I have a problem running a 770GTX 4GB on 1440p@144 that still isn’t solved… I can only used it @120 don’t know why… thread is somewhere in this forum too.
@aritger Thanks for the help! I will try these suggestions out when I can afford to be down for a bit to test them.
I have a major software project going on right now and I can’t afford any downtime for now.
Really appreciate the help though, it sounds like this might actually work.
Fantastic Andy - typing this at 4k@60Hz right now via the LG EDID. I had tried the currentmetamode assignments once before during my testing when I found the additional modes being detected - for me the _0 modes do absolutely nothing (no flickers, no trying, no errors) and the other two modes go to a invalid mode for the TV.
The LG EDID seems to work fine - only downside is losing the 120Hz 1080P mode but that doesn’t bother me a bit.
Thanks for testing that. I understand the driver bug that causes the _0 modes (the YUV420 modes) to not do anything, but I’m surprised the other two (the RGB444/YUV422/YUV422 modes) cause an invalid mode for the TV. I’ll try to hunt down a similar monitor to debug this.
FYI, NVIDIA bug 1804330 is tracking this issue.
I think this is a screw up on Vizio’s part, because that particular TV doesn’t actually support anything other than YUV420 at 4K 60Hz. Not sure why the other modes are there at all. I guess the Windows drivers are more robust and cover the weird corner cases like these.
If it would make it easier for you guys to have the TV to work/test with and you are located in the SF Bay Area, I can drop it off at one of your offices. I’m in no rush to get it back any time soon and would be glad to help out!
Thanks for the support! :)
OK I am stuck here. I have a VIZIO e48u. I have an older K610m video card that supports upto 3840. It’s a 4K tv and works great on windows. On Ubuntu 16.04 I have tried the above steps and switched out the edid.bin with the LG ones. I still do not get an option to chose a 4k resolution 4096 or 3840. I have tried to add the mode using xrandr and keep getting errors.
sudo xrandr --newmode "3840x2160_60.00" 593.41 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync
sudo xrandr --addmode DP-0 3840x2160_60.00
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 18 (RRAddOutputMode)
Serial number of failed request: 45
Current serial number in output stream: 46
I don’t ever get the possibility of even trying a 4K resolution because it is never an option for me to chose. Any help here would be great.
I think we have fixed this issue and fix will be available in next r370 driver .
Thanks @sandipt! Looking forward to that release for sure! Been a long time since I’ve been stuck on an old kernel and old nvidia driver. :)
Ownaginatious: Thanks for the offer. I’ve tested and confirmed that RGB444 4k @ 60Hz works on other TVs, so I’m content to blame the Vizio TV for the RGB444 problem. As sandipt said, the YUV420 problem should be fixed in our upcoming 370.xx release.
jdtommy: you shouldn’t need to add new modes. Are there any 4k @ 60Hz modes listed in xrandr -q? You should be able to do xrandr --output DP-0 --mode 3840x2160 --rate 60 (or … --rate 59.94 or similar).
If you’re not getting any 4k@60Hz modes listed in xrandr -q, please set the ModeDebug X config option, restart X, and attach the resulting X log.
Thanks for the reply @aritger. Here is my output for ‘xrandr -q’ and the X log after enabling the ModeDebug. I have 2 monitors, the laptop display and the Vizio. I switched the Vizio to DP-1 to see if it would make any differnce.
xradr -q
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 16384 x 16384
VGA-0 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 1054mm x 593mm
1920x1080 60.00*+ 59.94 29.97 23.97 60.00
1280x720 59.94
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32
720x480 59.94 60.05
640x480 75.00 59.94 59.93
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 60.01*+ 40.00
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
DP-6 disconnected (normal left inverted right x axis y axis)
X Log
[ 21.514]
X.Org X Server 1.18.3
Release Date: 2016-04-04
[ 21.514] X Protocol Version 11, Revision 0
[ 21.514] Build Operating System: Linux 3.13.0-86-generic x86_64 Ubuntu
[ 21.514] Current Operating System: Linux 4.4.0-36-generic #55-Ubuntu SMP Thu Aug 11 18:01:55 UTC 2016 x86_64
[ 21.514] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-36-generic root=UUID=714608d1-5ffb-46e7-8d30-6ddcf5b55d30 ro quiet splash
[ 21.514] Build Date: 18 May 2016 01:07:07AM
[ 21.514] xorg-server 2:1.18.3-1ubuntu2.2 (For technical support please see http://www.ubuntu.com/support)
[ 21.514] Current version of pixman: 0.33.6
[ 21.514] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 21.514] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 21.514] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Sep 7 19:33:26 2016
[ 21.515] (==) Using config file: "/etc/X11/xorg.conf"
[ 21.515] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 21.519] (==) ServerLayout "Layout0"
[ 21.519] (**) |-->Screen "Screen0" (0)
[ 21.519] (**) | |-->Monitor "Monitor0"
[ 21.520] (**) | |-->Device "Device0"
[ 21.520] (**) | |-->GPUDevice "Device1"
[ 21.520] (**) |-->Input Device "Keyboard0"
[ 21.520] (**) |-->Input Device "Mouse0"
[ 21.520] (**) Option "Xinerama" "0"
[ 21.520] (==) Automatically adding devices
[ 21.520] (==) Automatically enabling devices
[ 21.520] (==) Automatically adding GPU devices
[ 21.520] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 21.520] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 21.520] Entry deleted from font path.
[ 21.520] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 21.520] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 21.520] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 21.520] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 21.520] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 21.520] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 21.520] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 21.520] (WW) Disabling Keyboard0
[ 21.520] (WW) Disabling Mouse0
[ 21.520] (II) Loader magic: 0x55ed7df52da0
[ 21.520] (II) Module ABI versions:
[ 21.520] X.Org ANSI C Emulation: 0.4
[ 21.520] X.Org Video Driver: 20.0
[ 21.520] X.Org XInput driver : 22.1
[ 21.520] X.Org Server Extension : 9.0
[ 21.521] (++) using VT number 7
[ 21.521] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 21.521] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 21.522] (--) PCI:*(0:1:0:0) 10de:12b9:103c:197b rev 161, Mem @ 0xc8000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x????????/524288
[ 21.522] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[ 21.522] (II) "glx" will be loaded by default.
[ 21.522] (II) LoadModule: "glx"
[ 21.522] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 21.582] (II) Module glx: vendor="NVIDIA Corporation"
[ 21.582] compiled for 4.0.2, module version = 1.0.0
[ 21.582] Module class: X.Org Server Extension
[ 21.582] (II) NVIDIA GLX Module 361.45.18 Tue Jun 21 17:51:54 PDT 2016
[ 21.582] (II) LoadModule: "nvidia"
[ 21.582] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 21.587] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 21.587] compiled for 4.0.2, module version = 1.0.0
[ 21.587] Module class: X.Org Video Driver
[ 21.587] (II) NVIDIA dlloader X Driver 361.45.18 Tue Jun 21 17:30:12 PDT 2016
[ 21.587] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 21.595] (II) Loading sub module "fb"
[ 21.595] (II) LoadModule: "fb"
[ 21.596] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 21.596] (II) Module fb: vendor="X.Org Foundation"
[ 21.596] compiled for 1.18.3, module version = 1.0.0
[ 21.596] ABI class: X.Org ANSI C Emulation, version 0.4
[ 21.596] (II) Loading sub module "wfb"
[ 21.596] (II) LoadModule: "wfb"
[ 21.597] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 21.597] (II) Module wfb: vendor="X.Org Foundation"
[ 21.597] compiled for 1.18.3, module version = 1.0.0
[ 21.597] ABI class: X.Org ANSI C Emulation, version 0.4
[ 21.597] (II) Loading sub module "ramdac"
[ 21.597] (II) LoadModule: "ramdac"
[ 21.597] (II) Module "ramdac" already built-in
[ 21.599] (EE) Screen 1 deleted because of no matching config section.
