[600-Branch / Optimus] Crash in NvPresent64.dll during IDXGISwapChain::ResizeBuffers on window maximize (render-offload laptop)
Summary
On an NVIDIA Optimus laptop (where the Intel iGPU drives the display and the RTX 5070 Laptop GPU operates in render-offload mode), a D3D11 application crashes upon window maximization. During the swapchain resize operation, execution enters NvPresent64.dll (the NVIDIA cross-adapter present path), leading to a fatal process crash. Forcing the application to use the Intel iGPU bypasses the NVIDIA cross-adapter present path and completely mitigates the crash. Since identical binaries only crash when the NVIDIA present path is active, this strongly indicates a driver-side defect within the 600-branch cross-adapter present/resize implementation.
Environment
  • Render GPU: NVIDIA GeForce RTX 5070 Laptop GPU — PCI\VEN_10DE&DEV_2D58&SUBSYS_803117AA&REV_A1
  • NVIDIA Driver: 610.47 (Windows 32.0.16.1047, KMD 610.47, CUDA UMD 13.3), WHQL, late May 2026
  • Faulting Module: NvPresent64.dll (driver store: nvlti.inf_amd64_ac6e327f484351b4, 2026-05-21, 8,389,352 bytes)
  • Display GPU (iGPU): Intel UHD Graphics (RaptorLake-S), VEN_8086&DEV_A788. Note: Tested on Intel drivers 32.0.101.7080 and 32.0.101.7085; both are confirmed to reproduce the issue.
  • Hybrid Mode: Optimus / render-offload. The NVIDIA GPU does NOT drive any physical display (DxDiag: Current Mode / Topology = Unknown). The application renders on the NVIDIA GPU and relies on cross-adapter presentation to the Intel iGPU.
  • Hardware: Lenovo 83NN, Intel Core i9-14900HX, 32 GB RAM
  • Display: Internal panel, 2560×1600 @ 240 Hz, HDR-capable (BOE NE160QDM-NZB), driven exclusively by the Intel iGPU
  • OS: Windows 11 Home 64-bit, Build 26100.8655 (26200.8655), WDDM 3.2, DirectX 12
  • Application: Proprietary D3D11 application (issue reproduced on app versions 3.2.0 and 3.4.0). Built on SDL3; renderer = SDL_Render (D3D11 backend).
Impact
A hard crash occurs during a routine user interaction (maximizing the window). The only viable workaround on the application side is to explicitly disable NVIDIA GPU utilization (forcing execution on the iGPU via Windows OS graphics settings).
Steps to Reproduce
  1. Launch the application on the specified Optimus laptop, ensuring the RTX 5070 Laptop GPU is selected as the render device (Windows “High performance” / NVIDIA default).
  2. Maximize the application window (this triggers IDXGISwapChain::ResizeBuffers).
    → Result: The process hangs for approximately 1 minute before crashing.
  • Expected behavior: The window maximizes successfully, and the cross-adapter swapchain resizes without issues.
  • Actual behavior: During the resize operation, execution passes through NvPresent64.dll, resulting in an unhandled exception and process termination.
Technical Analysis (Captured via VEH debugger)
The application explicitly invokes IDXGISwapChain::ResizeBuffers (vtable slot 13; call qword [rax+0x68], where RAX is the swapchain instance). The swapchain’s vtable resolves to NvPresent64.dll, confirming that the NVIDIA driver wraps the DXGI swapchain. Consequently, the resize operation executes through NVIDIA’s cross-adapter present implementation, which is where the fault originates.
Call stack (innermost first):
NvPresent64.dll! <cross-adapter present / resize path>
SDL3.dll!D3D11_CreateWindowSizeDependentResources  ; IDXGISwapChain::ResizeBuffers (slot 13)
SDL3.dll! <window maximize / resize handling>
<application>
kernel32.dll!BaseThreadInitThunk
ntdll.dll!RtlUserThreadStart
Confirming Repro/Fix
Forcing the application to run on the Intel iGPU (via Windows Settings → System → Display → Graphics → [App] → Power saving) unloads the NVIDIA driver and NvPresent64.dll from the process space, entirely eliminating the crash. Given that identical application and SDL binaries only fault when utilizing the NVIDIA cross-adapter present path, the issue isolates to the NVIDIA driver.
Note for the engineering team: We noticed the Hotfix 610.52 release notes mention a G-SYNC frame-pacing fix affecting the 600 branch. We are flagging this as a point of reference, as it might intersect with the faulting present/resize path described above.
Ask
We request an investigation into the NvPresent64.dll cross-adapter present/resize path triggered by IDXGISwapChain::ResizeBuffers on Optimus / render-offload setups under the 600 driver branch. We hope the detailed context and technical analysis provided above are sufficient for the engineering team to successfully reproduce and resolve this defect in an upcoming driver update.
