46tok/s with RedHatAI/gemma-4-26B-A4B-it-NVFP4
| model                             |            test |             t/s |     peak t/s |        ttfr (ms) |     est_ppt (ms) |    e2e_ttft (ms) |
| RedHatAI/gemma-4-26B-A4B-it-NVFP4 |          pp2048 | 7296.94 ± 11.07 |              |    332.87 ± 0.43 |    280.80 ± 0.43 |    332.95 ± 0.42 |
| RedHatAI/gemma-4-26B-A4B-it-NVFP4 |            tg32 |    47.49 ± 0.02 | 49.03 ± 0.02 |                  |                  |                  |
| RedHatAI/gemma-4-26B-A4B-it-NVFP4 |  pp2048 @ d4096 |  6295.58 ± 7.45 |              |   1083.91 ± 5.75 |   1031.84 ± 5.75 |   1083.99 ± 5.75 |
| RedHatAI/gemma-4-26B-A4B-it-NVFP4 |    tg32 @ d4096 |    46.93 ± 0.06 | 48.45 ± 0.06 |                  |                  |                  |
| RedHatAI/gemma-4-26B-A4B-it-NVFP4 |  pp2048 @ d8192 |  5383.59 ± 5.05 |              |   2081.20 ± 2.45 |   2029.13 ± 2.45 |   2081.30 ± 2.44 |
| RedHatAI/gemma-4-26B-A4B-it-NVFP4 |    tg32 @ d8192 |    46.17 ± 0.07 | 47.66 ± 0.07 |                  |                  |                  |
| RedHatAI/gemma-4-26B-A4B-it-NVFP4 | pp2048 @ d16384 |  4081.53 ± 9.25 |              |  4935.81 ± 19.58 |  4883.74 ± 19.58 |  4935.89 ± 19.58 |
| RedHatAI/gemma-4-26B-A4B-it-NVFP4 |   tg32 @ d16384 |    45.27 ± 0.15 | 46.74 ± 0.16 |                  |                  |                  |
| RedHatAI/gemma-4-26B-A4B-it-NVFP4 | pp2048 @ d32768 |  2627.16 ± 5.73 |              | 14377.94 ± 67.04 | 14325.87 ± 67.04 | 14378.03 ± 67.04 |
| RedHatAI/gemma-4-26B-A4B-it-NVFP4 |   tg32 @ d32768 |    43.60 ± 0.33 | 45.02 ± 0.34 |                  |                  |                  |
llama-benchy (0.3.5)
date: 2026-04-08 22:05:18 | latency mode: generation
Steps:
1.
git clone https://github.com/eugr/spark-vllm-docker.git
cd spark-vllm-docker
./build-and-copy.sh --tf5 --apply-vllm-pr 39045
  1. Modify ./spark-vllm-docker/recipes/gemma4-26b-a4b.yaml
  2. # Recipe: Gemma4-26B-A4B
    # Gemma4-26B-A4B model in online FP8 quantization
    recipe_version: "1"
    description: vLLM serving Gemma4-26B-A4B
    # HuggingFace model to download (optional, for --download-model)
    model: RedHatAI/gemma-4-26B-A4B-it-NVFP4
    # Only cluster is supported
    cluster_only: false
    solo_only: false
    # Container image to use
    container: vllm-node-tf5
    build_args:
      - --tf5
    # Mods
    mods:
      - mods/fix-gemma4-tool-parser
    # Default settings (can be overridden via CLI)
    defaults:
      port: 8000
      host: 0.0.0.0
      tensor_parallel: 2
      gpu_memory_utilization: 0.7
      max_model_len: 262144
      max_num_batched_tokens: 8192
    # Environment variables
    env: {}
    # The vLLM serve command template
    command: |
      vllm serve RedHatAI/gemma-4-26B-A4B-it-NVFP4  \
        --max-model-len {max_model_len} \
        --gpu-memory-utilization {gpu_memory_utilization} \
        --port {port} \
        --host {host} \
        --load-format fastsafetensors \
        --enable-prefix-caching \
        --enable-auto-tool-choice \
        --tool-call-parser gemma4 \
        --reasoning-parser gemma4 \
        --kv-cache-dtype fp8 \
        --max-num-batched-tokens {max_num_batched_tokens} \
        -tp {tensor_parallel} --distributed-executor-backend ray
  3. ./spark-vllm-docker/run-recipe.sh gemma4nvfp4 –solo -d
Hey, feel free to submit your benchmark to https://spark-arena.com
we don’t have any gemma-4-26B-A4B-it-NVFP4 contributions yet!