[ 21.599] (II) UnloadModule: "nvidia"
[ 21.599] (II) UnloadSubModule: "wfb"
[ 21.599] (II) UnloadSubModule: "fb"
[ 21.599] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 21.599] (==) NVIDIA(0): RGB weight 888
[ 21.599] (==) NVIDIA(0): Default visual is TrueColor
[ 21.599] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 21.600] (**) NVIDIA(0): Option "Stereo" "0"
[ 21.600] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-0"
[ 21.600] (**) NVIDIA(0): Option "SLI" "Off"
[ 21.600] (**) NVIDIA(0): Option "MultiGPU" "Off"
[ 21.600] (**) NVIDIA(0): Option "ModeDebug" "true"
[ 21.600] (**) NVIDIA(0): Option "BaseMosaic" "off"
[ 21.600] (**) NVIDIA(0): Stereo disabled by request
[ 21.600] (**) NVIDIA(0): NVIDIA SLI disabled.
[ 21.600] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[ 21.600] (**) NVIDIA(0): Option "CustomEDID" "DFP-0:/home/jarad/edid.bin"
[ 21.600] (**) NVIDIA(0): Option "MetaModes" "DP-3: nvidia-auto-select +0+0, DP-0: nvidia-auto-select +1920+0"
[ 21.600] (**) NVIDIA(0): Enabling 2D acceleration
[ 21.923] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 21.923] (--) NVIDIA(0): CRT-0
[ 21.923] (--) NVIDIA(0): DFP-0
[ 21.923] (--) NVIDIA(0): DFP-1
[ 21.923] (--) NVIDIA(0): DFP-2
[ 21.923] (--) NVIDIA(0): DFP-3 (boot)
[ 21.923] (--) NVIDIA(0): DFP-4
[ 21.923] (--) NVIDIA(0): DFP-5
[ 21.923] (--) NVIDIA(0): DFP-6
[ 21.924] (--) NVIDIA(0): CRT-0: disconnected
[ 21.924] (--) NVIDIA(0): CRT-0 Name Aliases:
[ 21.924] (--) NVIDIA(0): DPY-0
[ 21.924] (--) NVIDIA(0): VGA-0
[ 21.924] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 21.925] (--) NVIDIA(0): DFP-0: disconnected
[ 21.925] (--) NVIDIA(0): DFP-0: Internal TMDS
[ 21.925] (--) NVIDIA(0): DFP-0 Name Aliases:
[ 21.925] (--) NVIDIA(0): DPY-1
[ 21.925] (--) NVIDIA(0): DP-0
[ 21.925] (--) NVIDIA(0): DFP-0: 165.0 MHz maximum pixel clock
[ 21.984] (--) NVIDIA(0): VIZ E48u-D0 (DFP-1): connected
[ 21.984] (--) NVIDIA(0): VIZ E48u-D0 (DFP-1): Internal TMDS
[ 21.984] (--) NVIDIA(0): VIZ E48u-D0 (DFP-1) Name Aliases:
[ 21.984] (--) NVIDIA(0): DFP
[ 21.984] (--) NVIDIA(0): DFP-1
[ 21.984] (--) NVIDIA(0): DPY-2
[ 21.984] (--) NVIDIA(0): DP-1
[ 21.984] (--) NVIDIA(0): DPY-EDID-ca67a127-9959-090a-ada8-3a67d610f32c
[ 21.984] (--) NVIDIA(0): VIZ E48u-D0 (DFP-1): 165.0 MHz maximum pixel clock
[ 21.984] (--) NVIDIA(0): --- EDID for VIZ E48u-D0 (DP-1) ---
[ 21.984] (--) NVIDIA(0): EDID Version : 1.3
[ 21.984] (--) NVIDIA(0): Manufacturer : VIZ
[ 21.984] (--) NVIDIA(0): Monitor Name : VIZ E48u-D0
[ 21.984] (--) NVIDIA(0): Product ID : 0x1018
[ 21.984] (--) NVIDIA(0): 32-bit Serial Number : 0x01010101
[ 21.984] (--) NVIDIA(0): Serial Number String :
[ 21.984] (--) NVIDIA(0): Manufacture Date : 2016, week 10
[ 21.984] (--) NVIDIA(0): DPMS Capabilities : Active Off
[ 21.984] (--) NVIDIA(0): Input Type : Digital
[ 21.984] (--) NVIDIA(0): Prefer first detailed timing : Yes
[ 21.984] (--) NVIDIA(0): Supports GTF : No
[ 21.984] (--) NVIDIA(0): Maximum Image Size : 1050 mm x 590 mm
[ 21.984] (--) NVIDIA(0): Valid HSync Range : 15.0 kHz - 140.0 kHz
[ 21.984] (--) NVIDIA(0): Valid VRefresh Range : 25.0 Hz - 76.0 Hz
[ 21.984] (--) NVIDIA(0): EDID maximum pixel clock : 593.4 MHz
[ 21.984] (--) NVIDIA(0): CEA-861 extension block # : 0
[ 21.984] (--) NVIDIA(0): CEA-861 revision : 3
[ 21.984] (--) NVIDIA(0): IEEE Vendor Registration ID: 00-0c-03
[ 21.984] (--) NVIDIA(0): Supports YCbCr 4:4:4 : Yes
[ 21.984] (--) NVIDIA(0): Supports YCbCr 4:2:2 : Yes
[ 21.984] (--) NVIDIA(0): Supports Basic Audio : Yes
[ 21.984] (--) NVIDIA(0): Audio Descriptor : 0
[ 21.984] (--) NVIDIA(0): Audio Format : E-AC-3
[ 21.984] (--) NVIDIA(0): Maximum Channels : 8
[ 21.984] (--) NVIDIA(0): Sample Rates : 44KHz, 48KHz
[ 21.984] (--) NVIDIA(0): Speaker Allocation Data :
[ 21.984] (--) NVIDIA(0): Front Left + Front Right
[ 21.984] (--) NVIDIA(0): Standard Timings:
[ 21.984] (--) NVIDIA(0): 1920 x 1080 @ 60 Hz
[ 21.984] (--) NVIDIA(0): Detailed Timings:
[ 21.984] (--) NVIDIA(0): 3840 x 2160 @ 30 Hz
[ 21.984] (--) NVIDIA(0): Pixel Clock : 297.00 MHz
[ 21.984] (--) NVIDIA(0): HRes, HSyncStart : 3840, 4016
[ 21.984] (--) NVIDIA(0): HSyncEnd, HTotal : 4104, 4400
[ 21.984] (--) NVIDIA(0): VRes, VSyncStart : 2160, 2168
[ 21.984] (--) NVIDIA(0): VSyncEnd, VTotal : 2178, 2250
[ 21.984] (--) NVIDIA(0): H/V Polarity : +/+
[ 21.984] (--) NVIDIA(0): Image Size : 1054 mm x 593 mm
[ 21.984] (--) NVIDIA(0): Pixel Clock : 148.50 MHz
[ 21.984] (--) NVIDIA(0): HRes, HSyncStart : 1920, 2008
[ 21.984] (--) NVIDIA(0): HSyncEnd, HTotal : 2052, 2200
[ 21.984] (--) NVIDIA(0): VRes, VSyncStart : 1080, 1084
[ 21.984] (--) NVIDIA(0): VSyncEnd, VTotal : 1089, 1125
[ 21.984] (--) NVIDIA(0): Established Timings:
[ 21.984] (--) NVIDIA(0): 640 x 480 @ 60 Hz
[ 21.984] (--) NVIDIA(0): 640 x 480 @ 75 Hz
[ 21.984] (--) NVIDIA(0): 800 x 600 @ 60 Hz
[ 21.984] (--) NVIDIA(0): 800 x 600 @ 72 Hz
[ 21.984] (--) NVIDIA(0): 800 x 600 @ 75 Hz
[ 21.984] (--) NVIDIA(0): 1024 x 768 @ 60 Hz
[ 21.984] (--) NVIDIA(0): 1024 x 768 @ 70 Hz
[ 21.984] (--) NVIDIA(0): 1024 x 768 @ 75 Hz
[ 21.984] (--) NVIDIA(0): CEA-861B Timings:
[ 21.984] (--) NVIDIA(0): Pixel Clock : 296.70 MHz
[ 21.984] (--) NVIDIA(0): CEA Format : 95
