570 release feedback & discussion
It’s happening again updating to nvidia-570.133.07-5 on arch. Same thing, Unity editor crashes after the splash screen. Only happening with Vulkan.
Can someone clue me in what’s going on here? This is the 3rd time. Since when does Unity require to play catch up with nvidia drivers? I really don’t understand.
Furthermore, how am I not able to fix this with downgrading? I’m downgrading all packages to a specific date yet this problem persists. Really hard to find out what’s going on. The crash report in case it helps anyone:
Thread 0x79ed177ff6c0 may have been prematurely finalized* Assertion at mono-threads.c:702, condition `info' not met, function:mono_thread_info_current,
An error has occured in the native fault reporting. Some diagnostic information will be unavailable.
	Native stacktrace:
	0x79ec9a91533e - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Data/MonoBleedingEdge/MonoEmbedRuntime/libmonobdwgc-2.0.so :
	0x79ec9aa5f41a - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Data/MonoBleedingEdge/MonoEmbedRuntime/libmonobdwgc-2.0.so : mono_assertion_message_disabled
	0x79ec9aa54a64 - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Data/MonoBleedingEdge/MonoEmbedRuntime/libmonobdwgc-2.0.so :
	0x79ec9aa55f2c - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Data/MonoBleedingEdge/MonoEmbedRuntime/libmonobdwgc-2.0.so :
	0x79ec9aa02918 - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Data/MonoBleedingEdge/MonoEmbedRuntime/libmonobdwgc-2.0.so :
	0x79ec9a9154d1 - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Data/MonoBleedingEdge/MonoEmbedRuntime/libmonobdwgc-2.0.so :
	0x79ec9a8bde72 - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Data/MonoBleedingEdge/MonoEmbedRuntime/libmonobdwgc-2.0.so :
	0x79ec9a843390 - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Data/MonoBleedingEdge/MonoEmbedRuntime/libmonobdwgc-2.0.so :
	0x57b387df2afc - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Unity :
	0x79ee9b41bcd0 - /usr/lib/libc.so.6 :
	0x79ed469e4764 - /usr/lib/libnvidia-glcore.so.570.133.07 :
	0x79ed4699631e - /usr/lib/libnvidia-glcore.so.570.133.07 :
	0x79ed46996462 - /usr/lib/libnvidia-glcore.so.570.133.07 :
	0x79ed469aa2f1 - /usr/lib/libnvidia-glcore.so.570.133.07 :
	0x57b3884b3aef - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Unity :
	0x57b3884b36d3 - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Unity :
	0x57b3884b1017 - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Unity :
	0x57b3884af5c5 - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Unity :
	0x57b3884aefc8 - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Unity :
	0x57b38802dba4 - /home/enzi/Unity/Hub/Editor/6000.0.45f1/Editor/Unity :
	0x79ee9b47370a - /usr/lib/libc.so.6 :
	0x79ee9b4f7aac - /usr/lib/libc.so.6 :
Hello. Seems there’s a regression in 32bit drivers with reporting power usage in mW.
mangohud issue here: GPU power draw shows wrong numbers with 32bit applications · Issue #1607 · flightlessmango/MangoHud · GitHub
paste with mangohud debug about random numbers:
64bit s unaffected.
570.124.04 and 570.133.07 both have the regression. (not sure about older 570 versions)
RTX 3080
can confirm this issue under Portal 2 as well.
I’m having increasing levels of seemingly random driver crashing, causing me to have to sysrq to reboot, screens go black and no output and cant switch TTY.
OpenSuse Tumbleweed version 20250409
| NVIDIA-SMI 570.133.07             Driver Version: 570.133.07     CUDA Version: 12.8     |
|   0  NVIDIA GeForce RTX 3080        On  |   00000000:2B:00.0  On |                  N/A |
| 30%   36C    P5             29W /  370W |    1314MiB /  10240MiB |     35%      Default |
|                                         |                        |                  N/A |
Apr 13 20:18:59 dreamscape kernel: nvidia-modeset: ERROR: GPU:0: The requested configuration of display devices (LHC 34C801 (DP-4), Ancor Communications Inc ROG PG278Q (DP-2)) is not supported on this GPU.
Apr 13 20:18:58 dreamscape kernel: nvidia-modeset: ERROR: GPU:0: The requested configuration of display devices (LHC 34C801 (DP-4), Ancor Communications Inc ROG PG278Q (DP-2)) is not supported on this GPU.
