/0x200
[82172.112025] wp_page_copy+0x45b/0xa00
[82172.112026] do_wp_page+0x94/0x6a0
[82172.112029] ? __switch_to_asm+0x40/0x70
[82172.112030] ? __switch_to_asm+0x34/0x70
[82172.112031] __handle_mm_fault+0x771/0x7a0
[82172.112032] handle_mm_fault+0xca/0x200
[82172.112034] do_user_addr_fault+0x1f9/0x450
[82172.112035] __do_page_fault+0x58/0x90
[82172.112036] do_page_fault+0x2c/0xe0
[82172.112037] page_fault+0x34/0x40
[82172.112039] RIP: 0033:0xfffba0
[82172.112042] Code: Bad RIP value.
[82172.112043] RSP: 002b:000000c6b22d8be8 EFLAGS: 00010246
[82172.112044] RAX: 0000000000000000 RBX: 0000000002be4920 RCX: 0000000000000010
[82172.112045] RDX: 0000000000000020 RSI: 000000c853506900 RDI: 0000000000010000
[82172.112045] RBP: 000000c6b22d8c80 R08: 000000000000e3f4 R09: 000000c6b4026ed0
[82172.112045] R10: 0000000000000010 R11: 0000000000000000 R12: 000000c853506908
[82172.112046] R13: 000000c853506948 R14: 0000000000000092 R15: 000000cc34989010
[82172.112047] Mem-Info:
[82172.112050] active_anon:15428468 inactive_anon:647181 isolated_anon:0
active_file:746 inactive_file:313 isolated_file:14
unevictable:84 dirty:2 writeback:15330 unstable:0
slab_reclaimable:52951 slab_unreclaimable:112621
mapped:113302 shmem:100218 pagetables:53796 bounce:0
free:81549 free_pcp:1527 free_cma:0
[82172.112052] Node 0 active_anon:61713872kB inactive_anon:2588724kB active_file:2984kB inactive_file:1252kB unevictable:336kB isolated(anon):0kB isolated(file):56kB mapped:453208kB dirty:8kB writeback:61320kB shmem:400872kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 5079040kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
[82172.112053] Node 0 DMA free:15884kB min:16kB low:28kB high:40kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15996kB managed:15884kB mlocked:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[82172.112055] lowmem_reserve[]: 0 3364 64143 64143 64143
[82172.112056] Node 0 DMA32 free:246484kB min:3540kB low:6984kB high:10428kB active_anon:3366832kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:3616108kB managed:3615528kB mlocked:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[82172.112058] lowmem_reserve[]: 0 0 60779 60779 60779
[82172.112059] Node 0 Normal free:63828kB min:64024kB low:126260kB high:188496kB active_anon:58347948kB inactive_anon:2590328kB active_file:2672kB inactive_file:3184kB unevictable:336kB writepending:61776kB present:63425536kB managed:62246504kB mlocked:336kB kernel_stack:33472kB pagetables:215184kB bounce:0kB free_pcp:6108kB local_pcp:328kB free_cma:0kB
[82172.112061] lowmem_reserve[]: 0 0 0 0 0
[82172.112062] Node 0 DMA: 1*4kB (U) 1*8kB (U) 0*16kB 0*32kB 2*64kB (U) 1*128kB (U) 1*256kB (U) 0*512kB 1*1024kB (U) 1*2048kB (M) 3*4096kB (M) = 15884kB
[82172.112066] Node 0 DMA32: 47*4kB (UM) 43*8kB (UM) 34*16kB (UM) 29*32kB (UM) 18*64kB (UM) 3*128kB (UM) 1*256kB (M) 2*512kB (UM) 2*1024kB (UM) 1*2048kB (M) 58*4096kB (M) = 246484kB
[82172.112069] Node 0 Normal: 4237*4kB (UMEH) 3273*8kB (UMEH) 887*16kB (UMEH) 181*32kB (UMEH) 1*64kB (M) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 63180kB
[82172.112074] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB
[82172.112074] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
