[595.84] Reproducible SIGSEGV in libnvidia-glcore.so during OpenGL draw (OpenSceneGraph/OpenMW), RTX 4080 Laptop — same crash in Windows
System
  • GPU: NVIDIA GeForce RTX 4080 Laptop (AD104M), 12GB
  • CPU: Intel i9-13900HX (hybrid laptop: Intel UHD iGPU + dGPU, MUX-capable)
  • Laptop: Clevo X370SNV-G, BIOS 1.07.14aLS1
  • OS: Nobara Linux 44 (Fedora-based), KDE Plasma, Wayland
  • Driver: 595.84 (open kernel module)
  • Display: external LG 27GN880-B 2560x1440@144Hz over the dGPU + internal panel
Summary
The application openmw (open-source Morrowind engine, native Linux, OpenGL via OpenSceneGraph 3.6) segfaults inside libnvidia-glcore.so.595.84 during normal gameplay rendering. Crashes are reproducible: with a specific heavily-modded scene loaded, time-to-crash is minutes to ~1 hour, over 10+ occurrences. Backtraces across independent crashes show the same libnvidia-glcore code path (matching function offsets across runs).
Backtrace (gdb, representative — render thread)
Fault is signal 11, e.g. “Address not mapped to object”, Address: (nil) / 0x90 across instances:
#5
#6 0x00007f18e8fba1ac in ?? () from /lib64/libnvidia-glcore.so.595.84
#7 0x00007f18e8fb80e4 in ?? () from /lib64/libnvidia-glcore.so.595.84
#8 0x00007f18e93322e2 in ?? () from /lib64/libnvidia-glcore.so.595.84
#9 0x00007f18e930d13d in ?? () from /lib64/libnvidia-glcore.so.595.84
#10 0x00007f18e931a773 in ?? () from /lib64/libnvidia-glcore.so.595.84
#15 osgUtil::RenderLeaf::render(osg::RenderInfo&, osgUtil::RenderLeaf*)
#16 osgUtil::RenderBin::drawImplementation(…)
#17 osgUtil::RenderBin::draw(…)
(full backtraces in attached crash logs; offsets …30d13d / …31a773 recur across separate crashes)
What has been ruled out
  • Threading race: crashes persist with OSG_SERIALIZE_DRAW_DISPATCH=ON and with OSG_THREADING=SingleThreaded
  • GPU topology: crashes occur in both MUX modes (dGPU-direct/discrete AND hybrid PRIME render offload)
  • Refresh rate: occurs at both 60Hz and 144Hz (interval possibly modulated, not gated)
  • Overheating/hardware: GPU at ~40-46C under this load; hardware passes stress tests
  • No kernel-side fault: journalctl shows zero Xid errors across all crashes — userspace GL library only
Additional context (possibly useful)
  • The same machine exhibits an equivalent crash class on Windows 11 in nvoglv64.dll (glDrawElements → DrvPresentBuffers path, plus a deadlock variant) across many Windows driver versions (537.58 through current); WinDbg dumps available on request.
  • A user with identical hardware class (i9-13900HX + RTX 4080 Mobile + external monitor) reported the same Linux crash class on 560.x, fixed in 570.86.16. On 595.84 it is present again — possibly a regression of that fix.
  • Reproduction: OpenMW 0.52 dev build rendering a large modded content set; a specific in-game region reproduces within minutes reliably. I can run test builds/driver settings on request.
  • nvidia-bug-report.log.gz (generated as root immediately after a crash)
  • openmw crash log with full gdb backtrace
Happy to provide additional logs, the Windows dumps, or run diagnostics. Thank you.
EDIT: appears related to a long-running crash family, e.g. 313.18: minecraft and vdpau cause SEGV in libnvidia-glcore.so (same library/failure mode reported 2013, users still reporting in 2026).
openmw-crash-0514.txt (31.2 KB)
nvidia-bug-report.log.gz (707.0 KB)
Can you please provide reproduction instructions for this? We will need to observe it internally.
Thank you! Reproduction details below. I can provide configs, saves, crash logs, and nvidia-bug-report bundles for every driver version mentioned, and I’m happy to run debug builds or set any debug env vars you need.
Hardware/OS: Clevo X370SNV-G laptop, i9-13900HX + RTX 4080 Laptop GPU (AD104M, 12GB), MUX in discrete mode (also reproduces in hybrid). Nobara Linux 44 (Fedora-based), kernel 7.1.4-200, KDE Plasma on Wayland. External 2560x1440@144 display as primary (also reproduces at 60Hz and on internal panel).
Drivers reproduced: 595.84, 610.43.03, 610.57.04 (open kernel modules; dkms packages). Equivalent crash class occurs on Windows 11 in nvoglv64.dll (glDrawElements → DrvPresentBuffers, plus a deadlock variant) across many driver versions — WinDbg dumps available. Additionally, downgrading to the 580 branch is not possible on current kernels (module does not build), so affected users have no working driver version available.
