@aplattner is your patch included in the latest beta driver 460.27.04?
Been using the patched driver for 10 days now without any more lockups. Hoping to go back to PPA/DKMS builds.
Improved the memory allocation strategy in nvidia-modeset.ko to reduce the likelihood of out-of-memory errors, which typically manifest as āpage allocation failureā messages in the kernel log.
Yes, the beta contains the fixes for this bug. Please let me know if you still experience this problem with 460.27.04.
I am still having the same kernel null pointer freeze after an hour with 460.27.04. I am running 4 monitors and a shadowtech VM on gentoo with kernel-5.9.15. The shadowtech VM seems to be the trigger. It happens every time after the ShadowTech VM runs for about an hour. 450.80.02-r1 runs with no issues
@harrisl The NULL pointer bug is a different bug. Itās being discussed here: Bug report: 455.23.04 - Kernel Panic due to NULL pointer dereference
As for page allocation errors, Iāve been running 460.27.04 for about 5 days and havenāt seen this error.
To confirm, upgraded from patched 455 driver to 460 beta and havenāt had a lock-up in 9 days.
Confirmed here as well.
Had identical problem on Linux Mint: several crashes per day after lots of I/O. Installed beta. Did lots of I/O. No problems for a week. Thanks much for the fix.
Every 1-2 days I was having similar crashes with nvidia_modeset. After upgrading to 460.32.03-0ubuntu0.20.10.1 havenāt had a single crash. Thanks!
