515.76 has no prime support?
can’t tell if this is a bug or normal thing. i updated to nvidia driver version 515.65 to 515.76 and the prime support appears gone. as does opengl and vulkan. is this a bug or is that some sort of cuda only driver? how would i enable prime on this driver if it isn’t a bug. i had to install this version from nvidia’s site
uninstalled the broken propriatary driver and well… Traceback (most recent call last):
File “/usr/bin/prime-select”, line 458, in
switcher.enable_profile(arg)
File “/usr/bin/prime-select”, line 241, in enable_profile
self._disable_nvidia(keep_nvidia_modules=True)
File “/usr/bin/prime-select”, line 269, in _disable_nvidia
self._update_initramfs()
File “/usr/bin/prime-select”, line 404, in _update_initramfs
proc = subprocess.Popen([‘update-initramfs’, ‘-u’],stdout=subprocess.PIPE)
File “/usr/lib/python3.10/subprocess.py”, line 966, in init
self._execute_child(args, executable, preexec_fn, close_fds,
File “/usr/lib/python3.10/subprocess.py”, line 1842, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: ‘update-initramfs’
somehow have prime now after instaling 5 diffrent things, but i am havng trouble. roblox uses xdg open, and cause of this, it bypasses the flatseal rule to use nvidia card, any idea how to fix this? blender also has trouble