[ 21.984] (--) NVIDIA(0): Aspect Ratio : 16:9
[ 21.984] (--) NVIDIA(0): 4096 x 2160 @ 30 Hz
[ 21.984] (--) NVIDIA(0): HRes, HSyncStart : 4096, 4184
[ 21.984] (--) NVIDIA(0): HSyncEnd, HTotal : 4272, 4400
[ 21.984] (--) NVIDIA(0): CEA Format : 100
[ 21.984] (--) NVIDIA(0): Image Size : 256 mm x 135 mm
[ 21.984] (--) NVIDIA(0): 3840 x 2160 @ 24 Hz
[ 21.984] (--) NVIDIA(0): Pixel Clock : 296.75 MHz
[ 21.984] (--) NVIDIA(0): HRes, HSyncStart : 3840, 5116
[ 21.984] (--) NVIDIA(0): HSyncEnd, HTotal : 5204, 5500
[ 21.984] (--) NVIDIA(0): CEA Format : 93
[ 21.984] (--) NVIDIA(0): 4096 x 2160 @ 24 Hz
[ 21.984] (--) NVIDIA(0): HRes, HSyncStart : 4096, 5116
[ 21.984] (--) NVIDIA(0): CEA Format : 98
[ 21.984] (--) NVIDIA(0): Pixel Clock : 148.35 MHz
[ 21.984] (--) NVIDIA(0): CEA Format : 16
[ 21.984] (--) NVIDIA(0): 1920 x 1080 @ 30 Hz
[ 21.984] (--) NVIDIA(0): Pixel Clock : 74.18 MHz
[ 21.984] (--) NVIDIA(0): CEA Format : 34
[ 21.984] (--) NVIDIA(0): 1920 x 1080 @ 24 Hz
[ 21.984] (--) NVIDIA(0): Pixel Clock : 74.16 MHz
[ 21.984] (--) NVIDIA(0): HRes, HSyncStart : 1920, 2558
[ 21.984] (--) NVIDIA(0): HSyncEnd, HTotal : 2602, 2750
[ 21.984] (--) NVIDIA(0): CEA Format : 32
[ 21.984] (--) NVIDIA(0): VSyncEnd, VTotal : 1094, 1124
[ 21.984] (--) NVIDIA(0): Interlaced : yes
[ 21.984] (--) NVIDIA(0): CEA Format : 5
[ 21.984] (--) NVIDIA(0): 1280 x 720 @ 60 Hz
[ 21.984] (--) NVIDIA(0): HRes, HSyncStart : 1280, 1390
[ 21.984] (--) NVIDIA(0): HSyncEnd, HTotal : 1430, 1650
[ 21.984] (--) NVIDIA(0): VRes, VSyncStart : 720, 725
[ 21.984] (--) NVIDIA(0): VSyncEnd, VTotal : 730, 750
[ 21.984] (--) NVIDIA(0): CEA Format : 4
[ 21.984] (--) NVIDIA(0): 720 x 480 @ 60 Hz
[ 21.984] (--) NVIDIA(0): Pixel Clock : 27.00 MHz
[ 21.984] (--) NVIDIA(0): HRes, HSyncStart : 1440, 1478
[ 21.984] (--) NVIDIA(0): HSyncEnd, HTotal : 1602, 1716
[ 21.984] (--) NVIDIA(0): VRes, VSyncStart : 480, 488
[ 21.984] (--) NVIDIA(0): VSyncEnd, VTotal : 494, 524
[ 21.984] (--) NVIDIA(0): H/V Polarity : -/-
[ 21.984] (--) NVIDIA(0): CEA Format : 7
[ 21.984] (--) NVIDIA(0): CEA Format : 6
[ 21.984] (--) NVIDIA(0): Aspect Ratio : 4:3
[ 21.984] (--) NVIDIA(0): HRes, HSyncStart : 720, 736
[ 21.984] (--) NVIDIA(0): HSyncEnd, HTotal : 798, 858
[ 21.984] (--) NVIDIA(0): VRes, VSyncStart : 480, 489
[ 21.984] (--) NVIDIA(0): VSyncEnd, VTotal : 495, 525
[ 21.984] (--) NVIDIA(0): CEA Format : 2
[ 21.984] (--) NVIDIA(0): Pixel Clock : 25.17 MHz
[ 21.984] (--) NVIDIA(0): HRes, HSyncStart : 640, 656
[ 21.984] (--) NVIDIA(0): HSyncEnd, HTotal : 752, 800
[ 21.984] (--) NVIDIA(0): VRes, VSyncStart : 480, 490
[ 21.984] (--) NVIDIA(0): VSyncEnd, VTotal : 492, 525
[ 21.984] (--) NVIDIA(0): CEA Format : 0
[ 21.984] (--) NVIDIA(0): 3840 x 2160 @ 60 Hz
[ 21.984] (--) NVIDIA(0): Pixel Clock : 593.41 MHz
[ 21.984] (--) NVIDIA(0): CEA Format : 97
[ 21.984] (--) NVIDIA(0): 4096 x 2160 @ 60 Hz
[ 21.984] (--) NVIDIA(0): CEA Format : 102
[ 21.984] (--) NVIDIA(0): HDMI Extended Resolution Timings:
[ 21.984] (--) NVIDIA(0): --- End of EDID for VIZ E48u-D0 (DP-1) ---
[ 21.984] (--) NVIDIA(0): Raw EDID bytes:
[ 21.984] (--) NVIDIA(0): 00 ff ff ff ff ff ff 00 59 3a 18 10 01 01 01 01
[ 21.984] (--) NVIDIA(0): 0a 1a 01 03 80 69 3b 78 2a b1 dd a4 53 52 97 26
[ 21.984] (--) NVIDIA(0): 0d 47 4a a5 ce 00 d1 c0 01 01 01 01 01 01 01 01
[ 21.984] (--) NVIDIA(0): 01 01 01 01 01 01 04 74 00 30 f2 70 5a 80 b0 58
[ 21.984] (--) NVIDIA(0): 8a 00 1e 51 42 00 00 1e 02 3a 80 18 71 38 2d 40
[ 21.984] (--) NVIDIA(0): 58 2c 45 00 1e 51 42 00 00 1e 00 00 00 fc 00 45
[ 21.985] (--) NVIDIA(0): 34 38 75 2d 44 30 0a 20 20 20 20 20 00 00 00 fd
[ 21.985] (--) NVIDIA(0): 00 19 4c 0f 8c 26 00 0a 20 20 20 20 20 20 01 f3
[ 21.985] (--) NVIDIA(0): 02 03 3c 71 4e 5f 64 5d 62 10 22 20 05 04 07 06
[ 21.985] (--) NVIDIA(0): 03 02 01 32 57 06 00 00 00 00 00 00 00 00 00 00
[ 21.985] (--) NVIDIA(0): 09 07 07 15 07 50 83 01 00 00 6d 03 0c 00 30 00
[ 21.985] (--) NVIDIA(0): 38 3c 20 00 60 01 03 04 e3 0e 61 66 00 00 00 00
[ 21.985] (--) NVIDIA(0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 21.985] (--) NVIDIA(0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1a
[ 21.988] (--) NVIDIA(0): DFP-2: disconnected
[ 21.988] (--) NVIDIA(0): DFP-2: Internal TMDS
[ 21.988] (--) NVIDIA(0): DFP-2 Name Aliases:
[ 21.988] (--) NVIDIA(0): DPY-3
[ 21.988] (--) NVIDIA(0): DP-2
[ 21.988] (--) NVIDIA(0): DFP-2: 165.0 MHz maximum pixel clock
[ 21.988] (--) NVIDIA(0): CMN (DFP-3): connected
[ 21.988] (--) NVIDIA(0): CMN (DFP-3): Internal DisplayPort
[ 21.988] (--) NVIDIA(0): CMN (DFP-3) Name Aliases:
[ 21.988] (--) NVIDIA(0): DFP-3
[ 21.988] (--) NVIDIA(0): DPY-4
[ 21.989] (--) NVIDIA(0): DP-3
[ 21.989] (--) NVIDIA(0): DPY-EDID-d5e4e1d3-93fc-2728-2847-cac454efc430
[ 21.989] (--) NVIDIA(0): CMN (DFP-3): 960.0 MHz maximum pixel clock
[ 21.989] (--) NVIDIA(0): --- EDID for CMN (DP-3) ---
[ 21.989] (--) NVIDIA(0): EDID Version : 1.4
[ 21.989] (--) NVIDIA(0): Manufacturer : CMN
[ 21.989] (--) NVIDIA(0): Monitor Name : CMN
[ 21.989] (--) NVIDIA(0): Product ID : 0x15c2
[ 21.989] (--) NVIDIA(0): 32-bit Serial Number : 0x00000000
[ 21.989] (--) NVIDIA(0): Serial Number String :
[ 21.989] (--) NVIDIA(0): Manufacture Date : 2013, week 4
