6 Cameras using Recorder Tool
Hi
Is it possible to record 6 cameras via DriveWorks Recording Tool along with GPS and Lidar. Thanks.
Umer
Dear Umer,
Yes, you can use ./recorder-qt tool in /usr/local/driverworks/tool in DPX2. Thanks.
Hi Steve,
Can you share the configurations for the recorder-config.json file that can allow me to capture data from port ab and port cd simultaneously. Thanks.
Umer
Hi Umer,
Did you look into Tools->Recording tools in /usr/local/driveworks/doc/nvdwx_html/NVIDIA_DriveWorks_DevGuide.pdf.
You can get more details on how to add sensors to recorder-config.json file.
Hope it helps.
Hi Umer,
Were you able to do the capture using 6 cameras? I am looking to do something similar to that but am able to get the capture only for one particular group and not the two simultaneously. I am looking to use ipp_capture_encode. I was able to do it only for 4 cameras.