[82172.112075] 119516 total pagecache pages
[82172.112075] 17745 pages in swap cache
[82172.112076] Swap cache stats: add 250622, delete 232951, find 245/560
[82172.112076] Free swap = 0kB
[82172.112076] Total swap = 999420kB
[82172.112077] 16764410 pages RAM
[82172.112077] 0 pages HighMem/MovableOnly
[82172.112077] 294931 pages reserved
[82172.112078] 0 pages cma reserved
[82172.112078] 0 pages hwpoisoned
[82172.112078] Tasks state (memory values in pages):
[82172.112078] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
[82172.112083] [ 741] 0 741 71276 2 573440 449 -250 systemd-journal
[82172.112085] [ 772] 0 772 6025 0 73728 922 -1000 systemd-udevd
[82172.112086] [ 1109] 101 1109 6122 1 81920 1153 0 systemd-resolve
[82172.112088] [ 1110] 102 1110 22612 0 86016 239 0 systemd-timesyn
[82172.112089] [ 1138] 0 1138 59573 0 98304 271 0 accounts-daemon
[82172.112090] [ 1139] 0 1139 635 7 49152 39 0 acpid
[82172.112091] [ 1143] 115 1143 2132 0 53248 121 0 avahi-daemon
[82172.112092] [ 1145] 0 1145 2353 1 53248 66 0 cron
[82172.112093] [ 1149] 103 1149 2533 1 61440 745 -900 dbus-daemon
[82172.112094] [ 1152] 0 1152 83985 0 159744 776 0 NetworkManager
[82172.112095] [ 1161] 0 1161 20514 3 57344 116 0 irqbalance
[82172.112096] [ 1166] 0 1166 9830 0 114688 2069 0 networkd-dispat
[82172.112097] [ 1172] 126 1172 1297 0 53248 45 0 nvidia-persiste
[82172.112098] [ 1173] 0 1173 60275 0 106496 1131 0 polkitd
[82172.112099] [ 1178] 104 1178 56087 0 81920 662 0 rsyslogd
[82172.112100] [ 1182] 0 1182 716213 0 479232 4424 -900 snapd
[82172.112100] [ 1184] 0 1184 58898 0 81920 160 0 switcheroo-cont
[82172.112101] [ 1187] 0 1187 4240 1 73728 293 0 systemd-logind
[82172.112102] [ 1190] 0 1190 98308 1 131072 848 0 udisksd
[82172.112103] [ 1191] 0 1191 3420 0 65536 159 0 wpa_supplicant
[82172.112104] [ 1196] 115 1196 2086 0 53248 82 0 avahi-daemon
[82172.112105] [ 1254] 0 1254 60028 0 102400 453 0 ModemManager
[82172.112106] [ 1263] 0 1263 3044 1 65536 230 -1000 sshd
[82172.112107] [ 1268] 0 1268 59901 1 90112 299 0 gdm3
[82172.112108] [ 1350] 0 1350 29461 0 122880 2059 0 unattended-upgr
[82172.112109] [ 1351] 0 1351 41665 1 90112 296 0 gdm-session-wor
[82172.112110] [ 1361] 125 1361 4737 1 77824 513 0 systemd
[82172.112111] [ 1362] 125 1362 42370 8 98304 949 0 (sd-pam)
[82172.112112] [ 1367] 125 1367 220455 0 172032 1053 0 pulseaudio
[82172.112113] [ 1369] 125 1369 127825 0 176128 2104 0 tracker-miner-f
[82172.112114] [ 1370] 125 1370 41003 1 73728 172 0 gdm-x-session
[82172.112115] [ 1372] 125 1372 45223 2153 241664 3851 0 Xorg
[82172.112116] [ 1375] 125 1375 1847 1 53248 147 0 dbus-daemon
[82172.112117] [ 1376] 111 1376 38233 0 61440 72 0 rtkit-daemon
[82172.112118] [ 1384] 125 1384 59926 1 94208 231 0 gvfsd
[82172.112119] [ 1399] 125 1399 78200 0 98304 224 0 gvfsd-fuse
[82172.112120] [ 1405] 125 1405 96946 0 110592 521 0 gvfs-udisks2-vo
[82172.112121] [ 1411] 125 1411 59555 1 98304 252 0 gvfs-gphoto2-vo
[82172.112122] [ 1415] 125 1415 58967 0 90112 189 0 gvfs-goa-volume
[82172.112123] [ 1419] 125 1419 136530 0 253952 1549 0 goa-daemon
[82172.112124] [ 1432] 125 1432 78687 0 110592 331 0 goa-identity-se