Apr 13 20:18:58 dreamscape kernel: ---[ end trace 0000000000000000 ]---
Apr 13 20:18:58 dreamscape kernel:  </TASK>
Apr 13 20:18:58 dreamscape kernel: R13: 00007f9b637fe920 R14: 0000000000000000 R15: 00007ffdda8e5470
Apr 13 20:18:58 dreamscape kernel: R10: 0000000000000000 R11: 00007f9be5534000 R12: 0000000000919890
Apr 13 20:18:58 dreamscape kernel: RBP: 0000000000000000 R08: 001151a1afe3c1de R09: 0000000000000007
Apr 13 20:18:58 dreamscape kernel: RDX: 00007f9b637fdd00 RSI: 00007f9b637fde30 RDI: 0000000000919890
Apr 13 20:18:58 dreamscape kernel: RAX: 0000000000000000 RBX: 000000000000000b RCX: 0000000000000000
Apr 13 20:18:58 dreamscape kernel: RSP: 002b:00007f9b637fdc60 EFLAGS: 00010246
Apr 13 20:18:58 dreamscape kernel: Code: Unable to access opcode bytes at 0x7f9be3ce16b5.
Apr 13 20:18:58 dreamscape kernel: RIP: 0033:0x7f9be3ce16df
Apr 13 20:18:58 dreamscape kernel:  asm_exc_page_fault+0x26/0x30
Apr 13 20:18:58 dreamscape kernel:  irqentry_exit_to_user_mode+0x12e/0x1c0
Apr 13 20:18:58 dreamscape kernel:  arch_do_signal_or_restart+0x2e/0x230
Apr 13 20:18:58 dreamscape kernel:  get_signal+0x81a/0x840
Apr 13 20:18:58 dreamscape kernel:  do_group_exit+0x30/0x80
Apr 13 20:18:58 dreamscape kernel:  do_exit+0x2f6/0xab0
Apr 13 20:18:58 dreamscape kernel:  task_work_run+0x5c/0x90
Apr 13 20:18:58 dreamscape kernel:  __fput+0xe6/0x2a0
Apr 13 20:18:58 dreamscape kernel:  nvidia_close+0x182/0x270 [nvidia 8ebdbeabd8f52d683953e9e0dd96bd4869b1872a]
Apr 13 20:18:58 dreamscape kernel:  ? nvidia_dev_put+0xa4/0xb0 [nvidia 8ebdbeabd8f52d683953e9e0dd96bd4869b1872a]
Apr 13 20:18:58 dreamscape kernel:  ? asm_exc_invalid_op+0x1a/0x20
Apr 13 20:18:58 dreamscape kernel:  ? exc_invalid_op+0x17/0x70
Apr 13 20:18:58 dreamscape kernel:  ? handle_bug+0x58/0x90
Apr 13 20:18:58 dreamscape kernel:  ? report_bug+0xff/0x140
Apr 13 20:18:58 dreamscape kernel:  ? __warn.cold+0x93/0xf7
Apr 13 20:18:58 dreamscape kernel:  <TASK>
Apr 13 20:18:58 dreamscape kernel: Call Trace:
Apr 13 20:18:58 dreamscape kernel: PKRU: 55555554
Apr 13 20:18:58 dreamscape kernel: CR2: 00007f9bb3fff990 CR3: 000000059e9dc000 CR4: 0000000000f50ef0
Apr 13 20:18:58 dreamscape kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 13 20:18:58 dreamscape kernel: FS:  0000000000000000(0000) GS:ffff94927eb80000(0000) knlGS:0000000000000000
Apr 13 20:18:58 dreamscape kernel: R13: ffffffffc1f3e2e0 R14: ffff948bca247ec0 R15: 000000000000000a
Apr 13 20:18:58 dreamscape kernel: R10: 0000000081000093 R11: 00000000ffffffff R12: ffff9490d3253000
Apr 13 20:18:58 dreamscape kernel: RBP: ffff948b8d7c66a8 R08: 0000000000000000 R09: ffffb35f46417ca8
Apr 13 20:18:58 dreamscape kernel: RDX: 0000000000000000 RSI: 0000000000000246 RDI: ffffb35f46417c30
Apr 13 20:18:58 dreamscape kernel: RAX: 0000000000000026 RBX: ffff948b8d7c6000 RCX: ffffb35f46417c80
Apr 13 20:18:58 dreamscape kernel: RSP: 0018:ffffb35f46417d00 EFLAGS: 00010202