[ 21.989] (--) NVIDIA(0): DPMS Capabilities :
[ 21.989] (--) NVIDIA(0): Input Type : Digital
[ 21.989] (--) NVIDIA(0): Prefer first detailed timing : Yes
[ 21.989] (--) NVIDIA(0): Supports Continuous Frequency: No
[ 21.989] (--) NVIDIA(0): EDID 1.4 YCbCr 422 support : No
[ 21.989] (--) NVIDIA(0): EDID 1.4 YCbCr 444 support : No
[ 21.989] (--) NVIDIA(0): Maximum Image Size : 340 mm x 190 mm
[ 21.989] (--) NVIDIA(0): Valid HSync Range : 45.3 kHz - 67.9 kHz
[ 21.989] (--) NVIDIA(0): Valid VRefresh Range : 40.0 Hz - 60.0 Hz
[ 21.989] (--) NVIDIA(0): EDID maximum pixel clock : 152.8 MHz
[ 21.989] (--) NVIDIA(0): EDID bits per component : 6
[ 21.989] (--) NVIDIA(0): Detailed Timings:
[ 21.989] (--) NVIDIA(0): 1920 x 1080 @ 60 Hz
[ 21.989] (--) NVIDIA(0): Pixel Clock : 152.84 MHz
[ 21.989] (--) NVIDIA(0): HRes, HSyncStart : 1920, 2010
[ 21.989] (--) NVIDIA(0): HSyncEnd, HTotal : 2070, 2250
[ 21.989] (--) NVIDIA(0): VRes, VSyncStart : 1080, 1086
[ 21.989] (--) NVIDIA(0): VSyncEnd, VTotal : 1095, 1132
[ 21.989] (--) NVIDIA(0): H/V Polarity : +/-
[ 21.989] (--) NVIDIA(0): Image Size : 344 mm x 194 mm
[ 21.989] (--) NVIDIA(0): 1920 x 1080 @ 40 Hz
[ 21.989] (--) NVIDIA(0): Pixel Clock : 101.89 MHz
[ 21.989] (--) NVIDIA(0): --- End of EDID for CMN (DP-3) ---
[ 21.989] (--) NVIDIA(0): Raw EDID bytes:
[ 21.989] (--) NVIDIA(0): 00 ff ff ff ff ff ff 00 0d ae c2 15 00 00 00 00
[ 21.989] (--) NVIDIA(0): 04 17 01 04 95 22 13 78 02 46 35 9e 57 57 94 27
[ 21.989] (--) NVIDIA(0): 14 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
[ 21.989] (--) NVIDIA(0): 01 01 01 01 01 01 b4 3b 80 4a 71 38 34 40 5a 3c
[ 21.989] (--) NVIDIA(0): 69 00 58 c2 10 00 00 1a cd 27 80 4a 71 38 34 40
[ 21.989] (--) NVIDIA(0): 5a 3c 69 00 58 c2 10 00 00 1a 00 00 00 00 00 00
[ 21.989] (--) NVIDIA(0): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02
[ 21.989] (--) NVIDIA(0): 00 0c 33 ff 0f 3c 96 21 14 33 96 00 00 00 00 70
[ 21.989] (--) NVIDIA(0): DFP-4: disconnected
[ 21.989] (--) NVIDIA(0): DFP-4: Internal DisplayPort
[ 21.989] (--) NVIDIA(0): DFP-4 Name Aliases:
[ 21.989] (--) NVIDIA(0): DPY-5
[ 21.989] (--) NVIDIA(0): DP-4
[ 21.989] (--) NVIDIA(0): DFP-4: 960.0 MHz maximum pixel clock
[ 21.989] (--) NVIDIA(0): DFP-5: disconnected
[ 21.989] (--) NVIDIA(0): DFP-5: Internal DisplayPort
[ 21.989] (--) NVIDIA(0): DFP-5 Name Aliases:
[ 21.989] (--) NVIDIA(0): DPY-6
[ 21.989] (--) NVIDIA(0): DP-5
[ 21.989] (--) NVIDIA(0): DFP-5: 960.0 MHz maximum pixel clock
[ 21.989] (--) NVIDIA(0): DFP-6: disconnected
[ 21.989] (--) NVIDIA(0): DFP-6: Internal DisplayPort
[ 21.989] (--) NVIDIA(0): DFP-6 Name Aliases:
[ 21.989] (--) NVIDIA(0): DPY-7
[ 21.989] (--) NVIDIA(0): DP-6
[ 21.989] (--) NVIDIA(0): DFP-6: 960.0 MHz maximum pixel clock
[ 21.989] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20150116)
[ 21.990] (II) NVIDIA(0): NVIDIA GPU Quadro K610M (GK208GL) at PCI:1:0:0 (GPU-0)
[ 21.990] (--) NVIDIA(0): Memory: 1048576 kBytes
[ 21.990] (--) NVIDIA(0): VideoBIOS: 80.28.44.00.07
[ 21.990] (II) NVIDIA(0): Detected PCI Express Link width: 8X
[ 21.990] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 21.990] (**) NVIDIA(0): device VIZ E48u-D0 (DFP-1) (Using EDID frequencies has
[ 21.990] (**) NVIDIA(0): been enabled on all display devices.)
[ 21.990] (II) NVIDIA(GPU-0):
[ 21.990] (II) NVIDIA(GPU-0): --- Building ModePool for VIZ E48u-D0 (DFP-1) ---
[ 21.990] (WW) NVIDIA(GPU-0): Validating Mode "3840x2160_30":
[ 21.990] (WW) NVIDIA(GPU-0): Mode Source: EDID
[ 21.990] (WW) NVIDIA(GPU-0): 3840 x 2160 @ 30 Hz
[ 21.990] (WW) NVIDIA(GPU-0): Pixel Clock : 297.00 MHz
[ 21.990] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 3840, 4016
[ 21.990] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 4104, 4400
[ 21.990] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 2160, 2168
[ 21.990] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 2178, 2250
[ 21.990] (WW) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 21.990] (WW) NVIDIA(GPU-0): Mode is rejected: PixelClock (297.0 MHz) too high for
[ 21.990] (WW) NVIDIA(GPU-0): Display Device (Max: 165.0 MHz).
[ 21.990] (WW) NVIDIA(GPU-0): Mode "3840x2160_30" is invalid.
[ 21.990] (II) NVIDIA(GPU-0): Validating Mode "1920x1080_60":
[ 21.990] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 21.990] (II) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 21.990] (II) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[ 21.990] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 21.990] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 21.990] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 21.990] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 21.990] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 21.990] (II) NVIDIA(GPU-0): Viewport 1920x1080+0+0
[ 21.990] (II) NVIDIA(GPU-0): Horizontal Taps 0
[ 21.990] (II) NVIDIA(GPU-0): Vertical Taps 0
[ 21.990] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 21.990] (II) NVIDIA(GPU-0): Base Depth 32
[ 21.990] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 21.990] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 21.990] (II) NVIDIA(GPU-0): Mode "1920x1080_60" is valid.
