560 release feedback & discussion
I don’t know if this is the crash I reported first in version 555. But thank you anyway for keeping track of UE bugs.
I will try the new version (560.31.02) and submit any issues I encounter.
Is anyone able to repro the issue where if vrr is enabled and in use (on one monitor even), the idle power draw is higher? For me my rtx 3070 normally only uses 11W or so on idle, however with vrr enabled it is closer to 40W.
pls nvidia, i am using 560.31.02 and gtx 1650
dvi port is broken since frist beta of 555, its still broken with 560.31.02, please fix it, it works with 550 and older
Hi @omarhanykasban706, This is under investigation - 4757907. Please follow Bug :nvidia-drivers-555.58 DVI output not working ->black screen for updates. We do not have a fix yet. Thank you
I still have frequent crashes on Arch on Standard and Beta (130.0b1) Firefox with and without MOZ_ENABLE_WAYLAND=0 , I’ve rolled back to the 555 branch
dmesg says this
[ 1668.014899] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 1668.018605] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 1668.032789] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 1668.032861] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 1668.035868] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 1668.035936] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 1668.065949] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 1668.066029] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 1675.497744] kitty[104809]: segfault at 418 ip 000071a9f408223c sp 00007ffef1937120 error 4 in glfw-wayland.so[1923c,71a9f4070000+20000] likely on CPU 7 (core 1, socket 0)
[ 1675.497753] Code: fe ff 0f b6 c0 48 8b 5d f8 c9 c3 0f 1f 00 f3 0f 1e fa 55 48 89 e5 53 48 89 fb 48 83 ec 08 8b 3d 12 95 05 00 ff 15 dc 8b 03 00 <48> 8b b8 18 04 00 00 48 85 ff 74 18 48 89 de ff 15 a7 8c 03 00 48
[ 1675.650948] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1675.707174] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1675.710612] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1687.634636] NVRM: nvCheckOkFailedNoLog: Check failed: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057) returned from gpuGetByHandle(pClient, pArgs->hObject, NULL, &pGpu) @ rmapi_gss_legacy_control.c:93
[ 1796.848893] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1796.868091] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1796.878485] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1796.917140] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1796.928443] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.081329] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.097435] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.108716] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.127615] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.142387] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.178504] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.186135] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.511760] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.524614] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.545207] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.559340] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.576658] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.590088] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.601129] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.621447] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.627981] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.631649] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.639971] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.659317] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.839772] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.841239] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.842809] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.844381] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.846015] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.847602] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.849211] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.850771] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.852316] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.853903] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.855655] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.857246] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.858869] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.860469] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.862129] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.863761] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.865356] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.979041] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.983062] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1797.995619] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.011680] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.025150] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.035658] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.051179] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.066451] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.081619] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.101719] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.118243] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.128461] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.143025] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.157139] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.168324] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.170889] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.173658] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.183912] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.199652] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1798.239006] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1846.228706] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 1934.343735] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2049.259701] perf: interrupt took too long (2505 > 2500), lowering kernel.perf_event_max_sample_rate to 79000
[ 2058.826932] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.828470] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.830014] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.831678] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.833273] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.834930] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.836494] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.838065] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.839631] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.841190] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.842738] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.844299] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.845886] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.847482] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.849051] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.850725] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2058.852407] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2326.974777] perf: interrupt took too long (3152 > 3131), lowering kernel.perf_event_max_sample_rate to 63000
[ 2414.627122] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2414.823648] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2414.959908] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2414.988356] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.000231] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.013205] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.041344] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.228210] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.241227] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.249523] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.260181] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.267934] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.275867] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.281304] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.283048] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.295212] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.318664] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.451227] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.460084] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.472511] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.480656] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.491318] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.498803] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.508901] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.524048] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.611011] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.629568] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.639707] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.649210] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.670286] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2415.672378] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2440.389571] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2849.431127] kitty[149478]: segfault at 418 ip 00007b8aa418323c sp 00007ffd6a5ba0a0 error 4 in glfw-wayland.so[1923c,7b8aa4171000+20000] likely on CPU 11 (core 5, socket 0)