[82172.112124] [ 1437] 125 1437 58954 0 86016 197 0 gvfs-mtp-volume
[82172.112125] [ 1442] 125 1442 79180 0 106496 277 0 gvfs-afc-volume
[82172.112127] [ 1447] 0 1447 63106 0 114688 422 0 upowerd
[82172.112127] [ 1533] 125 1533 1323 0 45056 49 0 dbus-run-sessio
[82172.112128] [ 1534] 125 1534 1882 1 49152 203 0 dbus-daemon
[82172.112129] [ 1535] 125 1535 102575 1 143360 597 0 gnome-session-b
[82172.112130] [ 1538] 125 1538 76344 0 90112 200 0 at-spi-bus-laun
[82172.112131] [ 1543] 125 1543 1777 0 53248 110 0 dbus-daemon
[82172.112132] [ 1564] 125 1564 1029702 2366 884736 19157 0 gnome-shell
[82172.112133] [ 1580] 125 1580 77730 1 94208 359 0 ibus-daemon
[82172.112134] [ 1583] 125 1583 40674 0 69632 171 0 ibus-memconf
[82172.112135] [ 1586] 125 1586 46993 1 126976 475 0 ibus-x11
[82172.112136] [ 1588] 125 1588 59091 0 86016 177 0 ibus-portal
[82172.112137] [ 1598] 125 1598 40694 0 81920 203 0 at-spi2-registr
[82172.112138] [ 1602] 125 1602 58897 0 90112 155 0 xdg-permission-
[82172.112139] [ 1608] 122 1608 71955 0 143360 1451 0 geoclue
[82172.112140] [ 1617] 125 1617 732543 0 262144 1370 0 gjs
[82172.112141] [ 1631] 125 1631 116160 0 131072 385 0 gsd-sharing
[82172.112142] [ 1633] 125 1633 83759 0 147456 547 0 gsd-wacom
[82172.112143] [ 1634] 125 1634 126452 1 192512 707 0 gsd-color
[82172.112144] [ 1635] 125 1635 83854 0 155648 542 0 gsd-keyboard
[82172.112145] [ 1636] 125 1636 62055 1 118784 372 0 gsd-print-notif
[82172.112146] [ 1637] 125 1637 114273 0 110592 228 0 gsd-rfkill
[82172.112147] [ 1639] 125 1639 78787 1 114688 266 0 gsd-smartcard
[82172.112148] [ 1642] 125 1642 93402 0 167936 513 0 gsd-datetime
[82172.112149] [ 1644] 125 1644 169606 0 184320 730 0 gsd-media-keys
[82172.112150] [ 1647] 125 1647 58875 1 86016 168 0 gsd-screensaver
[82172.112151] [ 1649] 125 1649 40672 0 81920 187 0 ibus-engine-sim
[82172.112152] [ 1651] 125 1651 79835 0 122880 292 0 gsd-sound
[82172.112153] [ 1653] 125 1653 77412 0 106496 186 0 gsd-a11y-settin
[82172.112154] [ 1655] 125 1655 77930 0 110592 217 0 gsd-housekeepin
[82172.112155] [ 1659] 125 1659 102586 0 151552 646 0 gsd-power
[82172.112156] [ 1711] 121 1711 61589 0 110592 1340 0 colord
[82172.112157] [ 1737] 125 1737 85546 1 147456 479 0 gsd-printer
[82172.112158] [ 1756] 120 1756 63280 1 122880 510 0 whoopsie
[82172.112159] [ 1758] 116 1758 2814 0 69632 120 0 kerneloops
[82172.112160] [ 1764] 116 1764 2814 0 61440 118 0 kerneloops
[82172.112161] [ 1801] 0 1801 97090 1 118784 489 0 gdm-session-wor
[82172.112162] [ 1810] 1000 1810 4862 295 73728 344 0 systemd
[82172.112163] [ 1811] 1000 1811 42370 20 98304 956 0 (sd-pam)
[82172.112164] [ 1816] 1000 1816 452784 909 233472 472 0 pulseaudio
[82172.112165] [ 1818] 1000 1818 127919 1 184320 2126 0 tracker-miner-f
[82172.112166] [ 1822] 1000 1822 2136 376 53248 63 0 dbus-daemon
[82172.112167] [ 1826] 1000 1826 133803 0 122880 391 0 gnome-keyring-d
[82172.112168] [ 1841] 1000 1841 59926 1 94208 242 0 gvfsd
[82172.112168] [ 1846] 1000 1846 94584 0 90112 223 0 gvfsd-fuse
[82172.112170] [ 1853] 1000 1853 96992 281 122880 199 0 gvfs-udisks2-vo
[82172.112170] [ 1859] 1000 1859 59554 0 94208 249 0 gvfs-gphoto2-vo
[82172.112171] [ 1864] 1000 1864 59122 0 90112 249 0 gvfs-goa-volume
