EDIT: Steps I have done to verify if it is the current driver: I installed the nvidia-470xx-dkms package from the aur to check if the issue would go away on an older driver version. The issue completely disappeared. I was able to switch workspaces and back without the game breaking or going invisible/blackscreen. After I reinstalled the newest nvidia driver version 510.47.03 and the issues were back again.
Hi since the update to the most recent driver I can no longer change work spaces on a single screen. With dual monitors it is fine for the most part. However, with 1 monitor for gsync if I switch out of the workspace it is impossible to bring back the original game.
“Optimized the Vulkan fullscreen presentation path for X11 and direct-to-display swapchains.”
Wondering if this has something to do with it? Also having issues with DXVK + 510 driver + fullscreen X11, using i3 or bspwm. Previous versions had no issues.
The game is hanging, to close it you have to kill it: from terminal (multiple processes to kill) or from Steam’s Library clicking multiple times “cancel”.
PS: As I have said before it does this only with VSync enabled, with VSync disabled everything works as it should, the game doesn’t go invisibile and there are no hangs.
EDIT: Since it seems fixed in the next driver version I remove the log since it contains some personal information.