Apr 13 20:18:58 dreamscape kernel: Code: 89 de 4c 89 e7 e8 fc de cb 00 85 c0 75 1c 5b 48 89 ef 5d 41 5c e9 8c 0d 98 c5 5b 48 c7 c7 90 e1 f3 c1 5d 41 5c e9 7c 0d 98 c5 <0f> 0b eb e0 0f 1f 84 00 00 00 00 00 90 90 90 90 90 90 90 90 90 90
Apr 13 20:18:58 dreamscape kernel: RIP: 0010:nvidia_dev_put+0xa4/0xb0 [nvidia]
Apr 13 20:18:58 dreamscape kernel: Hardware name: Micro-Star International Co., Ltd. MS-7C56/MPG B550 GAMING PLUS (MS-7C56), BIOS 1.C0 03/13/2023
Apr 13 20:18:58 dreamscape kernel: Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Apr 13 20:18:58 dreamscape kernel: CPU: 3 UID: 1000 PID: 521925 Comm: DesktopEditors Tainted: P        W  OE      6.14.1-1-default #1 openSUSE Tumbleweed 2cc20b4a18aadad6cc2b16587c7d4d6d6526cc98
Apr 13 20:18:58 dreamscape kernel:  mc acpi_cpufreq video wmi_bmof snd i2c_smbus soundcore k10temp libphy gpio_amdpt gpio_generic tiny_power_button nvme_fabrics nvme_keyring loop fuse efi_pstore dm_mod configfs nfnetlink ip_tables x_tables hid_generic usbhid ahci libahci libata polyval_clmulni polyval_generic ghash_clmulni_intel sd_mod sha512_ssse3 sha256_ssse3 xhci_pci scsi_dh_emc sha1_ssse3 scsi_dh_rdac xhci_hcd nvme scsi_dh_alua aesni_intel sg crypto_simd nvme_core ccp cryptd usbcore scsi_mod nvme_auth sp5100_tco scsi_common wmi button btrfs blake2b_generic xor raid6_pq msr efivarfs dmi_sysfs
Apr 13 20:18:58 dreamscape kernel: Modules linked in: binfmt_misc algif_hash af_alg af_packet nfnetlink_queue nf_conntrack_netlink ip6t_REJECT nf_reject_ipv6 ip6table_nat ip6table_filter ip6table_mangle ip6_tables xt_nat ipt_REJECT nf_reject_ipv4 xt_NFQUEUE xt_mark xt_connmark iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 iptable_mangle zram 842_decompress 842_compress lz4_compress lz4hc_compress snd_seq_dummy snd_hrtimer snd_seq qrtr rfkill vboxnetadp(O) vboxnetflt(O) vboxdrv(O) nf_tables nct6683 iptable_filter nvidia_drm(POE) nvidia_modeset(POE) nvidia_uvm(POE) nls_iso8859_1 nls_cp437 vfat fat nvidia(POE) amd_atl intel_rapl_msr intel_rapl_common snd_hda_codec_realtek snd_hda_codec_generic snd_hda_scodec_component snd_hda_codec_hdmi snd_hda_intel snd_usb_audio ee1004 edac_mce_amd battery snd_intel_dspcfg snd_usbmidi_lib snd_intel_sdw_acpi snd_hda_codec kvm_amd snd_ump snd_hda_core snd_rawmidi r8169 snd_hwdep snd_seq_device drm_ttm_helper realtek kvm snd_pcm mdio_devres ttm xpad i2c_piix4 snd_timer joydev ff_memless pcspkr
Apr 13 20:18:58 dreamscape kernel: WARNING: CPU: 3 PID: 521925 at nvidia/nv.c:4946 nvidia_dev_put+0xa4/0xb0 [nvidia]
Apr 13 20:18:58 dreamscape kernel: ------------[ cut here ]------------
Apr 13 20:18:58 dreamscape kernel: R10: 0000000081000096 R11: 0000000000000000 R12: ffff949264890000
nvidia-error.log (241.5 KB)
Full log output here
On another note, I never used to have this issue before but i have a heater next to me and if i accidentally kick it sometimes the power dips and causes my monitor to flicker, it’s always done this and been able to recover but now since like 570 the driver crashes every time without fail when it happens. What gives?