[82172.112172] [ 1868] 1000 1868 137414 1851 299008 4282 0 goa-daemon
[82172.112174] [ 1877] 1000 1877 78687 0 102400 281 0 goa-identity-se
[82172.112175] [ 1883] 1000 1883 58954 0 90112 199 0 gvfs-mtp-volume
[82172.112175] [ 1887] 1000 1887 79180 0 110592 279 0 gvfs-afc-volume
[82172.112176] [ 1903] 1000 1903 41003 1 81920 172 0 gdm-x-session
[82172.112177] [ 1905] 1000 1905 49007 2268 294912 6370 0 Xorg
[82172.112178] [ 1914] 1000 1914 47105 0 122880 448 0 gnome-session-b
[82172.112179] [ 1981] 1000 1981 1508 0 49152 114 0 ssh-agent
[82172.112181] [ 1998] 1000 1998 76391 0 90112 199 0 at-spi-bus-laun
[82172.112182] [ 2003] 1000 2003 1843 19 49152 97 0 dbus-daemon
[82172.112183] [ 2010] 1000 2010 22514 0 73728 113 0 gnome-session-c
[82172.112183] [ 2017] 1000 2017 102697 301 159744 367 0 gnome-session-b
[82172.112184] [ 2031] 1000 2031 1347171 231547 3317760 43356 0 gnome-shell
[82172.112185] [ 2055] 1000 2055 77736 48 94208 311 0 ibus-daemon
[82172.112186] [ 2059] 1000 2059 40674 0 77824 186 0 ibus-memconf
[82172.112187] [ 2060] 1000 2060 68950 1207 167936 2170 0 ibus-extension-
[82172.112188] [ 2062] 1000 2062 49465 982 155648 1463 0 ibus-x11
[82172.112189] [ 2065] 1000 2065 59454 394 94208 167 0 ibus-portal
[82172.112190] [ 2076] 1000 2076 40694 66 86016 95 0 at-spi2-registr
[82172.112191] [ 2080] 1000 2080 58897 0 94208 153 0 xdg-permission-
[82172.112192] [ 2082] 1000 2082 145305 0 196608 830 0 gnome-shell-cal
[82172.112193] [ 2093] 1000 2093 268500 1 282624 2126 0 evolution-sourc
[82172.112194] [ 2099] 1000 2099 39251 161 77824 154 0 dconf-service
[82172.112195] [ 2102] 1000 2102 40585 0 86016 174 0 gvfsd-metadata
[82172.112196] [ 2108] 1000 2108 209707 0 262144 1158 0 evolution-calen
[82172.112197] [ 2119] 1000 2119 186766 0 262144 1038 0 evolution-addre
[82172.112198] [ 2134] 1000 2134 732568 65 262144 1260 0 gjs
[82172.112199] [ 2148] 1000 2148 78487 0 106496 336 0 gvfsd-trash
[82172.112200] [ 2159] 1000 2159 77451 0 98304 169 0 gsd-a11y-settin
[82172.112201] [ 2160] 1000 2160 128806 951 225280 1672 0 gsd-color
[82172.112202] [ 2162] 1000 2162 93441 0 159744 506 0 gsd-datetime
[82172.112203] [ 2164] 1000 2164 77968 33 102400 168 0 gsd-housekeepin
[82172.112203] [ 2166] 1000 2166 86510 832 167936 1653 0 gsd-keyboard
[82172.112204] [ 2168] 1000 2168 172096 865 204800 1754 0 gsd-media-keys
[82172.112205] [ 2170] 1000 2170 105087 908 180224 1641 0 gsd-power
[82172.112206] [ 2171] 1000 2171 62058 1 118784 363 0 gsd-print-notif
[82172.112207] [ 2174] 1000 2174 114273 0 110592 213 0 gsd-rfkill
[82172.112208] [ 2177] 1000 2177 58875 0 90112 165 0 gsd-screensaver
[82172.112208] [ 2179] 1000 2179 116235 0 126976 355 0 gsd-sharing
[82172.112209] [ 2180] 1000 2180 78826 0 114688 244 0 gsd-smartcard
[82172.112210] [ 2183] 1000 2183 79874 0 114688 287 0 gsd-sound
[82172.112211] [ 2188] 1000 2188 96278 6 110592 182 0 gsd-usb-protect
[82172.112212] [ 2189] 1000 2189 67902 796 167936 1702 0 gsd-wacom
[82172.112213] [ 2190] 1000 2190 78532 0 106496 235 0 gsd-wwan
[82172.112214] [ 2193] 1000 2193 86683 939 184320 1690 0 gsd-xsettings
[82172.112215] [ 2194] 1000 2194 40672 0 77824 170 0 ibus-engine-sim
