570 release feedback & discussion
This seems to have done the trick, at least as far as random freezes go.
I’m unsure on when I enabled it back and why, but at least the system is usable now.
I’m now facing a different issue, when powering on with external screens connected Fedora is booting into recovery mode and everything is unresponsive, I cannot even “press enter to continue”.
Thankfully this is “easily” circumvented by just unplugging everything, booting, logging in, connecting the screens, logging out (as they don’t seem to be recognized) and then logging back in.
It’s a hassle and a time-sink but it works for now.
Lenovo Legion laptops are perhaps the worst supported Linux desktop under the sun. I tried to use one a year ago, I wiped Linux off of it almost immediately.
KDE freezes and stops working when using HDMI external monitor. Laptop, Xserver, Manjaro, 6.14 kernel. 570.144 drivers.
Mirror external and internal monitors works better but still unstable, sole external monitor doesn’t work.
550 drivers worked normally before and worked in particular on 6.13 kernel and with dkms drivers version.
nvidia-bug-report.gz (422.1 KB)
P.S. Yes, 550 dkms drivers still work normally with KDE and the external monitor on 6.14 kernel.
Processing: nvidia-bug-report.log.gz…
Hi! my nvidia-smi hangs after printing only the headers and not my RTX4060. Ubuntu 25.04
journalctl item: ‘mai 06 12:24:50 jkp /usr/bin/nvidia-powerd[2045]: Found unsupported configuration. Exiting…’
GPU is fully functioning, discoverable by all other methods, works on the same pc in windows and pop!os 24.04.
We just got a 5070 card. I installed 570.144 and I’m getting this from X windows:
[ 11021.291] (II) NVIDIA GLX Module 570.144 Thu Apr 10 20:06:53 UTC 2025
[ 11021.291] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 11021.317] (EE) NVIDIA(GPU-0): The NVIDIA GPU at PCI:1:0:0 is not supported by the 570.144
[ 11021.317] (EE) NVIDIA(GPU-0): NVIDIA driver.
[ 11021.317] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[ 11021.317] (EE) NVIDIA(0): Failing initialization of X screen
uname -a:
5.16.14-100.fc34.x86_64 #1 SMP PREEMPT Fri Mar 11 20:24:01 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
I know, it’s an old kernel. Is that why I’m getting this error? It seems to compile and install just fine.
I’ve talked to other people that are using KDE and a 3070 and can enable HDR. The only time I could enable HDR was with the Nobara USB installation, while using it, I could enable HDR with the Nobara 41 Rescue disk.
nvidia-bug-report.log (1.7 MB)
Are you using the open source kernel module? From Blackwell the closed-source kernel module cannot be used. This happens e.g. if you upgrade from an older Nvidia card and still run the older driver.
dmesg.txt (81.2 KB)
journalctl.txt (11.9 KB)
nvidia-bug-report.log.gz (209.2 KB)
Screen Freeze bug still not fixed on nvidia-open-570.144-5.
Update: Issue is recreatable in LTS kernel
In addition to the problems already mentioned, my laptop won’t shut down when hibernating. There are no error logs, and the NVIDIA logs report that the process is successful. However, the laptop turns off the screen and doesn’t respond, but it never shuts down completely.
This didn’t happen with previous versions.
hibernate works again if i boot the system without loading nvidia modules.
the latest logs
15/5/25 16:25	systemd	Reached target Sleep.
15/5/25 16:25	systemd	Starting NVIDIA system hibernate actions...
15/5/25 16:25	systemd	nvidia-hibernate.service: Deactivated successfully.
15/5/25 16:25	systemd	Finished NVIDIA system hibernate actions.
15/5/25 16:25	systemd	nvidia-hibernate.service: Consumed 1.863s CPU time, 4.9M memory peak.
15/5/25 16:25	systemd	Starting System Hibernate...
15/5/25 16:25	systemd-sleep	User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0).
15/5/25 16:25	systemd-sleep	This is not recommended, and might result in unexpected behavior, particularly
15/5/25 16:25	systemd-sleep	in suspend-then-hibernate operations or setups with encrypted home directories.
15/5/25 16:25	systemd-sleep	Performing sleep operation 'hibernate'...
nvidia-bug-report.log.gz (1.5 MB)
RTX 5090, Debian 13 (6.12.22-amd64) - Nvidia Driver Version: 570.144 - Dual MIT/GPL official open-source kernel module. Gnome, x11
After each reboot when I open an app (e.g. chrome, Webstorm) I experience a freezing/lock on the system - from several seconds to 1 min.
During the freeze, keyboard is active, mouse is active, videos are mostly playing but sometimes goes into loading state, super key is active, and I can show the gnome app search dash view. However, icons are loading on the app search. Apps or desktop environment (Gnome) is not responsive and pops up Force Quit or Wait dialog. If the terminal was open, when I type a command and send it, terminal does not respond and stays stale non-responsive. App that I’m interacting instantly shows Force Quit dialog.
This issue however, mostly does not happen 2nd time on the same session. It’s mostly reproducible after each reboot.
This issue is not reproducible on Windows 11.
There are no relevant logs in the journalctl at the time of incident. What is the best way to catch nvidia logs at the incident time?
Is this potentially related with the other freezing issues?
I would like to apologize to the nvidia team i made the mistake reporting an issue on 570 driver when i put on 575, here is the issue.