Software: OpenMW 0.52 dev build (Linux tarball from openmw.org development builds; commit 6447970a5e) — native Linux, OpenGL via OpenSceneGraph 3.6. Morrowind data files from Steam. Content: large mod set (“Path of the Incarnate” 2.3.1, ~955 data directories); I can supply my exact openmw.cfg + settings.cfg + save files to remove all setup guesswork.
Repro steps:
  1. Launch openmw, load provided save (dense exterior region — Balmora area).
  2. Play normally: exploration, combat, cell transitions. No specific action is required.
  3. SIGSEGV in libnvidia-glcore occurs stochastically — observed range ~5 minutes to ~2 hours, 10+ logged occurrences, median roughly 10–60 min. It has occurred in clear weather, rain, and ash storms; during combat, wandering, and shortly after saves. Denser scenes and particle weather appear to shorten the interval but nothing gates it: identical conditions have produced both sub-minute crash clusters and 15+ crash-free minutes. No user-side setting tested prevents it (post-processing on/off, shadows on/off, weather particle occlusion on/off, 60 vs 144Hz, hybrid vs discrete MUX, serialized/single-threaded draw).
  4. Recommendation for internal observation: treat it as a soak test — play or script movement through the provided save for 1–2 hours; likelihood of at least one crash in that window has been ~100% in my logs.
Crash signature: consistent across all occurrences regardless of conditions — signal 11 in libnvidia-glcore.so on the render thread, called from osgUtil::RenderLeaf::render → RenderBin::drawImplementation. Fault addresses are null-plus-small-offset ((nil), 0x1c, 0x80, 0x90, 0x230) or wild pointers; the same page offsets recur across independent runs (e.g. …ba1ac/…b80e4/…322e2 family on 595.84). Zero kernel Xid events across all crashes — userspace only. Not a threading race: reproduces with OSG_SERIALIZE_DRAW_DISPATCH=ON and with OSG_THREADING=SingleThreaded. GPU telemetry (5s interval) captured one crash following ~35s after a large (~2.6GB) engine-side resource-cache purge (mass GL object deletion + reallocation) — offered as a lead, not a confirmed trigger; VRAM never exceeded ~45% of 12GB in any session.
Also relevant: a vanilla (unmodded) OpenMW crash with matching osg::Drawable::draw offset was reported on Windows on a desktop RTX 4090 (OpenMW GitLab issue), so the large mod set likely raises frequency rather than being required.
Please remove all the guesswork we’d have so do in reproducing this - as much as possible, anyway.
Hi @Khant.iMplora, I have filed an internal bug for tracking - NVBug #6680260.
Yes, please provide additional details to help with our reproduction efforts. Thank you
Could you also provide these for Engineering review. Thank you
Evidence package for Engineering review / NVBug #6680260 (90MB zip):
Contains everything described upthread — the 10 Linux gdb crash logs (595.84 / 610.43.03 / 610.57.04), a fresh nvidia-bug-report.log.gz from 610.57.04, my exact openmw.cfg + settings.cfg (only edit needed: the data= path prefixes), save files, and the per-session GPU telemetry CSVs — plus the Windows-side material, detailed below for the first time.
Two clarifications for reproduction:
  • The content set is “Path of the Incarnate” (POTI) 2.3.1 — a pre-tailored, publicly available modlist with an automated installer; it can be obtained from the POTI project’s website: [POTI LINK]. No manual mod assembly is needed to match my setup — install the list, drop in my two cfg files with the path-prefix edit, done.
  • My save files are not required. The crashes occur on any save, including fresh playthroughs — the included save-Haru_Zhen/ files are purely a convenience (the newest quicksave loads into a region with a short median time-to-crash, which may speed up observation). Any character, anywhere, soak-tested per the steps upthread, reproduces.
windows-dumps/ + windows-era-evidence-dossier.md (same machine, dual-boot Win11):
  • 8× openmw.exe WER minidumps — nvoglv64.dll faults in two families: INVALID_POINTER_READ in the DrvPresentBuffers path at address 0xFFFFFFFFFFFFFFFF (two dumps share an identical Failure.Hash), and INVALID_POINTER_WRITE at 0x0 immediately after opengl32!glDrawElements
  • 3× NVDisplay.Container.exe crash dumps from the same period
  • 2× msedge.exe GPU-process crash dumps (Chromium apps were dying silently on the desktop during the same era)
  • Kernel watchdog samples; the system additionally holds 24× Kernel_141 and 8× Kernel_193 WER reports spanning Apr 2025–Jul 2026, all available if useful
  • Three full-memory openmw.exe dumps (7–8GB each) are preserved and available on request
One exclusion not yet mentioned: the Intel 13th-gen microcode angle is already covered — this machine’s BIOS was updated to the Dec-2024 firmware (verified), and the crashes continued on both OSes afterward.
If a replayable GL call stream would help, I’m happy to capture an apitrace of a crashing session — and the standing offer holds for debug builds, __GL_* environment variables, or any diagnostics you specify.