[82172.112215] [ 2233] 1000 2233 85546 1 151552 494 0 gsd-printer
[82172.112216] [ 2305] 1000 2305 181040 3490 376832 700 0 evolution-alarm
[82172.112217] [ 2308] 1000 2308 57948 228 73728 106 0 gsd-disk-utilit
[82172.112218] [ 2329] 1000 2329 323906 58794 1462272 12770 0 snap-store
[82172.112219] [ 2341] 1000 2341 114378 83 122880 70 0 xdg-document-po
[82172.112220] [ 2455] 1000 2455 231618 2570 352256 1202 0 gnome-calendar
[82172.112221] [ 2595] 0 2595 65364 1 225280 5658 -900 python3
[82172.112222] [ 3424] 1000 3424 206697 5498 294912 358 0 gnome-terminal-
[82172.112223] [ 3432] 1000 3432 2894 565 57344 11 0 bash
[82172.112224] [ 4085] 1000 4085 115935 1789 212992 834 0 update-notifier
[82172.112225] [ 4185] 1000 4185 2373 51 53248 13 0 mytmux.sh
[82172.112225] [ 4186] 1000 4186 2433 89 49152 0 0 tmux: client
[82172.112226] [ 4188] 1000 4188 2684 344 45056 24 0 tmux: server
[82172.112227] [ 4189] 1000 4189 3045 717 61440 32 0 bash
[82172.112228] [ 4208] 1000 4208 62426 8405 290816 1175 0 emacs
[82172.112229] [ 4642] 1000 4642 3144 781 69632 69 0 bash
[82172.112230] [ 4654] 1000 4654 59890 5226 262144 1779 0 emacs
[82172.112231] [ 5111] 1000 5111 178456 665 172032 116 0 ibazel
[82172.112232] [ 6994] 1000 6994 2406 90 53248 6 0 bash
[82172.112233] [ 7017] 1000 7017 28342 8433 200704 615 0 devserver-linux
[82172.112233] [ 7031] 1000 7031 3045 721 65536 28 0 bash
[82172.112234] [ 7045] 1000 7045 3142 346 61440 27 0 top
[82172.112235] [ 7547] 1000 7547 1278773 10522 1171456 1876 0 code
[82172.112236] [ 7549] 1000 7549 90041 1484 618496 346 0 code
[82172.112237] [ 7550] 1000 7550 90041 1650 630784 173 0 code
[82172.112238] [ 7573] 1000 7573 240384 51904 1757184 2201 200 code
[82172.112238] [ 7589] 1000 7589 110957 2366 708608 219 0 code
[82172.112239] [ 7968] 1000 7968 1201373 8508 1159168 600 0 code
[82172.112240] [ 57610] 1000 57610 3866621 48690 1974272 1749 0 code
[82172.112241] [ 57642] 1000 57642 1190742 21478 1069056 1219 0 code
[82172.112242] [ 57676] 1000 57676 1160067 4492 708608 177 0 code
[82172.112243] [ 57780] 1000 57780 1092193 67424 1937408 4400 0 gopls
[82172.112244] [ 64941] 1000 64941 1508 0 53248 126 0 ssh-agent
[82172.112245] [ 96463] 1000 96463 352239 48705 2134016 1731 0 chrome
[82172.112246] [ 96469] 1000 96469 2055 17 49152 0 0 cat
[82172.112247] [ 96470] 1000 96470 2055 16 57344 0 0 cat
[82172.112248] [ 96473] 1000 96473 68637 2258 450560 631 0 chrome
[82172.112249] [ 96474] 1000 96474 68637 2378 446464 510 0 chrome
[82172.112250] [ 96475] 1000 96475 2687 110 65536 35 0 nacl_helper
[82172.112251] [ 96478] 1000 96478 68637 2379 249856 511 0 chrome
[82172.112266] [ 96501] 1000 96501 632406 81673 4390912 3052 200 chrome
[82172.112267] [ 96503] 1000 96503 110211 9129 565248 483 200 chrome
[82172.112269] [ 96508] 1000 96508 89407 3898 430080 741 200 chrome
[82172.112270] [ 96528] 1000 96528 88194 6499 372736 788 200 chrome
[82172.112272] [ 96616] 1000 96616 1152295 4428 745472 666 300 chrome
[82172.112273] [ 96631] 1000 96631 1167787 10394 876544 906 300 chrome
[82172.112274] [ 96637] 1000 96637 3792304 13319 958464 1691 300 chrome
[82172.112275] [ 96652] 1000 96652 1198365 34752 1433600 4203 300 chrome
[82172.112276] [ 96669] 1000 96669 1190333 11067 1019904 2000 300 chrome
