After a suspend/resume cycle i2c has stopped working with the newest drivers, 465.24.02
sudo gddccontrol -v -p
gddccontrol: invalid option -- 'p'
ddcpci initing...
Starting /usr/libexec/ddccontrol/ddcpci 1 1226145835 &...
I/O warning : failed to load external entity "/root/.ddccontrol/monitorlist"
Document not parsed successfully.
Probing for available monitors...
Found PCI device (pci:07:00.0-0)
Found PCI device (pci:07:00.0-1)
Found PCI device (pci:07:00.0-2)
Device: pci:07:00.0-0
Error while reading write message answer: Bad message
Reading EDID 0x50 failed.
ddcci_open returned -2
Device: pci:07:00.0-1
Device: pci:07:00.0-2
Found I2C device (dev:/dev/i2c-8)
ioctl(): Input/output error
ioctl returned -1
Found I2C device (dev:/dev/i2c-7)
Corrupted EDID at 0x50.
Found I2C device (dev:/dev/i2c-6)
ioctl returned -1
Found I2C device (dev:/dev/i2c-5)
ioctl returned -1
Found I2C device (dev:/dev/i2c-4)
ioctl returned -1
Found I2C device (dev:/dev/i2c-3)
ioctl(): Operation not supported
ioctl returned -1
Found I2C device (dev:/dev/i2c-2)
ioctl returned -1
Found I2C device (dev:/dev/i2c-0)
ioctl returned -1
Found I2C device (dev:/dev/i2c-1)
ioctl(): Connection timed out
ioctl returned -1
ddcpci being released...
==>ddcpci is quitting.
In dmesg
you can see:
nvidia-gpu 0000:07:00.3: i2c timeout error e0000000
(to be honest it occurs on boot as well but it doesn’t prevent i2c from working)
The last drivers where everything worked: 460.67
My GPU is: GTX 1660 Ti
My monitor is LG 24MP55 connected via an HDMI interface.
