525.60.11 proprietary kernel version won't boot with Dell Precision T7760 Laptop
After installing the proprietary 525.60.11 on my Dell Precision T7760 laptop, but grub menu comes up, but then
the system hangs and is not accessibly remotely with ssh,
the screen is dark and the keyboard unresponsive. One must
power down with the power switch, then power up and in the
grub menu select a oldler kernel version and either install 510 or the open-kernel version of 525.60.11.
So I can’t get any information from the frozen state, but with the open-kernel 525.60.11 the out put from “nvidia-smi -q” is:
==============NVSMI LOG==============
Timestamp : Thu Jan 5 09:54:39 2023
Driver Version : 525.60.11
CUDA Version : 12.0
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : NVIDIA RTX A3000 Laptop GPU
Product Brand : NVIDIA RTX
Product Architecture : Ampere
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Disabled
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-417ead46-fcb2-4593-f174-2f1cda4562be
Minor Number : 0
VBIOS Version : 94.04.42.40.02
MultiGPU Board : No
Board ID : 0x100
Board Part Number : N/A
GPU Part Number : 24B8-926-A1
Module ID : 0
Inforom Version
Image Version : G001.0000.03.03
OEM Object : 2.0
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GSP Firmware Version : 525.60.11
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x24B810DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x0A6A1028
GPU Link Info
PCIe Generation
Max : 4
Current : 2
Device Current : 2
Device Max : 4
Host Max : 4
Link Width
Max : 16x
Current : 8x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 1240000 KB/s
Rx Throughput : 0 KB/s
Atomic Caps Inbound : N/A
Atomic Caps Outbound : N/A
Fan Speed : N/A
Performance State : P5
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 6144 MiB
Reserved : 349 MiB
Used : 735 MiB
Free : 5058 MiB
BAR1 Memory Usage
Total : 8192 MiB
Used : 7 MiB
Free : 8185 MiB
Compute Mode : Default
Utilization
Gpu : 28 %
Memory : 9 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 55 C
GPU Shutdown Temp : 98 C
GPU Slowdown Temp : 95 C
GPU Max Operating Temp : 87 C
GPU Target Temperature : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : N/A
Power Draw : 17.72 W
Power Limit : N/A
Default Power Limit : N/A
Enforced Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : 375 MHz
SM : 375 MHz
Memory : 810 MHz
Video : 555 MHz
Applications Clocks
Graphics : 1560 MHz
Memory : 5501 MHz
Default Applications Clocks
Graphics : 1560 MHz
Memory : 5501 MHz
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 1740 MHz
SM : 1740 MHz
Memory : 5501 MHz
Video : 1530 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : 631.250 mV
Fabric
State : N/A
Status : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 79215
Type : G
Used GPU Memory : 396 MiB
Process ID : 79631
Type : G
Used GPU Memory : 152 MiB
Process ID : 79642
Type : G
Used GPU Memory : 95 MiB
Process ID : 79803
Type : G
Used GPU Memory : 3 MiB
Process ID : 79809
Type : G
Process ID : 79834
Type : G
Used GPU Memory : 35 MiB
Process ID : 79836
Type : G
Used GPU Memory : 43 MiB
Ubuntu just released 525.78.01 for 20.04 LTS. This version
still has the very same problem with the proprietary kernel
version. The open kernel version no longer requires the modprobe.d workaround for the nvidia tools to recognize the GPU, but loading
the proprietary kernel version results in a frozen machine on boot.
Ubuntu finally just released 525.85.05 for 20.04 LTS. It seems to have fixed this problem for the Dell T7760!