[82172.112277] [ 96676] 1000 96676 1151012 3996 712704 863 300 chrome
[82172.112278] [ 96873] 1000 96873 1179451 9509 880640 721 300 chrome
[82172.112279] [ 102693] 0 102693 7109 0 86016 431 0 cupsd
[82172.112280] [ 102695] 0 102695 45110 0 118784 434 0 cups-browsed
[82172.112281] [ 119930] 1000 119930 1151268 4347 733184 818 300 chrome
[82172.112283] [ 119949] 1000 119949 48717 2517 151552 1082 0 chrome-gnome-sh
[82172.112284] [ 185774] 0 185774 41615 0 94208 303 0 gdm-session-wor
[82172.112285] [ 226830] 0 226830 94263 0 172032 876 0 fwupd
[82172.112287] [ 230386] 1000 230386 1156391 3976 729088 490 300 chrome
[82172.112288] [ 230400] 1000 230400 1164381 10132 958464 871 300 chrome
[82172.112289] [ 230699] 1000 230699 141383 2629 425984 69 200 chrome
[82172.112290] [ 231199] 1000 231199 1158274 4679 724992 0 0 code
[82172.112291] [ 231244] 1000 231244 1153654 16406 827392 0 0 code
[82172.112292] [ 231245] 1000 231245 1165946 39248 1114112 0 0 code
[82172.112293] [ 231262] 1000 231262 1152969 8136 749568 0 0 code
[82172.112294] [ 231288] 1000 231288 7826994 101478 2400256 0 0 java
[82172.112295] [ 231766] 1000 231766 1158530 4868 700416 0 0 code
[82172.112295] [ 232396] 1000 232396 7939359 403778 5005312 0 0 java
[82172.112296] [ 232698] 1000 232698 1169511 17614 999424 466 300 chrome
[82172.112298] [ 232841] 1000 232841 1027 94 49152 0 0 bash
[82172.112299] [ 232907] 1000 232907 495311 99003 11325440 0 0 node
[82172.112300] [ 234656] 1000 234656 1027 93 45056 0 0 bash
[82172.112300] [ 234657] 1000 234657 1027 94 49152 0 0 bash
[82172.112301] [ 234788] 1000 234788 514537 118310 13848576 0 0 node
[82172.112302] [ 234790] 1000 234790 469077 69906 8372224 0 0 node
[82172.112303] [ 235635] 1000 235635 1236269 170943 2768896 465 300 chrome
[82172.112304] [ 238349] 1000 238349 15729627 13868390 120565760 0 0 server
[82172.112306] [ 241469] 1000 241469 1172202 17406 1216512 465 300 chrome
[82172.112307] [ 241538] 1000 241538 1168055 13000 978944 465 300 chrome
[82172.112308] [ 241735] 1000 241735 1197229 16464 1286144 465 300 chrome
[82172.112309] [ 241986] 1000 241986 1171840 13662 1052672 465 300 chrome
[82172.112310] [ 242146] 1000 242146 1208743 32311 1683456 465 300 chrome
[82172.112311] [ 242234] 1000 242234 1240779 46343 2252800 465 300 chrome
[82172.112312] [ 243959] 1000 243959 1215724 19723 1306624 465 300 chrome
[82172.112313] [ 244014] 1000 244014 1157719 7184 823296 466 300 chrome
[82172.112314] [ 244030] 1000 244030 1204690 13367 1097728 465 300 chrome
[82172.112315] [ 244566] 1000 244566 1169561 13274 978944 465 300 chrome
[82172.112316] [ 244733] 1000 244733 1197289 15263 1220608 465 300 chrome
[82172.112317] [ 244793] 1000 244793 1168604 11928 974848 465 300 chrome
[82172.112318] [ 245118] 1000 245118 1185164 19957 1146880 465 300 chrome
[82172.112319] [ 245146] 1000 245146 1161827 9169 897024 466 300 chrome
[82172.112320] [ 245169] 1000 245169 1157976 7564 835584 465 300 chrome
[82172.112321] [ 245218] 1000 245218 1203726 41274 1183744 466 300 chrome
[82172.112321] [ 245234] 1000 245234 1165726 40017 798720 473 200 chrome
[82172.112322] [ 245436] 1000 245436 1181680 14353 987136 465 300 chrome
