Summary
A 4K monitor on the HDMI port of an RTX 4090 Laptop GPU shows a black screen and goes back to standby if 3840x2160 @ 60 Hz was set while the monitor was in standby. That mode is 594 MHz, so it needs HDMI 2.0 TMDS scrambling.
When the monitor wakes, it can’t show the signal. The connector stays connected the whole time (no hotplug), and nothing fixes it until the mode is changed while the monitor is awake. Modes at or below 340 MHz (for example 4K at 23.976 or 29.97 Hz, 297 MHz) don’t have the problem.
Our reading: the SCDC scrambling setup done at modeset time doesn’t reach the monitor (or is lost) while it’s in standby, and the driver doesn’t redo it when the monitor wakes because there is no hotplug event. Please correct us if the cause is something else.
System
- Laptop: ASUS ROG Zephyrus G16 GU605MY, BIOS GU605MY.329.
- Intel Meteor Lake-P Arc [8086:7d55] + GeForce RTX 4090 Laptop GPU (AD103M) [10de:2757].
- The HDMI port is on the NVIDIA GPU.
- Driver: NVIDIA open kernel module 595.91.07.
- OS: Ubuntu 26.04, kernel 7.0.0-38-generic, GNOME Shell / mutter 50.1 (Wayland), GDM 50.1.
- Monitor: Acer DS1 (EDID
ACR,DS1_156), 15.6" 3840x2160, on its own power adapter.- Video is over HDMI.
- A separate USB-C cable carries USB only (no DP alt mode).
Monitor EDID (relevant fields; full hex at the end)
- Preferred timing: 3840x2160 @ 60.000 Hz, 594.000 MHz pixel clock.
- CTA-861 VICs include 97 (4K60) and 95 (4K30).
- HDMI 1.4 VSDB: max TMDS clock 340 MHz.
- HF-VSDB: max TMDS character rate 600 MHz, SCDC_Present=1, RR_Capable=0, LTE_340Mcsc_scramble=0.
Steps to reproduce
A. At boot
- The monitor is in standby on its power adapter. The GNOME/GDM display config has it at 3840x2160 @ 60 Hz.
- Power on the laptop. nvidia-modeset logs
Unable to read EDID for display device DP-0twice at about 5 s, because the monitor is asleep.DP-0is nvidia-modeset’s name for this HDMI connector. - The GDM login screen starts at about 6–7 s and sets 3840x2160 @ 60 Hz while the monitor is still asleep.
- The monitor wakes about 10 s later, shows black, and goes back to standby 0.5–1.8 s later.
B. During a session (simpler)
- Log in. The monitor works at 3840x2160 @ 60 Hz.
- Turn the monitor off with its power button, then on again. Don’t touch the display settings.
- Result: black screen, and the monitor goes back to standby about 15–19 s later.
- Do the same at 3840x2160 @ 23.976 Hz (297 MHz). The picture comes back by itself and stays. Switching to 60 Hz while the monitor is on also works and stays.
Expected: at 60 Hz, the picture comes back when the monitor wakes, the same as at 297 MHz.
Evidence
The monitor has a built-in USB hub (0bda:5411) that is powered only while the panel is awake. Its connect/disconnect in the kernel log shows when the monitor wakes and when it goes back to standby.
A. Boot, before any workaround: 10 of 10 boots between 2026-09-30 and 2026-10-08 look the same.
| Boot (local time) | EDID read warning | Hub appears (monitor wakes) | Hub disconnects (back to standby) |
| 09-30 14:46 | 4.7 s | 16.9 s | 18.0 s (+1.1) |
| 10-01 14:51 | 5.8 s | 18.7 s | 19.2 s (+0.5) |
| 10-01 15:38 | 4.7 s | 17.1 s | 18.4 s (+1.3) |
| 10-02 13:54 | 4.8 s | 17.0 s | 18.2 s (+1.2) |
| 10-02 14:08 | 5.1 s | 16.8 s | 18.3 s (+1.5) |
| 10-06 13:20 | 5.9 s | 17.4 s | 19.2 s (+1.8) |
| 10-07 13:30 | 4.8 s | 16.6 s | 18.2 s (+1.6) |
| 10-07 14:25 | 6.7 s | 19.0 s | 20.3 s (+1.3) |
| 10-08 13:31 | 4.8 s | 17.2 s | 18.2 s (+1.0) |
| 10-08 17:09 | 5.9 s | 17.8 s | 19.2 s (+1.4) |
B. Power-cycling the monitor during a session:
- 2026-10-08 17:13, at 60 Hz: the hub came back at 17:13:19, and the screen stayed black. The whole hub disconnected at 17:13:38, when the monitor went back to standby 19 s later.
- 2026-10-08 17:16, at 23.976 Hz: the hub came back at 17:16:47. The picture came back by itself and stayed.
- 2026-10-12 14:50, at 60 Hz (by accident): the monitor came back at 14:50:33 and was in standby again at 14:50:48.
- Mode changes at 14:51:09 and 14:51:34, while the monitor was in standby, did nothing.
- The monitor woke at 14:54:58. A mode change at about 14:55:06 brought the picture back.
Throughout, /sys/class/drm/card0-HDMI-A-1 stays status=connected, enabled=enabled, dpms=On.
C. With the workaround: we made the GDM login screen use 3840x2160 @ 29.97 Hz (297 MHz) through the greeter’s monitors.xml.
- 4 of 4 boots were fine (1 reboot, 3 cold boots).
- The monitor woke on the 297 MHz signal. The user session then switched it to 60 Hz while it was awake, and it stayed on.
The same monitor on an Intel-only laptop’s HDMI port hasn’t shown this. But that laptop auto-logs-in, so no mode is set while the monitor sleeps, and it’s not a clean comparison.
What we looked at in the open source (tag 595.91.07)
- NVKMS sends the sink’s HDMI capabilities to RM in
nvSendHdmiCapsToRm()(src/nvidia-modeset/src/nvkms-hdmi.c), usingNV0073_CTRL_CMD_SPECIFIC_SET_HDMI_SINK_CAPS. This covers SCDC present and support above 340 MHz. It runs on connect/disconnect and EDID updates. - That control is marked
ROUTE_TO_PHYSICAL, so the SCDC and scrambling programming itself is in GSP firmware, which we can’t read. - We found no NVKMS path that redoes the scrambling setup when the sink comes back without a hotplug event.
Questions
- Is the SCDC scrambling setup (TMDS_Config) written only on modeset and hotplug? Could the driver notice that the sink lost it, for example by reading SCDC Scrambler_Status, and write it again?
- If the fault is on the monitor’s side (it should toggle HPD after it loses SCDC state), is there a driver option to re-do the HDMI link setup without a full mode change? We’d like a workaround that doesn’t change the user’s refresh rate.
nvidia-bug-report.log.gz, captured in the same boot as the 2026-10-12 14:50 reproduction of B (its dmesg includes it).- EDID (256 bytes, hex):
00ffffffffffff0004720100a7f02e3216210103802213782aceb5a65434b625
0e5054bdef00714f8140818081c09500b300d1c0010108e80030f2705a80b058
8a0058c11000001e000000fe00464652324141413030310a2020000000fc0044
53315f3135360a2020202020000000fd00174c1e873c000a2020202020200128
020331b14f905d040302016111131f205f60215e6d030c001000384420006001
020367d85dc401788003e30f4000e200ea023a801871382d40582c450058c110
00001e08e80030f2705a80b0588a0058c11000001e565e00a0a0a02950302035
0058c11000001e662156aa51001e30468f330058c11000001e0000000000006c
nvidia-bug-report.log.gz (340.5 KB)
