[595.112.07] glXBindTexImageEXT SIGSEGV on DRI3-imported linear XRGB8888 pixmap
angle uses this path in vaapi, i get a sigsegv on my 4090 every time. not sure if this is a regression or not.
this is a reproducer
// crash: glXBindTexImageEXT on a linear DRI3 dma-buf (modifier 0).
// build: cc -O1 -o crash crash.c $(pkg-config --libs --cflags gl x11 x11-xcb xcb-dri3 gbm)
#include <GL/gl.h>
#define GLX_GLXEXT_PROTOTYPES 1
#include <GL/glx.h>
#include <GL/glxext.h>
#include <X11/Xlib-xcb.h>
#include <gbm.h>
#include <fcntl.h>
#include <stdio.h>
#include <string.h>
#include <unistd.h>
#include <xcb/dri3.h>
#define W 64
#define H 64
static int xerr;
static int onerr(Display *d, XErrorEvent *e) { xerr = e->error_code; return 0; }
int main(int argc, char **argv) {
    // argv[1]: "linear" (crashes) or "mod" (server-advertised tiled, works).
    const char *mode = argc > 1 ? argv[1] : "linear";
    int use_mod = strstr(mode, "mod") != NULL;
    setbuf(stdout, NULL);
    Display *dpy = XOpenDisplay(NULL);
    XSetErrorHandler(onerr);  // record, do not abort
    if (!dpy) return puts("no display"), 1;
    int scr = DefaultScreen(dpy);
    Window win = RootWindow(dpy, scr);
    int attrs[] = {GLX_DRAWABLE_TYPE, GLX_PIXMAP_BIT | GLX_WINDOW_BIT, GLX_RENDER_TYPE, GLX_RGBA_BIT,
                   GLX_BIND_TO_TEXTURE_RGB_EXT, True,
                   GLX_BIND_TO_TEXTURE_TARGETS_EXT, GLX_TEXTURE_2D_BIT_EXT,
                   GLX_RED_SIZE, 8, GLX_GREEN_SIZE, 8, GLX_BLUE_SIZE, 8, None};
    int ncfg = 0;
    GLXFBConfig *cfg = glXChooseFBConfig(dpy, scr, attrs, &ncfg);
    if (!ncfg) return puts("no fbconfig"), 1;
    XVisualInfo *vi = glXGetVisualFromFBConfig(dpy, cfg[0]);
    // A GLXWindow is required: making the context current to a plain X window makes the
    // driver bind with no valid drawable and memcpy from NULL even for good buffers.
    XSetWindowAttributes swa = {.colormap =
        XCreateColormap(dpy, win, vi->visual, AllocNone)};
    Window gw = XCreateWindow(dpy, win, 0, 0, W, H, 0, vi->depth, InputOutput,
                              vi->visual, CWColormap, &swa);
    GLXWindow glxwin = glXCreateWindow(dpy, cfg[0], gw, NULL);
    GLXContext ctx = glXCreateNewContext(dpy, cfg[0], GLX_RGBA_TYPE, NULL, True);
    glXMakeContextCurrent(dpy, glxwin, glxwin, ctx);
    xcb_connection_t *xcb = XGetXCBConnection(dpy);
    xcb_generic_error_t *err = NULL;
    int flags = use_mod ? GBM_BO_USE_RENDERING : GBM_BO_USE_LINEAR | GBM_BO_USE_WRITE;
    int fd_gpu = open("/dev/dri/renderD128", O_RDWR | O_CLOEXEC);
    struct gbm_device *gdev = gbm_create_device(fd_gpu);
    struct gbm_bo *bo;
    if (use_mod) {
        xcb_dri3_get_supported_modifiers_reply_t *m =
            xcb_dri3_get_supported_modifiers_reply(xcb,
                xcb_dri3_get_supported_modifiers(xcb, win, vi->depth, 32), &err);
        if (!m || err) return puts("no modifiers"), 1;
        bo = gbm_bo_create_with_modifiers(gdev, W, H, GBM_FORMAT_XRGB8888,
                    xcb_dri3_get_supported_modifiers_screen_modifiers(m),
                    m->num_screen_modifiers);
    } else {
        bo = gbm_bo_create(gdev, W, H, GBM_FORMAT_XRGB8888, flags);
    if (!bo) return puts("gbm_bo_create failed"), 1;
    uint32_t stride;
    void *map;
    uint32_t *px = gbm_bo_map(bo, 0, 0, W, H, GBM_BO_TRANSFER_WRITE, &stride, &map);
    if (px) {  // tiled buffers are not CPU-mappable
        for (int i = 0; i < W * H; i++) px[i] = 0x00ff0000;
        gbm_bo_unmap(bo, map);
    int fd = gbm_bo_get_fd(bo);
    printf("buffer modifier=0x%llx pitch=%u\n",
           (unsigned long long)gbm_bo_get_modifier(bo), gbm_bo_get_stride(bo));
    // Explicit import with the buffer's own modifier and a correct size; the legacy
    // request has no modifier field and fails or binds wrong for tiled buffers.
    Pixmap pm = xcb_generate_id(xcb);
    uint32_t pitch = gbm_bo_get_stride(bo);
    off_t size = lseek(fd, 0, SEEK_END);
    xcb_dri3_pixmap_from_buffers(xcb, pm, win, 1, W, H, pitch, 0, 0, 0, 0, 0, 0, 0,
                                 vi->depth, 32, gbm_bo_get_modifier(bo), &fd);
    XSync(dpy, False);
    printf("imported pixmap=0x%lx size=%jd pitch=%u\n", (unsigned long)pm, (intmax_t)size, pitch);
    int pattrs[] = {GLX_TEXTURE_TARGET_EXT, GLX_TEXTURE_2D_EXT,
                    GLX_TEXTURE_FORMAT_EXT, GLX_TEXTURE_FORMAT_RGB_EXT, None};
    GLXPixmap gp = glXCreatePixmap(dpy, cfg[0], pm, pattrs);
    XSync(dpy, False);
    GLuint tex;
    glGenTextures(1, &tex);
    glBindTexture(GL_TEXTURE_2D, tex);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
    printf("binding...\n");
    xerr = 0;
    glXBindTexImageEXT(dpy, gp, GLX_FRONT_EXT, NULL);
    static unsigned char got[W * H * 4];  // full texture: glGetTexImage writes W*H*4
    XSync(dpy, False);
    glGetTexImage(GL_TEXTURE_2D, 0, GL_RGBA, GL_UNSIGNED_BYTE, got);
    int c = (H / 2 * W + W / 2) * 4;
    printf("X error %d, GL error 0x%x, center RGBA = %d %d %d %d\n",
           xerr, glGetError(), got[c], got[c+1], got[c+2], got[c+3]);
    return 0;
I can reproduce using the provided program with drivers version 595.104.02 on FreeBSD.
