4k on hdmi 2.0
I have 4K Philips 28" 4K LED 288P6LJEB/00 with HDMI 2.0 and geforce 970 also with hdmi 2.0. But I am unable to get 60 Hz with 3840x2160 in Linux. Is there any option I can use in xorg.conf.
Screen 0: minimum 8 x 8, current 2560 x 1440, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 621mm x 341mm
3840x2160 29.98 + 30.00 29.97 25.00 24.00 23.98
2560x1440 59.95*
2048x1080 59.99
1920x1080 60.00 59.94 50.00 50.00 60.00 50.04
1680x1050 59.95
1440x900 74.98 59.89
1280x1024 75.02 60.02
1280x960 60.00
1280x720 60.00 59.94 50.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00 50.08
720x480 59.94 60.05
640x480 75.00 72.81 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
resolved.
Screen 0: minimum 8 x 8, current 3840 x 2160, maximum 16384 x 16384
HDMI-0 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 621mm x 341mm
3840x2160 60.00*+ 59.94 50.00 30.00 29.98 29.97 25.00 23.98
1920x2160 59.99
1680x1050 59.95
1280x960 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
Could you elaborate? There are a lot of us in the forum that have been having the same issue without success.
The Philips Brilliance 288P does NOT support HDMI 2.0 properly. I do not believe Knut49 even has this screen…
It only supports HDMI 1.4 and DP 1.2 (which is capable of 4K input - I’m using it to write this post). If you own this screen like me you will know that the HDMI 1.4 / HDMI 2.0 option which should be below the DisplayPort 1.1 / 1.2 option and above the reset option (in the monitor setup menu).
Philips tech support are offering refunds on this screen since they do not current sell any monitor capable of 4K @ 60Hz so can’t even send replacement item instead.
So to all having issues sorry - you need to contact Philips for a refund if you need HDMI 2.0 input.
I have a Philips PHL 288P6L which support 4k with 60 hz.
xrandr
1920x2160 59.99
1680x1050 59.95
1280x960 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
Prove it.
The 288P6LJEB/00 does not support 4K over HDMI2.0. Philips do not sell ANY monitor capable of 60Hz @ 4K over HDMI 2.0. The specs in the manuals and on boxes etc were incorrect according to Philips tech support.
They knew the drill when I called, they were incredibly nice about it though. The lady I spoke to was very knowledgeable and incredibly nice about the situation. In fact I think she was rather embarrassed by their marketing dept’s mistakes.
Companies such as Philips don’t go round advising customers their monitors don’t support 4K @ 60Hz over HDMI 2.0 and offer refunds immediately no questions asked (we had a nice chat, it wasn’t as if I was a customer from hell). It was also confirmed by her colleagues too.
If your monitor does support 4K over HDMI 2.0 you won’t have a problem showing the HDMI 1.4 / 2.0 setting option in the monitor’ setup menu which is MIA on all 288P’s.
Prove you’ve got it running at 4K over HDMI 2.0 instead of just a load of xorg text gumph and help dchurch315 and others with this monitor to get it working 4K @ 60Hz or your word on this or any other topic is worthless.
Could you share your EDID?
nvidia-settings->GPU-0->HDMI-0(Or DFP-0 and name of the monitor)->Acquire edid
If it says Max dot clock 600MHz, it really is hdmi2.0(well it’s in binary form, it have to be parsed). You should even see it on /var/log/Xorg.0.log(edit. oops, /etc/X11/Xorg.0.log), were should be parsing information of your edid too. Nvidia have some yuv tweaking on windows side, where you can get 4k60Hz over hdmi 1.4. But I haven’t heard it could be possible with xorg.
Good advice Tuke81, My Linux install is still waiting to get done on my new rig so I went another direction.
These days I’m more of a Hackintosh/BSD user and only really use Windows for gaming. I installed OSX Sierra the other day, just waiting for Nvidia webdrivers to use new 1070 in OSX. If Windows does weirdness to EDID info I can try and get it out of SwitchResX in OSX but I expect the results will be the same.
My Philips Brilliance 288P6LJEB/00 displays the following EDID info (done in Windows via EDID Viewer & MonitorInfoView):-
For the DP it’s EDID is version 1.4 with a max pixel clock of 600Mhz, vert = 23-80, horiz = 30-160Khz
For the HDMI Port it EDID version is 1.3 with a max pixel clock of 300Mhz, vert 23-80, horiz = 30-99Khz
Anyways to prove the limit I used the 300Mhz as a barline to cross andupped the refresh over the HDMI 1.4 Port to a max of 34Hz before I reached the pixel clock limit. Go over the 300Mhz and guess what blank screen.
Knut49 is full of bull**** This monitor does not have a HDMI 2.0 port. Philips told me the truth, I wonder why he’s lying, what has he to gain? Fake kudos for getting something impossible to work maybe?
I had to change som option in the menu for the monitor to enable hdmi 2.0. This is my EDID
EDID:
00ffffffffffff00410cf20881040000
0e1a0103803e22782a5525a1574fa028
0f5054bd4b00d1c081808140950f9500
b30081c001014dd000a0f0703e803020
35006d552100001aa36600a0f0701f80
302035006d552100001a000000fc0050
484c2032383850364c0a2020000000fd
0017501e633c000a2020202020200195
020333f14c9004031f1301125d5e5f60
6123090707830100006d030c00100039
7820006001020367d85dc401788003e3
0f000c011d007251d01e206e2855006d
552100001e8c0ad08a20e02d10103e96
006d55210000184d6c80a070703e8030
203a006d552100001a04740030f2705a
80b0588a006d552100001a00000000a1
The option is MIA because the monitor spec is wrong. It simply isn’t there. Philips have confirmed the manual is wrong and the setting DOES NOT EXIST on this monitor.
Video of you actually accessing the settings menu or I’m still calling you out to be billy bulls*it. Anyone can hack a EDID to try and prove a pathetic point…
We should close the the threads. I have probably another Philips monitor that is bought in Europe not US. but I did have to change the default in monitor menu as shown on page 8 in the manual http://download.p4c.philips.com/files/2/288p6ljeb_27/288p6ljeb_27_dfu_aen.pdf. Thingi please provide me with a source since Philips has not change their manuals and personal communication do not count.
I bought mine in Europe too.
Philips are happy for any Euro customer to receive a refund due to no official support for HDMI 2.0. I’ve spoken with them already. Feel free to phone their support line for your country they will tell you what they told me.
Philips sell ZERO monitors with 2.0 support, you’ll notice the screen’s updated model is 5k and Dual DP only.
I’m sending mine back via the UK retailer I bought it from since they have agreed to supply me a new Dell S2817Q as a replacement.
I’d be interested to know the firmware revision and manufacturing date on your screen etc. I’m happy to post mine when I get home.