Hi @raphael.amorim The leaderboard should have evals too. For example, some of the quantizations i’ve seen for this particular model have very noisy reasoning traces - that implies poor quantizations. There is no point in being fast if the output is unsatisfactory.
Is this one of them>?
I don’t have linkedin account sorry
We’re still restricting anonymous contributions, but we will get there. We’re putting the tools in place on Sparkarena and Sparkrun for that
That would be huge, only then could we see how true some of the claimed improvements here on the forum actually are, please implement this. @raphael.amorim - I don’t even have a Spark, getting mine in 2 days and can’t wait to try, would be very willing to help if I can and if I may with trying out different versions of models, if Eval gets implemented. :) Thanks for the great work.
That’s in the works @vgoklani, but those take a long time to run and we only have a few Sparks. After we standardize the execution models. We’re going to add the functionality for users to run locally and distribute as well through Sparkrun, so users an update their existing and new recipes with intelligence benchmarks as well.
Looks like vllm-pr 39045 was merged in yesterday, so --apply-vllm-pr 39045 is no longer needed if you update vllm
Applying --apply-vllm-pr 39045 causes the build to fail:
0.713 error: patch failed: vllm/model_executor/models/gemma4.py:1248
0.713 error: vllm/model_executor/models/gemma4.py: patch does not apply
ERROR: failed to build: failed to solve: process “/bin/sh -c if [ -n "$VLLM_PRS" ]; then echo "Applying PRs: $VLLM_PRS"; for pr in $VLLM_PRS; do echo "Fetching and applying PR #$pr…"; curl -fL "Sign in to GitHub · GitHub” | git apply -v; done; fi" did not complete successfully: exit code: 1
But some other error is causing it to not load :-(
Thanks @raphael.amorim looking forward to it.
I’m using spark-vllm-docker last build.
I am as well I did this 1st:
cd /spark-vllm-docker
git pull
rm wheels/.whl wheels/.-commit
./build-and-copy.sh -t vllm-node-tf5 --rebuild-vllm
1st run ./run-recipe.sh gemma4-26b-a4b-nvfp4 --solo --setup
2nd run ./run-recipe.sh gemma4-26b-a4b-nvfp4 --solo
Then crash.
@eugr can you give this one a try, or did I build it incorrectly?
spark-vllm-docker not updated new vllm.
See previous message,
See previous message about vllm-pr 39045 now merged and crashes vllm-builder
=> ERROR [vllm-builder 4/8] RUN if [ -n “39045” ]; then echo "Applying PRs: 39 0.8s
[vllm-builder 4/8] RUN if [ -n “39045” ]; then echo “Applying PRs: 39045”; for pr in 39045; do echo “Fetching and applying PR #$pr…”; curl -fL “https://github.com/vllm-project/vllm/pull/${pr}.diff” | git apply -v; done; fi:
Maybe re-clone the repo
–tf5 not equal -t vllm-node-tf5
There were some issues with the build pipeline when I was traveling, it’s been fixed now.
BTW, --tf5 without specifying the image name will now produce vllm-node-tf5 by default ;)
COOL ! @eugr are you working on the gemma4 mtp addon?
Yes, I plan to test that one.