[ 2849.431148] Code: fe ff 0f b6 c0 48 8b 5d f8 c9 c3 0f 1f 00 f3 0f 1e fa 55 48 89 e5 53 48 89 fb 48 83 ec 08 8b 3d 12 95 05 00 ff 15 dc 8b 03 00 <48> 8b b8 18 04 00 00 48 85 ff 74 18 48 89 de ff 15 a7 8c 03 00 48
[ 2850.133895] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2850.133977] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2851.713009] kitty[149707]: segfault at 418 ip 000078108b98323c sp 00007fff5bb18ec0 error 4 in glfw-wayland.so[1923c,78108b971000+20000] likely on CPU 4 (core 4, socket 0)
[ 2851.713022] Code: fe ff 0f b6 c0 48 8b 5d f8 c9 c3 0f 1f 00 f3 0f 1e fa 55 48 89 e5 53 48 89 fb 48 83 ec 08 8b 3d 12 95 05 00 ff 15 dc 8b 03 00 <48> 8b b8 18 04 00 00 48 85 ff 74 18 48 89 de ff 15 a7 8c 03 00 48
[ 2852.387649] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2852.387699] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2852.393108] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2852.393162] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2852.405479] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2852.405578] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.098291] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.098360] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.184324] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.184400] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.334733] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.334789] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.340255] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.340317] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.373186] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.373839] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.422333] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.422390] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.897514] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.897577] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.913425] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2859.913492] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2860.135229] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2860.135276] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2860.147765] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2860.147833] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2860.167582] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2860.168610] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2860.184901] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2860.185825] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2860.211080] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2860.211221] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2860.235380] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2860.235435] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.132118] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.132207] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.154277] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.154335] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.417910] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.418029] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.434137] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.434205] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.454728] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.454806] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.476397] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.476480] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.584606] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.584686] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.596693] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.596808] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.697291] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.697353] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.717320] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.717373] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.733773] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.733819] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.748069] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2861.748124] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[ 2888.336151] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2888.337818] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2888.339578] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2888.341252] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2888.342883] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2888.344464] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2888.346071] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2889.450434] NVRM: rmapiUnmapWithSecInfo: Nv04Unmap: ummap failed; status: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057)
[ 2899.242220] NVRM: nvCheckOkFailedNoLog: Check failed: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057) returned from gpuGetByHandle(pClient, pArgs->hObject, NULL, &pGpu) @ rmapi_gss_legacy_control.c:93
and everything freezes to its last state when vram gets full, hyprland wayland
hyprctl version
Hyprland, built from branch main at commit b0a70f63e3865eaa77f0b78a04b230aa583bc95c  (wayland/compositor: drop pending buffer ref if synchronous).
Date: Tue Aug 6 18:08:22 2024
Tag: v0.41.2-169-gb0a70f63, commits: 5055
nvidia-bug-report.log.gz (577.5 KB)
wlroots just merged explicit sync support!
I compiled sway-git and wlroots-git and installed nvidia driver 560.31.02, and sway launches with explicit synchronization presumably enabled… but each one of my 3 monitors freezes after a few seconds when moving the mouse around on the empty desktop.
I’m using arch linux with kernel 6.10.3
Some kernel errors it’s spitting:
Aug 06 16:51:44 quat-desktop kernel: [drm:nv_drm_atomic_apply_modeset_config.isra.0 [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to initialize semaphore for plane fence
Aug 06 16:51:44 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to apply atomic modeset.  Error code: -11
Aug 06 16:51:52 quat-desktop kernel: [drm:nv_drm_atomic_apply_modeset_config.isra.0 [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to initialize semaphore for plane fence
Aug 06 16:51:52 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to apply atomic modeset.  Error code: -11
Aug 06 16:52:00 quat-desktop kernel: [drm:nv_drm_atomic_apply_modeset_config.isra.0 [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to initialize semaphore for plane fence
Aug 06 16:53:53 quat-desktop kernel: [drm:nv_drm_atomic_apply_modeset_config.isra.0 [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to initialize semaphore for plane fence
Aug 06 16:53:53 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to apply atomic modeset.  Error code: -11
Aug 06 16:53:54 quat-desktop kernel: [drm:nv_drm_atomic_apply_modeset_config.isra.0 [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to initialize semaphore for plane fence
Aug 06 16:53:54 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to apply atomic modeset.  Error code: -11
Aug 06 16:53:58 quat-desktop kernel: [drm:nv_drm_atomic_apply_modeset_config.isra.0 [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to initialize semaphore for plane fence
Aug 06 16:53:58 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to apply atomic modeset.  Error code: -11
Aug 06 16:54:10 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Flip event timeout on head 1
Aug 06 16:54:13 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Flip event timeout on head 2
Aug 06 16:54:16 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Flip event timeout on head 3
Aug 06 16:54:19 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Flip event timeout on head 1
Aug 06 16:54:22 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Flip event timeout on head 2
Aug 06 16:54:25 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Flip event timeout on head 3
Aug 06 16:54:33 quat-desktop kernel: [drm:nv_drm_atomic_apply_modeset_config.isra.0 [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to initialize semaphore for plane fence
Aug 06 16:54:33 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Failed to apply atomic modeset.  Error code: -11
Aug 06 16:54:39 quat-desktop kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000b00] Flip event timeout on head 2
nvidia-bug-report.log.gz (1.9 MB)
I had the same experience. I’m currently working around this issue with a patch to avoid sending IN_FENCE_FD in atomic commits, but this is not a real fix.