[ 21.990] (WW) NVIDIA(GPU-0): Pixel Clock : 296.70 MHz
[ 21.990] (WW) NVIDIA(GPU-0): Mode is rejected: PixelClock (296.7 MHz) too high for
[ 21.990] (WW) NVIDIA(GPU-0): Validating Mode "4096x2160_30":
[ 21.990] (WW) NVIDIA(GPU-0): 4096 x 2160 @ 30 Hz
[ 21.990] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 4096, 4184
[ 21.990] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 4272, 4400
[ 21.991] (WW) NVIDIA(GPU-0): Mode "4096x2160_30" is invalid.
[ 21.991] (WW) NVIDIA(GPU-0): Validating Mode "3840x2160_24":
[ 21.991] (WW) NVIDIA(GPU-0): Mode Source: EDID
[ 21.991] (WW) NVIDIA(GPU-0): 3840 x 2160 @ 24 Hz
[ 21.991] (WW) NVIDIA(GPU-0): Pixel Clock : 296.75 MHz
[ 21.991] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 3840, 5116
[ 21.991] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 5204, 5500
[ 21.991] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 2160, 2168
[ 21.991] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 2178, 2250
[ 21.991] (WW) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 21.991] (WW) NVIDIA(GPU-0): Mode is rejected: PixelClock (296.7 MHz) too high for
[ 21.991] (WW) NVIDIA(GPU-0): Display Device (Max: 165.0 MHz).
[ 21.991] (WW) NVIDIA(GPU-0): Mode "3840x2160_24" is invalid.
[ 21.991] (WW) NVIDIA(GPU-0): Validating Mode "4096x2160_24":
[ 21.991] (WW) NVIDIA(GPU-0): 4096 x 2160 @ 24 Hz
[ 21.991] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 4096, 5116
[ 21.991] (WW) NVIDIA(GPU-0): Mode "4096x2160_24" is invalid.
[ 21.991] (II) NVIDIA(GPU-0): Validating Mode "1920x1080_60":
[ 21.991] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 21.991] (II) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 21.991] (II) NVIDIA(GPU-0): Pixel Clock : 148.35 MHz
[ 21.991] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 21.991] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 21.991] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 21.991] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 21.991] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 21.991] (II) NVIDIA(GPU-0): Viewport 1920x1080+0+0
[ 21.991] (II) NVIDIA(GPU-0): Horizontal Taps 0
[ 21.991] (II) NVIDIA(GPU-0): Vertical Taps 0
[ 21.991] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 21.991] (II) NVIDIA(GPU-0): Base Depth 32
[ 21.991] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 21.991] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 21.991] (II) NVIDIA(GPU-0): Mode "1920x1080_60" is valid.
[ 21.991] (II) NVIDIA(GPU-0): Validating Mode "1920x1080_30":
[ 21.991] (II) NVIDIA(GPU-0): 1920 x 1080 @ 30 Hz
[ 21.991] (II) NVIDIA(GPU-0): Pixel Clock : 74.18 MHz
[ 21.991] (II) NVIDIA(GPU-0): Mode "1920x1080_30" is valid.
[ 21.991] (II) NVIDIA(GPU-0): Validating Mode "1920x1080_24":
[ 21.991] (II) NVIDIA(GPU-0): 1920 x 1080 @ 24 Hz
[ 21.991] (II) NVIDIA(GPU-0): Pixel Clock : 74.16 MHz
[ 21.991] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2558
[ 21.991] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2602, 2750
[ 21.991] (II) NVIDIA(GPU-0): The EDID for VIZ E48u-D0 (DP-1) contradicts itself: mode
[ 21.991] (II) NVIDIA(GPU-0): "1920x1080" is specified in the EDID; however, the EDID's
[ 21.991] (II) NVIDIA(GPU-0): valid VertRefresh range (25.000-76.000 Hz) would exclude
[ 21.991] (II) NVIDIA(GPU-0): this mode's VertRefresh (23.970 Hz); ignoring VertRefresh
[ 21.991] (II) NVIDIA(GPU-0): check for mode "1920x1080".
[ 21.991] (II) NVIDIA(GPU-0): Mode "1920x1080_24" is valid.
[ 21.991] (II) NVIDIA(GPU-0): Validating Mode "1920x1080_60i":
[ 21.991] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1094, 1124
[ 21.991] (II) NVIDIA(GPU-0): Extra : Interlace
[ 21.991] (II) NVIDIA(GPU-0): Mode "1920x1080_60i" is valid.
[ 21.991] (II) NVIDIA(GPU-0): Validating Mode "1280x720_60":
[ 21.991] (II) NVIDIA(GPU-0): 1280 x 720 @ 60 Hz
[ 21.991] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1280, 1390
[ 21.991] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1430, 1650
[ 21.991] (II) NVIDIA(GPU-0): VRes, VSyncStart : 720, 725
[ 21.991] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 730, 750
[ 21.991] (II) NVIDIA(GPU-0): Viewport 1280x720+0+0
[ 21.991] (II) NVIDIA(GPU-0): Mode "1280x720_60" is valid.
[ 21.991] (II) NVIDIA(GPU-0): Validating Mode "720x480_60i":
[ 21.991] (II) NVIDIA(GPU-0): 720 x 480 @ 60 Hz
[ 21.991] (II) NVIDIA(GPU-0): Pixel Clock : 13.50 MHz
[ 21.991] (II) NVIDIA(GPU-0): HRes, HSyncStart : 720, 739
[ 21.991] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 801, 858
[ 21.991] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 488
[ 21.991] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 494, 524
[ 21.991] (II) NVIDIA(GPU-0): Sync Polarity : -H -V
[ 21.991] (II) NVIDIA(GPU-0): Viewport 1440x480+0+0
[ 21.991] (II) NVIDIA(GPU-0): Mode "720x480_60i" is valid.
[ 21.991] (II) NVIDIA(GPU-0): Validating Mode "720x480_60":
[ 21.991] (II) NVIDIA(GPU-0): Pixel Clock : 27.00 MHz
[ 21.991] (II) NVIDIA(GPU-0): HRes, HSyncStart : 720, 736
[ 21.991] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 798, 858
[ 21.991] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[ 21.991] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 495, 525
[ 21.991] (II) NVIDIA(GPU-0): Viewport 720x480+0+0
[ 21.992] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 21.992] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 21.992] (II) NVIDIA(GPU-0): Mode "720x480_60" is valid.
[ 21.992] (II) NVIDIA(GPU-0): Validating Mode "720x480_60":
[ 21.992] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 21.992] (II) NVIDIA(GPU-0): 720 x 480 @ 60 Hz
[ 21.992] (II) NVIDIA(GPU-0): Pixel Clock : 27.00 MHz
[ 21.992] (II) NVIDIA(GPU-0): HRes, HSyncStart : 720, 736
[ 21.992] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 798, 858
[ 21.992] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 489
[ 21.992] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 495, 525
[ 21.992] (II) NVIDIA(GPU-0): Sync Polarity : -H -V
[ 21.992] (II) NVIDIA(GPU-0): Viewport 720x480+0+0
[ 21.992] (II) NVIDIA(GPU-0): Horizontal Taps 0
[ 21.992] (II) NVIDIA(GPU-0): Vertical Taps 0
[ 21.992] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 21.992] (II) NVIDIA(GPU-0): Base Depth 32
[ 21.992] (II) NVIDIA(GPU-0): Validating Mode "640x480_60":
[ 21.992] (II) NVIDIA(GPU-0): 640 x 480 @ 60 Hz
[ 21.992] (II) NVIDIA(GPU-0): Pixel Clock : 25.17 MHz
[ 21.992] (II) NVIDIA(GPU-0): HRes, HSyncStart : 640, 656
[ 21.992] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 752, 800
[ 21.992] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 490
[ 21.992] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 492, 525
[ 21.992] (II) NVIDIA(GPU-0): Viewport 640x480+0+0
[ 21.992] (II) NVIDIA(GPU-0): Mode "640x480_60" is valid.