[82172.112324] [ 245487] 1000 245487 1206605 42987 1388544 465 300 chrome
[82172.112325] [ 245578] 1000 245578 1145314 3204 602112 471 300 chrome
[82172.112326] [ 245667] 1000 245667 1166379 5388 765952 467 300 chrome
[82172.112327] [ 245699] 0 245699 6025 1 65536 926 0 systemd-udevd
[82172.112328] [ 245700] 0 245700 6025 1 65536 926 0 systemd-udevd
[82172.112329] [ 245701] 0 245701 6025 1 65536 926 0 systemd-udevd
[82172.112330] [ 245702] 0 245702 6025 1 65536 926 0 systemd-udevd
[82172.112331] [ 245703] 0 245703 6025 1 65536 926 0 systemd-udevd
[82172.112333] [ 245707] 0 245707 6025 1 65536 926 0 systemd-udevd
[82172.112334] [ 245708] 0 245708 6025 1 65536 926 0 systemd-udevd
[82172.112335] [ 245709] 0 245709 6025 0 65536 926 0 systemd-udevd
[82172.112337] [ 245710] 0 245710 6025 1 65536 925 0 systemd-udevd
edit: I see now that this issue may be fixed in an upcoming release .
keep happening me to , it feels happening frequently after upgrade to 20.04
[267303.757721] gnome-shell: page allocation failure: order:4, mode:0x40cc0(GFP_KERNEL|__GFP_COMP), nodemask=(null),cpuset=/,mems_allowed=0
[267303.757727] CPU: 5 PID: 2739 Comm: gnome-shell Tainted: P OE 5.4.0-54-generic #60-Ubuntu
[267303.757728] Hardware name: Gigabyte Technology Co., Ltd. Z270X-Gaming 7/Z270X-Gaming 7, BIOS F8 11/30/2017
[267303.757728] Call Trace:
[267303.757734] dump_stack+0x6d/0x9a
[267303.757737] warn_alloc.cold+0x7b/0xdf
[267303.757739] __alloc_pages_slowpath+0xe07/0xe50
[267303.757742] ? __switch_to_asm+0x34/0x70
[267303.757743] ? __switch_to_asm+0x40/0x70
[267303.757744] ? __switch_to_asm+0x40/0x70
[267303.757746] ? __switch_to_asm+0x40/0x70
[267303.757747] ? __switch_to_asm+0x34/0x70
[267303.757748] ? __switch_to_asm+0x40/0x70
[267303.757750] ? get_page_from_freelist+0x233/0x390
[267303.757752] __alloc_pages_nodemask+0x2d0/0x320
[267303.757753] alloc_pages_current+0x87/0xe0
[267303.757755] kmalloc_order+0x1f/0x80
[267303.757756] kmalloc_order_trace+0x24/0xa0
[267303.757757] __kmalloc+0x220/0x280
[267303.757759] ? remove_wait_queue+0x47/0x50
[267303.757774] nvkms_alloc+0x24/0x60 [nvidia_modeset]
[267303.757788] _nv002718kms+0x16/0x30 [nvidia_modeset]
[267303.757799] ? _nv002593kms+0x4e/0x1610 [nvidia_modeset]
[267303.757801] ? prep_new_page+0x128/0x160
[267303.757803] ? __alloc_pages_nodemask+0x173/0x320
[267303.757804] ? alloc_pages_current+0x87/0xe0
[267303.757805] ? kmalloc_order+0x63/0x80
[267303.757806] ? kmalloc_order_trace+0x24/0xa0
[267303.757815] ? _nv000746kms+0x40/0x40 [nvidia_modeset]
[267303.757816] ? __kmalloc+0x220/0x280
[267303.757825] ? _nv000746kms+0x40/0x40 [nvidia_modeset]
[267303.757841] ? _nv002691kms+0x906/0xae0 [nvidia_modeset]
[267303.757849] ? _nv000746kms+0x40/0x40 [nvidia_modeset]
[267303.757850] ? __kmalloc+0x220/0x280
[267303.757852] ? _copy_from_user+0x3e/0x60
[267303.757860] ? _nv000746kms+0x40/0x40 [nvidia_modeset]
[267303.757868] ? nvKmsIoctl+0x96/0x1d0 [nvidia_modeset]
[267303.757877] ? nvkms_ioctl_common+0x42/0x80 [nvidia_modeset]
[267303.757885] ? nvkms_ioctl+0xc4/0x100 [nvidia_modeset]
[267303.758030] ? nvidia_frontend_unlocked_ioctl+0x3b/0x50 [nvidia]
[267303.758032] ? do_vfs_ioctl+0x407/0x670
