I’ve recently installed 5.2-4 and mpich 1.2.6 on Linux x86_64. In 5.1-6 the my code executes without a problem. In 5.2-4, the code crashes with sigsegv 11. Incase you are wondering, i’ve installed two seperate versions of mpich, each compiled with their respective compiler. I was able to trace the crash to to MPI_SCATTER(). Here are the lines of code:
call MPI_SCATTER(sgrid%sph(1:gnn_even,1), l_gnn, MPI_DOUBLE_PRECISION, &
lgrid%sph(:,1), l_gnn, MPI_DOUBLE_PRECISION, master, MPI_COMM_WORLD, ierr)
I’ve also tried the above without a non-derived data type, i.e.
allocate(sgrid_sph1(gnn_even),sgrid_sph2(gnn_even))
allocate(lgrid_sph1(l_gnn),lgrid_sph2(l_gnn))
lgrid_sph1 = 0.0
lgrid_sph2 = 0.0
sgrid_sph1 = sgrid%sph(1:gnn_even,1)
sgrid_sph2 = sgrid%sph(1:gnn_even,2)
call MPI_SCATTER(sgrid_sph1, l_gnn, MPI_DOUBLE_PRECISION,&
lgrid_sph1, l_gnn, MPI_DOUBLE_PRECISION, master, MPI_COMM_WORLD, ierr)
Am I seeing an incarnation of the bug mentioned in TPR 3439 on the FAQ; its description is so vague!
Thanks,
Rob