[ 21.992] (WW) NVIDIA(GPU-0): Validating Mode "3840x2160_60":
[ 21.992] (WW) NVIDIA(GPU-0): Mode Source: EDID
[ 21.992] (WW) NVIDIA(GPU-0): 3840 x 2160 @ 60 Hz
[ 21.992] (WW) NVIDIA(GPU-0): Pixel Clock : 593.41 MHz
[ 21.992] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 3840, 4016
[ 21.992] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 4104, 4400
[ 21.992] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 2160, 2168
[ 21.992] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 2178, 2250
[ 21.992] (WW) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 21.992] (WW) NVIDIA(GPU-0): Mode is rejected: PixelClock (296.7 MHz) too high for
[ 21.992] (WW) NVIDIA(GPU-0): Display Device (Max: 165.0 MHz).
[ 21.992] (WW) NVIDIA(GPU-0): Mode "3840x2160_60" is invalid.
[ 21.992] (WW) NVIDIA(GPU-0): Validating Mode "4096x2160_60":
[ 21.992] (WW) NVIDIA(GPU-0): 4096 x 2160 @ 60 Hz
[ 21.992] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 4096, 4184
[ 21.992] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 4272, 4400
[ 21.992] (WW) NVIDIA(GPU-0): Mode "4096x2160_60" is invalid.
[ 21.992] (II) NVIDIA(GPU-0): Validating Mode "1920x1080_60":
[ 21.992] (II) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 21.992] (II) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[ 21.992] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 21.992] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 21.992] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 21.992] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 21.992] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 21.992] (II) NVIDIA(GPU-0): Viewport 1920x1080+0+0
[ 21.992] (II) NVIDIA(GPU-0): Mode "1920x1080_60" is valid.
[ 21.992] (II) NVIDIA(GPU-0): Validating Mode "640x480_75":
[ 21.992] (II) NVIDIA(GPU-0): 640 x 480 @ 75 Hz
[ 21.992] (II) NVIDIA(GPU-0): Pixel Clock : 31.50 MHz
[ 21.992] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 720, 840
[ 21.992] (II) NVIDIA(GPU-0): VRes, VSyncStart : 480, 481
[ 21.992] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 484, 500
[ 21.992] (II) NVIDIA(GPU-0): Mode "640x480_75" is valid.
[ 21.992] (II) NVIDIA(GPU-0): Validating Mode "800x600_60":
[ 21.992] (II) NVIDIA(GPU-0): 800 x 600 @ 60 Hz
[ 21.992] (II) NVIDIA(GPU-0): Pixel Clock : 40.00 MHz
[ 21.992] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 840
[ 21.992] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 968, 1056
[ 21.992] (II) NVIDIA(GPU-0): VRes, VSyncStart : 600, 601
[ 21.992] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 605, 628
[ 21.992] (II) NVIDIA(GPU-0): Viewport 800x600+0+0
[ 21.992] (II) NVIDIA(GPU-0): Mode "800x600_60" is valid.
[ 21.992] (II) NVIDIA(GPU-0): Validating Mode "800x600_72":
[ 21.992] (II) NVIDIA(GPU-0): 800 x 600 @ 72 Hz
[ 21.992] (II) NVIDIA(GPU-0): Pixel Clock : 50.00 MHz
[ 21.992] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 856
[ 21.992] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 976, 1040
[ 21.992] (II) NVIDIA(GPU-0): VRes, VSyncStart : 600, 637
[ 21.992] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 643, 666
[ 21.992] (II) NVIDIA(GPU-0): Mode "800x600_72" is valid.
[ 21.993] (II) NVIDIA(GPU-0): Validating Mode "800x600_75":
[ 21.993] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 21.993] (II) NVIDIA(GPU-0): 800 x 600 @ 75 Hz
[ 21.993] (II) NVIDIA(GPU-0): Pixel Clock : 49.50 MHz
[ 21.993] (II) NVIDIA(GPU-0): HRes, HSyncStart : 800, 816
[ 21.993] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 896, 1056
[ 21.993] (II) NVIDIA(GPU-0): VRes, VSyncStart : 600, 601
[ 21.993] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 604, 625
[ 21.993] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 21.993] (II) NVIDIA(GPU-0): Viewport 800x600+0+0
[ 21.993] (II) NVIDIA(GPU-0): Horizontal Taps 0
[ 21.993] (II) NVIDIA(GPU-0): Vertical Taps 0
[ 21.993] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 21.993] (II) NVIDIA(GPU-0): Base Depth 32
[ 21.993] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 21.993] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 21.993] (II) NVIDIA(GPU-0): Mode "800x600_75" is valid.
[ 21.993] (II) NVIDIA(GPU-0): Validating Mode "1024x768_60":
[ 21.993] (II) NVIDIA(GPU-0): 1024 x 768 @ 60 Hz
[ 21.993] (II) NVIDIA(GPU-0): Pixel Clock : 65.00 MHz
[ 21.993] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1048
[ 21.993] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1184, 1344
[ 21.993] (II) NVIDIA(GPU-0): VRes, VSyncStart : 768, 771
[ 21.993] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 777, 806
[ 21.993] (II) NVIDIA(GPU-0): Sync Polarity : -H -V
[ 21.993] (II) NVIDIA(GPU-0): Viewport 1024x768+0+0
[ 21.993] (II) NVIDIA(GPU-0): Mode "1024x768_60" is valid.
[ 21.993] (II) NVIDIA(GPU-0): Validating Mode "1024x768_70":
[ 21.993] (II) NVIDIA(GPU-0): 1024 x 768 @ 70 Hz
[ 21.993] (II) NVIDIA(GPU-0): Pixel Clock : 75.00 MHz
[ 21.993] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1184, 1328
[ 21.993] (II) NVIDIA(GPU-0): Mode "1024x768_70" is valid.
[ 21.993] (II) NVIDIA(GPU-0): Validating Mode "1024x768_75":
[ 21.993] (II) NVIDIA(GPU-0): 1024 x 768 @ 75 Hz
[ 21.993] (II) NVIDIA(GPU-0): Pixel Clock : 78.75 MHz
[ 21.993] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1024, 1040
[ 21.993] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 1136, 1312
[ 21.993] (II) NVIDIA(GPU-0): VRes, VSyncStart : 768, 769
[ 21.993] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 772, 800
[ 21.993] (II) NVIDIA(GPU-0): Mode "1024x768_75" is valid.
[ 21.993] (WW) NVIDIA(GPU-0): Validating Mode "3840x2160_30":
[ 21.993] (WW) NVIDIA(GPU-0): Mode Source: EDID
[ 21.993] (WW) NVIDIA(GPU-0): 3840 x 2160 @ 30 Hz
[ 21.993] (WW) NVIDIA(GPU-0): Pixel Clock : 296.70 MHz
[ 21.993] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 3840, 4016
[ 21.993] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 4104, 4400
[ 21.993] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 2160, 2168
[ 21.993] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 2178, 2250
[ 21.993] (WW) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 21.993] (WW) NVIDIA(GPU-0): Mode is rejected: PixelClock (296.7 MHz) too high for
[ 21.993] (WW) NVIDIA(GPU-0): Display Device (Max: 165.0 MHz).
[ 21.993] (WW) NVIDIA(GPU-0): Mode "3840x2160_30" is invalid.
[ 21.993] (WW) NVIDIA(GPU-0): Validating Mode "3840x2160_24":
[ 21.993] (WW) NVIDIA(GPU-0): 3840 x 2160 @ 24 Hz
[ 21.993] (WW) NVIDIA(GPU-0): Pixel Clock : 296.75 MHz
[ 21.993] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 3840, 5116
[ 21.993] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 5204, 5500
[ 21.993] (WW) NVIDIA(GPU-0): Mode "3840x2160_24" is invalid.
