590 release feedback & discussion
Performance limiters are broken on Blackwell:
This was seen on 580, but I doubt it was fixed in 590.
Hi @eplklzip
We have filed a bug 5740841 internally for tracking purpose.
However, we are not able to duplicate issue locally with 590 drivers.
Could provide game settings and repro frequency for further testing.
Thanks in advance.
stalker-2-crash-590-drivers-nvidia-report.zip (731.5 KB)
Archive includes:
  1. UE crash dumps
  2. Proton log
  3. Game settings
Repro frequency: it crashes every single time when trying to load a saved game, or start a new game. No such issue after reverting to 580 drivers.
Forgot one more settings file
AppliedSettingsWin64.zip (2.3 KB)
i can second this!
“Stable” driver dropped.
As I said, “beta” means nothing. Distros could have and should have packaged and shipped the 590 driver.
This has been atleast the second or third time now where people claim “beta” drivers are some special opportunity to get feedback before the stable “production” drivers are released. They are not.
Just did the update, my fps on Rocket League jumped from ~380fps (580) to ~450fps (590), just like Windows.
Nice job!
monster hunter wilds works again on the new driver!
Stalker 2 crashes still but for some reason works on pikaos 4
performance is alot better than the beta so glad that got fixed thanks!
all in all great release! and VRR on hyprland is amazing!
Stream i did with the driver on cachyos
I am experiencing severe system latency and frequent audio Xruns (stuttering) on an Arch-based system running Kernel 6.13 with an RTX 3070.
Technical Problem: The GPU is currently forced onto IRQ 16, which is shared with multiple PCIe Root Ports on my Z690 motherboard. This shared legacy interrupt line is causing significant processing delays, especially when using the NVIDIA Open Kernel Modules.
Key Details:
  • Hardware: Intel i7-13700KF | RTX 3070 | Z690 Chipset.
  • Driver: 590.xx (Open Modules).
  • Architecture: System is optimized for x86-64-v3.
  • Symptoms: Audio dropouts and micro-stuttering under GPU load.
Request: It appears that MSI (Message Signaled Interrupts) is not being correctly utilized or remapped for the GPU on this specific chipset with the current open drivers.
  1. Is there a known workaround to force MSI on the open modules for Z690?
  2. Will the upcoming v590 driver address IRQ sharing and improve interrupt handling for the open-source kernel modules?
    nvidia-bug-report.log.gz (634.2 KB)
Monster Hunter Wilds finally loads past the intro screens with these new drivers, however there are tons of artifacts that make the performance unplayable
nvidia-bug-report.log.gz (794.0 KB)
This driver is not marked stable/production though, 590 is a “New Feature Branch” described as:
This driver provides early adopters and bleeding edge developers
access to the latest driver features before they are integrated
into the Production Branches.
Edit:
In Gentoo we treat the 3 types of drivers that way (just saying, maybe could inspire other distros):
Beta: opt-in only, no users gets it unless they ask for it
NFB: only users of the ~testing “branch” of Gentoo gets it
Production: ~testing users get it first, then users get it in our stable “branch” after 20-30 days usually unless it’s causing some major problems where we may wait for the next version (did that for 580.105.08 because of the hdmi / low resolution issues)
(we also keep each still-supported driver branches to let users easily downgrade if needed, currently 535, 570, 580, and 590 – legacy unsupported 390 and 470 are also still there for now but treated a bit differently due to being a security hazard among other things)
was any progress made since, that would come in a future 590.X release? can’t ask there since it’s still locked as “resolved” :/
Please support the EGL_EXT_config_select_group extension to support 10-bit color on GNOME/Mutter. [Feature Request] Implement EGL_EXT_config_select_group to enable 10-bit/HDR on GNOME (Mutter)
I looked up bug 5622970 and it’s still being worked on. I un-resolved and unlocked the thread you linked to, thanks for pointing out that it was incorrectly closed.
I didn’t see that label on the driver page but regardless, there aren’t any new features in 590 which makes the label meaningless just like “beta”.
I appreciate Gentoo trying to be more flexible than most distros but I was really asking for the ability to select any driver from any somewhat recent driver series. If Nvidia merges broken code from 590 into 580, it makes the whole thing kinda pointless otherwise.
Is 10-bit color the reason HDR is still broken even with the vulkan drivers?
Last time I tried HDR on gnome it worked but you needed the vulkan HDR layer package installed, but that was because the driver was missing HDR vulkan extensions (which have been added to the vulkan beta driver, but aren’t in this one afaik)
I tried it and the only HDR thing that worked properly was maybe YouTube videos. Gnome and games looked washed out among other issues exactly like without the vulkan beta drivers.
this is still happening on 590.48.01
try running games in wine Wayland with HDR enabled and the wsi flag, it works, it’s just a bunch of work without the extension