Hi. My distro (Linux Mint) just switched to nvidia-driver Version 570.133.07-0ubuntu0.24.04.1 and a new bug has appeared. Randomly hdmi audio stops getting piped to my TV. On my end I see no bugs or issues. In Pulse Audio it sees the HDMI output as still valid and has a little sound bar of the audio bouncing as it sends audio to my TV, but nothing comes out.
Rebooting fixes the issue. Also unplugging the hdmi cable and plugging it back in fixes the issue.
As a temporary fix anyone know how to refresh or reload the drivers without a system reboot? (edit: If I turn my display port monitor on and off the HDMI audio fixes. I guess disabling one of two monitors resets something.)
This is a pretty bad bug on my end. I might have to downgrade back to the 550 drivers.
Hibernation does not work ubuntu in Ubuntu 25.04 , plucky
Kde plasma with X or Wayland > 6.3.4-0ubuntu1
Nvdia installed :
570.144-0ubuntu0~gpu25.04.1
Hardware:
NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] Subsystem: ZOTAC International
Mainboard:
MS-7B79 X470 GAMING PRO
RAM
DIMM DDR4 Synchron Unbuffered (Unregistered) 2133
CPU
AMD Ryzen 7 2700X Eight-Core Processor
Errors:
(side error: nvidia: module verification failed: signature and/or required key missing - tainting kernel )
i can’t find specific errors related to the hibernation.
the system wakes up, i get a mouse pointer and the screen stays blank.
so i am not sure if it’s driver related or plasma
I’m getting a sporadic screen freeze. The game won’t crash, the audio keeps playing, and eventually it recovers, but sometimes the image is frozen for several seconds. I believe I’ve noticed this happening in other games, but it’s far more noticeable in Kingdom Come: Deliverance II (VKD3D).
This is on a RTX 5090 FE using 570.144-5. This is on Arch with GNOME.
In this sample the freeze occurred at (May 18th) 23:56 where I see this in the journalctl repeatedly
May 18 23:56:07 revachol gnome-shell[1434]: g_object_get_qdata: assertion ‘G_IS_OBJECT (object)’ failed
dmesg.txt (150.1 KB)
journalctl.txt (142.1 KB)
nvidia-bug-report.log.gz (599.5 KB)
A small example of the freeze:
I was opening some youtube video tabs and got a gpu driver crash that froze all screens and couldn’t recover graphics via ssh without rebooting the system.
RTX 5070 Ti
arch linux 6.14.6-arch1-1
nvidia-open 570.144-5
I saved this from the journal over ssh:
May 18 23:55:00 kernel: NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
May 18 23:55:00 kernel: x86/PAT: ThreadPoolForeg:1595890 conflicting memory types 400f4a0000-4010090000 uncached-minus<->write-combining
May 18 23:55:00 kernel: x86/PAT: memtype_reserve failed [mem 0x400f4a0000-0x401008ffff], track write-combining, req write-combining
May 18 23:55:00 kernel: ioremap memtype_reserve failed -16
May 18 23:55:00 kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Failed to ioremap_wc NvKmsKapiMemory 0x00000000cccceb75
May 18 23:55:00 kernel: NVRM: GPU at PCI:0000:01:00: GPU-c56c7bb9-04bc-5ad6-729d-7cdf1783f039
May 18 23:55:00 kernel: NVRM: GPU Board Serial Number: 0
May 18 23:55:00 kernel: NVRM: Xid (PCI:0000:01:00): 31, pid=1582480, name=chromium, Ch 00000045, intr 00000000. MMU Fault: ENGINE GR_HOST0 HUBCLIENT_ESC0 faulted @ 0x0_0402a000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
May 18 23:55:00 kernel: NVRM: krcCheckBusError_KERNEL: PCI-E corelogic status has pending errors (CL_PCIE_DEV_CTRL_STATUS = 00010020):
May 18 23:55:00 kernel: NVRM: krcCheckBusError_KERNEL:      _CORR_ERROR_DETECTED
May 18 23:55:01 chromium[1582480]: [53:53:0519/065500.999681:ERROR:gpu/command_buffer/service/shared_context_state.cc:1325] SharedContextState context lost via ARB/EXT_robustness. Reset status = GL_GUILTY_CONTEXT_RESET_KHR
May 18 23:55:01 chromium[1582480]: [53:53:0519/065501.001099:ERROR:components/viz/service/gl/gpu_service_impl.cc:1173] Exiting GPU process because some drivers can't recover from errors. GPU process will restart shortly.
May 18 23:55:01 chromium[1582419]: [2:2:0519/065501.019676:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=8704
May 18 23:55:23 kwin_wayland[1476032]: kwin_scene_opengl: A graphics reset attributable to the current GL context occurred.
I saw elsewhere in this thread a few mentions of “dmaAllocMapping_GM107” too
So I use 570.153.02 and also see freeze in the desktop x.org on ubuntu 25.04. not tried wayland.
don’t get any error in journal or dmesg desktop just stops reponding for several seconds.
I’m having a problem and I don’t know how to solve it. I bought an RTX 5070 TI and sometimes the monitor turns off, stopping the video and the GPU fans start to make a lot of noise. I only restart the PC to get it working again. This happens randomly, but if I run something heavy it happens faster. Does anyone know how to solve it? I’ve already installed driver versions 570.144 and 570.153, both have the same problem.
Maybe you have this issue 570 Random Freeze: GPU has fallen off the bus