[ 21.993] (WW) NVIDIA(GPU-0): Validating Mode "4096x2160_24":
[ 21.993] (WW) NVIDIA(GPU-0): 4096 x 2160 @ 24 Hz
[ 21.993] (WW) NVIDIA(GPU-0): Pixel Clock : 297.00 MHz
[ 21.993] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 4096, 5116
[ 21.993] (WW) NVIDIA(GPU-0): Mode is rejected: PixelClock (297.0 MHz) too high for
[ 21.993] (WW) NVIDIA(GPU-0): Mode "4096x2160_24" is invalid.
[ 21.993] (WW) NVIDIA(GPU-0): Validating Mode "640x350_85":
[ 21.993] (WW) NVIDIA(GPU-0): Mode Source: VESA
[ 21.993] (WW) NVIDIA(GPU-0): 640 x 350 @ 85 Hz
[ 21.993] (WW) NVIDIA(GPU-0): Pixel Clock : 31.50 MHz
Hopefully I was able to post enough of the log file to get the gist. When it started to complain about the PixelClock being to high for the display device, I thought that odd since the mode was coming from the EDID:
I added this to the xorg.conf file to try and force the issue:
Option "ModeValidation" "AllowNon60hzmodesDFPModes, NoEDIDDFPMaxSizeCheck, NoVertRefreshCheck, NoHorizSyncCheck, NoDFPNativeResolutionCheck, NoMaxSizeCheck, NoMaxPClkCheck, AllowNonEdidModes, NoEdidMaxPClkCheck"
Now its’s complaining about the hardware isn’t supporting it:
[ 12.860] (WW) NVIDIA(GPU-0): Validating Mode "3840x2160_30":
[ 12.860] (WW) NVIDIA(GPU-0): Mode Source: EDID
[ 12.860] (WW) NVIDIA(GPU-0): 3840 x 2160 @ 30 Hz
[ 12.860] (WW) NVIDIA(GPU-0): Pixel Clock : 296.70 MHz
[ 12.860] (WW) NVIDIA(GPU-0): HRes, HSyncStart : 3840, 4016
[ 12.860] (WW) NVIDIA(GPU-0): HSyncEnd, HTotal : 4104, 4400
[ 12.860] (WW) NVIDIA(GPU-0): VRes, VSyncStart : 2160, 2168
[ 12.860] (WW) NVIDIA(GPU-0): VSyncEnd, VTotal : 2178, 2250
[ 12.860] (WW) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 12.860] (WW) NVIDIA(GPU-0): ViewPort 3840x2160 exceeds hardware capabilities.
[ 12.860] (WW) NVIDIA(GPU-0): Mode is rejected: GPU extended capability check failed.
[ 12.860] (WW) NVIDIA(GPU-0): Mode "3840x2160_30" is invalid.
So I checked the Nvidia sight to make sure it could handle that resolution http://www.notebookcheck.net/NVIDIA-Quadro-K610M.98902.0.html:
The improved feature set now includes support for up to 4 active displays. Furthermore, high resolution monitors of up to 3840 x 2160 pixels can now be connected using DisplayPort 1.2 or HDMI 1.4a if available.
Not sure where the real road block is, if it is really the GPU or I have something else going on. Thanks for the help.
Anyone have any thoughts on the real limitation of my situation. I know the card can do a 4k resolution cause I have seen it do it on windows @ 30Hz. Does the driver have a problem reading its capabilities?
Just updated to the newly released 370.28 drivers and sure enough it fixed the issues with my 4k samsung.
Thanks for the fix guys! :)
jdtommy: I think you are experiencing a different problem than what is being described (and since been fixed in 370.28) here.
The problems we all had was working with 4k@60hz. You mentioned yours being 4k@30hz which has always worked for us. I could do 30hz I just couldn’t get 60hz.
My suggestion to get a better response is to start a new thread with a title that pertains to your issue. The logs you posted show a very different issue than the one described in this thread.
I can give you some stuff I tried to narrow down what was going on:
- Try to install older drivers (I used 361.28, which worked and let me identify what driver started the problem).
- Try letting Xorg start X without a config file using custom Options/EDID, and see if that gives you a different log with information that might help you diagnose the issue.
- Try a different monitor. That was the big problem for us here is that there are a few brands of TV/monitor that were not reporting the 4k modes properly. If you can try a different one and see if you can get 4k@30 that way.
From the looks of your log, your GPU does not support the mode you are trying to set. Since you know it works with Windows, that means it could be a driver issue or it could be some settings you have for X11. Could be an issue with your modeline telling your system to support something that you can’t. That’s why I would try without the config file, as the new Xorg guesses really well at your hardware set ups.
Good luck with your issue and again I would start a fresh thread that has to do with what you are trying to fix rather than using this thread that has a fix in the newest driver. I’m guessing most people in this thread have stopped watching it as it was fixed, so getting attention here might be hard. I’m unsubbing as well after this post.
I can confirm updating to the 370.28 driver now allows me to do 4K@60Hz, where I was previously only able to get 4k@30Hz.
There are several threads about the M43-C1 firmware update breaking things, so I included my TV FW version…
Here is my setup:
Display: Vizio M43-C1 (Connected to HDMI-5, which is the only input that supports 4k@60Hz)
TV Firmware Version: 1.3.15-UHD
FRC Version: 9.406
GPU: GTX 960
Connection: DVI->HDMI
OS: Mint 18 (4.4.0-21-generic)
Hope this helps!
I had given up on this a while back, and just came back to it after doing a fresh install of Ubuntu 16.04; I’m running a Vizio M43-c1.
It took a bit to get the driver running at all for some reason, and it turns out that NVidia drivers don’t play nice with luks (full disk encryption), so I had to switch boot up to text mode. It’s unfortunate, but not a deal-breaker.
I settled on the 370 version from a ppa, and am now able to select 4k 60hz in the nvidia app and it works perfectly!
Best monitor I’ve ever had. I don’t know about gaming, but it’s great for dev.
I have somewhat similar yet different problem, so I’ll post it here.
Ubuntu 16.04, GTX1070 with 375.26 drivers and Acer Predator XB281HK
With DP, I can select 4k60/30/24Hz, 1024x768 or 800x600 in most games (for example, Nvidia control panel says 1920x1080 is “scaled”. Some native games give me more resolutions for some reason?
With HDMI, I can select 4k30/24Hz, and a boatload of other resolutions, which do not say “scaled”, including 1920x1080.
My GPU should be able to send 4k60 through HDMI2.0 cable, and my display should be able to receive it. Also my display should be able to display 1920x1080 with DP.
I cannot get any response with get-edid > edid.bin from display connected to DP. I can however save edid in nvidia control panel and parse-edid gives a cryptic error message:
:~$ parse-edid < edid.bin
Checksum Correct
Section "Monitor"
Identifier "Acer XB281HK"
ModelName "Acer XB281HK"
VendorName "ACR"
# Monitor Model Year: 2013
# EDID version 1.4
# Digital Display
DisplaySize 620 340
Gamma 2.20
Option "DPMS" "false"
Horizsync 52-133
VertRefresh 30-60
# Maximum pixel clock is 540MHz
#Extension block found. Parsing...
extb[4]: 0x23 (0x20)
Hmm, you have data blocks, but not video ones... weird
Something strange happened. Please contact the author,
Matthew Kern at <pyrophobicman@gmail.com>
I have 2 monitors connected, but the problem is the same even with only one monitor.
This is most annoying with Wine games, and I haven’t found any solutions for it.
