CPU AMD Ryzen 9 3950X 16-Core Processor
I installed and compiled linux kernel 7.1.3 from source
then downloaded the driver 595.91.07 from the nvidia site.
everything seemed to compile and install ok but the X screen was not found.
Here is where things went wrong in the Xorg.0.log:
[ 243.341] (II) NVIDIA dlloader X Driver 595.91.07 Wed Jul 29 02:45:58 UTC 2026
[ 243.341] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 243.341] (II) Loading sub module “fb”
[ 243.341] (II) LoadModule: “fb”
[ 243.341] (II) Module “fb” already built-in
[ 243.341] (II) Loading sub module “wfb”
[ 243.341] (II) LoadModule: “wfb”
[ 243.341] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 243.342] (II) Module wfb: vendor=“X.Org Foundation”
[ 243.342] compiled for 1.21.1.23, module version = 1.0.0
[ 243.342] ABI class: X.Org ANSI C Emulation, version 0.4
[ 243.342] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 243.342] (==) NVIDIA(0): RGB weight 888
[ 243.342] (==) NVIDIA(0): Default visual is TrueColor
[ 243.343] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 243.343] () NVIDIA(0): Enabling 2D acceleration
[ 243.343] (II) Loading sub module “glxserver_nvidia”
[ 243.343] (II) LoadModule: “glxserver_nvidia”
[ 243.343] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 243.413] (II) Module glxserver_nvidia: vendor=“NVIDIA Corporation”
[ 243.413] compiled for 1.16.99.901, module version = 1.0.0
[ 243.413] Module class: X.Org Server Extension
[ 243.413] (II) NVIDIA GLX Module 595.91.07 Wed Jul 29 02:45:43 UTC 2026
[ 243.413] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 243.469] (EE) NVIDIA(GPU-0): The NVIDIA GPU at PCI:8:0:0 is not supported by the 595.91.07
[ 243.469] (EE) NVIDIA(GPU-0): NVIDIA driver.
[ 243.469] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[ 243.469] (EE) NVIDIA(0): Failing initialization of X screen
[ 243.469] (II) UnloadModule: “nvidia”
[ 243.469] (II) UnloadSubModule: “glxserver_nvidia”
[ 243.469] (II) Unloading glxserver_nvidia
[ 243.469] (II) UnloadSubModule: “wfb”
[ 243.469] (EE) Screen(s) found, but none have a usable configuration.