Are these memory allocation bugs ever getting fixed? Nevermind the horribly bad VRAM issues, I’m now getting DMESG errors about a use-after-free:
BUG: KFENCE: use-after-free read in _nv000177kms+0x439/0x2a10 [nvidia_modeset]
Use-after-free read at 0x000000000b59d00c (in kfence-#49):
_nv002879kms+0x665/0x9c0 [nvidia_modeset]
_nv000392kms+0x1e1/0x400 [nvidia_modeset]
_nv002878kms+0xf1a/0x11e0 [nvidia_modeset]
_nv002988kms+0x79c/0xd30 [nvidia_modeset]
nvKmsIoctl+0xf9/0x270 [nvidia_modeset]
nvkms_ioctl_from_kapi_try_pmlock+0x64/0xb0 [nvidia_modeset]
_nv000023kms+0x56b/0xbc0 [nvidia_modeset]
nv_drm_atomic_apply_modeset_config+0x4bb/0x830 [nvidia_drm]
nv_drm_atomic_commit+0xe6/0x460 [nvidia_drm]
drm_mode_atomic_ioctl+0xcbe/0xfd0
drm_ioctl_kernel+0xb0/0x100
drm_ioctl+0x277/0x4c0
__x64_sys_ioctl+0x97/0xc0
do_syscall_64+0x82/0x190
entry_SYSCALL_64_after_hwframe+0x76/0x7e
kfence-#49: 0x00000000568930e6-0x00000000ea117aa3, size=328, cache=kmalloc-512
allocated by task 1962 on cpu 1 at 118497.912379s (1.013790s ago):
 nvkms_alloc+0x50/0xa0 [nvidia_modeset]
_nv003020kms+0x22/0x40 [nvidia_modeset]
_nv002842kms+0x266/0x740 [nvidia_modeset]
_nv000719kms+0x40/0x60 [nvidia_modeset]
nvkms_ioctl_from_kapi+0x73/0xe0 [nvidia_modeset]
_nv000096kms+0x19d/0x240 [nvidia_modeset]
nv_drm_internal_framebuffer_create+0x332/0x4c0 [nvidia_drm]
nv_drm_framebuffer_create+0x99/0xc0 [nvidia_drm]
drm_internal_framebuffer_create+0xad/0x180
drm_mode_addfb2_ioctl+0x42/0xf0
freed by task 1962 on cpu 7 at 118498.746957s (0.179345s ago):
_nv000801kms+0x49/0x60 [nvidia_modeset]
_nv000110kms+0x4b/0x60 [nvidia_modeset]
nv_drm_framebuffer_destroy+0x3e/0x50 [nvidia_drm]
drm_mode_closefb_ioctl+0x11e/0x160
And XID errors:
Xid (PCI:0000:0c:00): 31, pid=34647, name=Render thread, Ch 00000048, intr 10000000. MMU Fault: ENGINE GRAPHICS GPC0 GPCCLIENT_PROP_0 faulted @ 0x0_00000000. Fault is of type FAULT_PTE ACCESS_TYPE_WRITE
And the usual:
[drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000c00] Failed to allocate NVKMS memory for GEM object
Suspend is still broken on open drivers on 570.
Maybe only a multi-monitor issue, but my main display never wakes up after waking up the computer. Switching back to the closed drivers does work fine however.
Here is the bug report from within repro state (captured on my second monitor whilst my main monitor was not working) nvidia-bug-report.log.gz (380.3 KB)
I can also recover the main screen by unplugging and replugging it back in. This is extremely tedious though.
I’m seeing corrupted menus in steam big picture and sometimes in from the drop down menus in steam.
nvidia-bug-report.log.gz (1.4 MB)
This is a known issue with Nvidia, you need to disable hardware acceleration for Steam unfortunately (then Big Picture becomes very shoppy).
Known issue.
See:
Is the 5060ti supported by this driver? Thinking about grabbing one tomorrow.
Irrelevant. This has been a continuous problem on several different versions of the driver. Including the latest (newer) production branch deiver
No, you will have to wait for a new driver
oh nice got released already Driver Details | NVIDIA
" * Fixed a bug that could cause the applications that use the VK_KHR_present_wait extension to hang on Wayland."
Glad to see this is finally out of the Vulkan-Beta drivers.
I assume the " COLOR_ENCODING and COLOR_RANGE" changes will let an HDR Wayland session set color spaces properly?
Update:
The bug I reported about ctm freeze looks to be fixed on 575. Thanks for your work!
With 575.51.02 drivers it reports 8mW with 32bit applications. 64bit unaffected
[2025-04-16 22:15:23.005] [MANGOHUD] [debug] Raw power usage (mW): 8
[2025-04-16 22:15:23.031] [MANGOHUD] [debug] Raw power usage (mW): 8
[2025-04-16 22:15:23.058] [MANGOHUD] [debug] Raw power usage (mW): 8
[2025-04-16 22:15:23.085] [MANGOHUD] [debug] Raw power usage (mW): 8
[2025-04-16 22:15:23.111] [MANGOHUD] [debug] Raw power usage (mW): 8
can confirm that instead of power draw readings being extremely large, they are now extremely small, too small to be displayed through MangoHud. Debug shows small values like yours.
A 575 series thread was started.
It just hasn’t been pinned yet:
Operating System: Manjaro Linux
KDE Plasma Version: 6.3.4
KDE Frameworks Version: 6.12.0
Qt Version: 6.9.0
Kernel Version: 6.12.21-4-MANJARO (64-bit)
Graphics Platform: X11
Processors: 16 × AMD Ryzen 7 5800X 8-Core Processor
Memory: 31.3 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 3060 Ti
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: B550I AORUS PRO AX
What is wrong with video colors? - #5 by Edward78 - Graphics & Display - Manjaro Linux Forum 3rd post here, the mod says.
This is still the 570.133.07 for me.
I think the packages libnvidia-egl-xcb1 and libnvidia-egl-xlib1 on the Debian 12 repos need to be updated to version 570.133.20, as they are still version 570.124.06