This problem still exists with NVIDIA-Linux-x86_64-375.39 + kernel_4.10.patch
Hardware: NVIDIA Quatro K620, Samsung UE43KS7505 SUHD TV, Club 3D CAC-1070 (DP to HDMI)
Kernel 4.10.1
SO, in the windows I can use 3840x2160@60p with 4:4:4, but in linux I can reach only 3840x2160@30p RGB and if I enable “UHD Color”, result is black screen and TV says that “Mode not supported, 720x480 60i”
First boot:
UHD colors enabled from computer start, here is Xorg.0.log (with Option “ModeDebug”) https://drive.google.com/open?id=0B_nQziZUPvaucDNWc3dtelZaeEk
Screen goes black and TV is reporting not supported mode. If I press Ctrl-Alt-F1, screen stays black.
Second boot:
UHD colors disabled from computer start and Xorg starts to 3840x2160@30p mode. Then I change (at TV) UHD colors enabled and video card change it’s mode. Result is black screen and TV is reporting not supported mode. I press Ctrl-Alt-F1, screen STAYS black, but TV reports that mode is now 1920x1080@60p
Here is Xorg.0.log (with Option “ModeDebug”): https://drive.google.com/open?id=0B_nQziZUPvauVmdzMGd6VEp2bzA
Here is nvidia-bug-report.log.gz https://drive.google.com/file/d/0B_nQziZUPvauVVM1anNQbnhBRVk/view?usp=sharing (it was too big to attach here directly; 185,5KB)
That console blackness is strange. If I boot my computer, grub starts with 1920x1080 resolution what I have defined in grub.conf, but then system loads nvidia modules and result is black screen on that 1920x1080@60i… Result is same even I use nouveau driver. If I don’t enable UHD colors, I have no problem to use 3840x2160@30p mode in console.
FFS it’s been like two years since I’ve been running 4k at only 30hz… Does anyone have any recommendations for a cheap 4k60hz compatible graphics (just for display purposes - no gaming) (that works in Linux…).
I’m still running into this issue. My display only supports 2160p60 in combination with 4:2:0 subsampling. But nvidia-settings doesn’t offer that setting in the respective dropdown.
The thing is, even on Windows I first have to switch to a setting that works at 2160p RGB (like at 30Hz) or the driver won’t offer the 4:2:0 mode. So I have to switch in 2 steps. That trick doesn’t work on my Ubuntu 18.0.4 with the 440.48.02 driver.
So, may that be a problem with the display’s EDID data? Here’s the EDID dump from nvidia-settings run through edid-decode:
Extracted contents:
header: 00 ff ff ff ff ff ff 00
serial number: 34 a9 96 a2 01 01 01 01 00 1a
version: 01 03
basic params: 80 80 48 78 0a
chroma info: da ff a3 58 4a a2 29 17 49 4b
established: 20 08 00
standard: 31 40 61 40 01 01 01 01 01 01 01 01 01 01 01 01
descriptor 1: 08 e8 00 30 f2 70 5a 80 b0 58 8a 00 ba 88 21 00 00 1e
descriptor 2: 02 3a 80 18 71 38 2d 40 58 2c 45 00 ba 88 21 00 00 1e
descriptor 3: 00 00 00 fc 00 50 61 6e 61 73 6f 6e 69 63 2d 54 56 0a
descriptor 4: 00 00 00 fd 00 17 3d 0f 88 3c 00 0a 20 20 20 20 20 20
extensions: 01
checksum: 20
Manufacturer: MEI Model a296
Made week 0 of 2016
EDID version: 1.3
Digital display
Maximum image size: 128 cm x 72 cm
Gamma: 2.20
Supported color formats: RGB 4:4:4, YCrCb 4:4:4
First detailed timing is preferred timing
Established timings supported:
640x480@60Hz
1024x768@60Hz
Standard timings supported:
640x480@60Hz
1024x768@60Hz
Detailed mode: Clock 594.000 MHz, 698 mm x 392 mm
3840 4016 4104 4400 hborder 0
2160 2168 2178 2250 vborder 0
+hsync +vsync
Detailed mode: Clock 148.500 MHz, 698 mm x 392 mm
1920 2008 2052 2200 hborder 0
1080 1084 1089 1125 vborder 0
+hsync +vsync
Monitor name: Panasonic-TV
Monitor ranges (GTF): 23-61Hz V, 15-136kHz H, max dotclock 600MHz
Has 1 extension blocks
Checksum: 0x20 (valid)
CEA extension block
Extension version: 3
83 bytes of CEA data
Video data block
VIC 16 1920x1080@60Hz
VIC 31 1920x1080@50Hz
VIC 5 1920x1080i@60Hz
VIC 20 1920x1080i@50Hz
VIC 32 1920x1080@24Hz
VIC 33 1920x1080@25Hz
VIC 34 1920x1080@30Hz
VIC 4 1280x720@60Hz
VIC 19 1280x720@50Hz
VIC 3 720x480@60Hz
VIC 18 720x576@50Hz
VIC 7 1440x480i@60Hz
VIC 22 1440x576i@50Hz
VIC 93 3840x2160@24Hz
VIC 94 3840x2160@25Hz
VIC 95 3840x2160@30Hz
VIC 98 4096x2160@24Hz
VIC 99 4096x2160@25Hz
VIC 100 4096x2160@30Hz
VIC 97 3840x2160@60Hz
VIC 96 3840x2160@50Hz
VIC 102 4096x2160@60Hz
VIC 101 4096x2160@50Hz
Audio data block
Linear PCM, max channels 2
Supported sample rates (kHz): 48 44.1 32
Supported sample sizes (bits): 16
AC-3, max channels 6
Maximum bit rate: 640 kHz
Dolby Digital+, max channels 8
Vendor-specific data block, OUI 000c03 (HDMI)
Source physical address 1.0.0.0
DC_36bit
DC_30bit
DC_Y444
Maximum TMDS clock: 300MHz
Extended HDMI video details:
3D present
3D-capable-VIC mask present
Base EDID image size is aspect ratio
HDMI VIC 0 3840x2160@30Hz
HDMI VIC 1 3840x2160@25Hz
HDMI VIC 2 3840x2160@24Hz
HDMI VIC 3 4096x2160@24Hz
3D: Side-by-side (half, quincunx)
3D: Side-by-side (half, horizontal)
3D: Top-and-bottom
3D: Frame-packing
3D VIC indices: 2 3 4 7 8
VIC index 0 supports top-and-bottom
VIC index 1 supports top-and-bottom
VIC index 0 supports unknown
VIC index 1 supports unknown
Vendor-specific data block, OUI c45dd8
Extended tag: video capability data block
YCbCr quantization: No Data (0)
RGB quantization: Selectable (via AVI Q) (1)
PT scan behaviour: No Data (0)
IT scan behaviour: Always Underscanned (2)
CE scan behaviour: Support both over- and underscan (3)
Extended tag: Colorimetry data block
xvYCC601
xvYCC709
sYCC601
AdobeYCC601
AdobeRGB
BT2020cYCC
BT2020YCC
BT2020RGB
Extended tag: YCbCr 4:2:0 capability map data block
Extended tag: HDR static metadata data block
Electro optical transfer functions:
Traditional gamma - SDR luminance range
Traditional gamma - HDR luminance range
SMPTE ST2084
Unknown
Supported static metadata descriptors:
Static metadata type 1
Underscans PC formats by default
Basic audio support
0 native detailed modes
Detailed mode: Clock 85.500 MHz, 698 mm x 392 mm
1366 1436 1579 1792 hborder 0
768 771 774 798 vborder 0
+hsync +vsync
Checksum: 0xe2 (valid)
Especially the part that says “Supported color formats: RGB 4:4:4, YCrCb 4:4:4” has me worried. 4:2:0 is only mentioned later as part of an extended tag, but it’s definitely supported (works on Windows at 4k). The 2 quoted modes are exactly the ones that are offered in nvidia-settings. To me it looks like the driver doesn’t try as hard under Linux as it does under Windows.
Since this limitation (2160p60 at only possible at 4:2:0 subsampling) is a widely known HDMI 2.0 bandwidth limit, it’s unfortunate that this doesn’t work.
So, for a solution: how can I change the EDID so it includes the 4:2:0 mode? Do you know any Linux tools that can do that? I’ve tried wxEDID but it chokes on the dump (crashes).