This issue is still occurring on 560. I’m unable to use HDR.
We’re just going to ignore the XWayland memory usage then?
Same issue here, but have you tried toggling the HDR with the kscreen-doctor command instead? For some weird reason leaving it enabled in the Plasma Display Configuration will freeze the system the next boot and login, but enabling it with kscreen-doctor the system will run just fine even if Plasma says HDR is not enabled.
Managed to get it to work after adding nvidia-drm.fbdev=1 nvidia-drm.modeset=1 to my kernel cmdline.
Using the NVIDIA UNIX Open Kernel Mode Setting Driver 560.31.02.
Starts now fine in Fedora 40, Wayland KDE Spin. Games also seem to work - tried Cyberpunk which ran without an issue.
560 with open module via nvidia-all, using nvidia-drm.modeset=1 nvidia_drm.fbdev=1 nvidia.NVreg_EnableGpuFirmware=0 as boot params. Having to force firefox(129)/thunderbird(115.13.0) to use xwayland I’m getting
firefox[5846]: [GFX1]: Error in eglSetDamageRegion: 0x3009
thunderbird[1654]: Crash Annotation GraphicsCriticalError: |[0][GFX1]: Error in eglSetDamageRegion: 0x3009
spammed to my journal, multiple times/sec. This wasn’t happening with 555. Trying to use firefox-developer-edition which is based on the 130 beta doesn’t do that, but is still a crashy mess with wayland backend so looks like there’s some bugs still there.
Running a game, in this case Horizon Forbidden West, causes
kernel: NVRM: nvAssertFailedNoLog: Assertion failed: pEventNotificationList->pendingEventNotifyCount == 0 @ event_notification.c:289
to be spammed to journal numerous times/sec, which again didn’t happen on 555.
nvidia-bug-report.log.gz (711.4 KB)
Will be heading back to 555 for the time being.
maybe the fix will only be released when a “new feature branch” driver drops, so probably 565 unfortunately.
Hi @jNines
Please confirm if running a game “Horizon Forbidden West” just spams the error messages or crashing game as well.
Also please confirm if you are using same boot params nvidia-drm.modeset=1 nvidia_drm.fbdev=1 nvidia.NVreg_EnableGpuFirmware=0 while launching the game.
For what it’s worth, I am not getting NVRM spam when running Horizon Forbidden West with the 560 proprietary modules.
Does nvidia.NVreg_EnableGpuFirmware=0 even have an affect with the open module? I thought the open module relies on GSP.
The game doesn’t crash just spams the logs. nvidia-drm.modeset=1 nvidia_drv.fbdev=1 I have been using for a few module versions. nvidia.NVreg_EnableGpuFirmware=0 was added with 555 as using Plasma felt like wading through jello without it.
After looking it up I see that’s not valid with the open module, and have since removed it, restarted, and checked again. All above errors still exist.
Same issue here with Microsoft Flight Simulator 2020. Game loads for a while but crashes with this error before it reaches the main menu.
Affected me on 555 and is still an issue on 560. Only affects Wayland. If I re-log on X11 it launches fine. Tried multiple versions of Proton, both official from Valve and unofficial community builds; Same result.
Hardware Information
  • CPU: AMD Ryzen 9 5950X 16-Core Processor
  • GPU: NVIDIA Corporation NVIDIA GeForce RTX 3090 Ti/PCIe/SSE2
  • RAM: 64GB DDR4-3200
  • Storage: 2TB Samsung 980 Pro nvme
Software Information
  • OS: Arch Linux
  • Kernel: 6.10.3-arch1-2
  • GPU Driver: nvidia-dkms-beta-560.31.02 from AUR
  • Kernel Parameters: GRUB_CMDLINE_LINUX_DEFAULT=“loglevel=3 nvidia_drm.modeset=1 nvidia_drm.fbdev=1 nvidia.NVreg_EnableGpuFirmware=0”
Interesting, I just tried enabling HDR using kscreen-doctor output.<output>.hdr.enable and it seems to be stable.
The colors are washed out, but that’s another issue.
Please fix! 555-560 drivers problematic!!! Tested on rtx 2060 and 4070. | Fedora ws 40
how to repeat:
  1. run the nvtop utility
  2. launch a xwayland-window (or native on 560 drivers) and change the window size.
  3. a memory leak occurs.
    relevant for 555 (with xwayland-window) and 560 (xwayland and native-window)