[267303.758033] ? __schedule+0x167/0x740
[267303.758036] ? recalibrate_cpu_khz+0x10/0x10
[267303.758037] ? ksys_ioctl+0x67/0x90
[267303.758038] ? schedule+0x42/0xb0
[267303.758039] ? __x64_sys_ioctl+0x1a/0x20
[267303.758041] ? do_syscall_64+0x57/0x190
[267303.758042] ? entry_SYSCALL_64_after_hwframe+0x44/0xa9
[267303.758043] Mem-Info:
[267303.758046] active_anon:4021276 inactive_anon:632341 isolated_anon:0
active_file:1595895 inactive_file:546086 isolated_file:0
unevictable:79 dirty:414 writeback:0 unstable:0
slab_reclaimable:1088860 slab_unreclaimable:112657
mapped:539492 shmem:294282 pagetables:40254 bounce:0
free:69218 free_pcp:0 free_cma:0
[267303.758048] Node 0 active_anon:16085104kB inactive_anon:2529364kB active_file:6383580kB inactive_file:2184344kB unevictable:316kB isolated(anon):0kB isolated(file):0kB mapped:2157968kB dirty:1656kB writeback:0kB shmem:1177128kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 0kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
[267303.758049] Node 0 DMA free:15896kB min:32kB low:44kB high:56kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15988kB managed:15896kB mlocked:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[267303.758051] lowmem_reserve : 0 2405 32003 32003 32003
[267303.758053] Node 0 DMA32 free:167004kB min:5076kB low:7536kB high:9996kB active_anon:735240kB inactive_anon:41952kB active_file:437572kB inactive_file:143988kB unevictable:0kB writepending:156kB present:2578544kB managed:2512404kB mlocked:0kB kernel_stack:1536kB pagetables:7184kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[267303.758055] lowmem_reserve : 0 0 29597 29597 29597
[267303.758057] Node 0 Normal free:93972kB min:62472kB low:92780kB high:123088kB active_anon:15349400kB inactive_anon:2487808kB active_file:5946008kB inactive_file:2039420kB unevictable:316kB writepending:1500kB present:30916608kB managed:30315984kB mlocked:316kB kernel_stack:43360kB pagetables:153832kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[267303.758059] lowmem_reserve : 0 0 0 0 0
[267303.758060] Node 0 DMA: 24kB (U) 2 8kB (U) 216kB (U) 1 32kB (U) 364kB (U) 2 128kB (U) 0256kB 0 512kB 11024kB (U) 1 2048kB (M) 34096kB (M) = 15896kB
[267303.758065] Node 0 DMA32: 4247 4kB (UME) 93628kB (UME) 3924 16kB (UME) 41232kB (UE) 0 64kB 0128kB 0 256kB 0512kB 0 1024kB 02048kB 0 4096kB = 167852kB
[267303.758068] Node 0 Normal: 90304kB (UMEH) 2890 8kB (UMEH) 97816kB (UMEH) 613 32kB (UEH) 264kB (H) 0 128kB 1256kB (H) 0 512kB 01024kB 0 2048kB 0*4096kB = 94888kB
[267303.758073] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB
[267303.758074] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
[267303.758075] 2361636 total pagecache pages
[267303.758079] 6042 pages in swap cache
[267303.758080] Swap cache stats: add 117149, delete 111111, find 46456/56230
[267303.758080] Free swap = 30904060kB
[267303.758081] Total swap = 31250428kB
[267303.758081] 8377785 pages RAM
[267303.758081] 0 pages HighMem/MovableOnly
[267303.758082] 166714 pages reserved
[267303.758082] 0 pages cma reserved
[267303.758083] 0 pages hwpoisoned
It looks like 460.27.04 fixed this problem for me. I haven’t seen this issue for about 5 days running this driver. Thanks!
