[610.57.04] Xid 56 during hardware-accelerated browser video playback — permanent display engine hang, KDE Wayland, dual DP 1440p@165Hz
System
  • GPU: RTX 4070 Ti SUPER (PCI 0000:05:00), 16 GB
  • Driver: 610.57.04
  • iGPU: AMD (PCI 0000:11:00), unused for this session
  • OS: Fedora 44, kernel 7.1.8-200.fc44.x86_64
  • Desktop: KDE Plasma 6.7.4, KWin 6.7.4, Wayland
  • Displays: 2x 2560x1440 @ 165 Hz, both on DisplayPort off the discrete GPU
    • DP-4: LG ULTRAGEAR
    • DP-5: Sentronic SKP_E30-27
  • Night Light: disabled
Summary
After 7.5 hours of uptime, a single Xid 56 was raised while a hardware-decoded video was playing in a browser tab. From that moment the display engine never recovered: KWin emitted a pageflip timeout every second for the next 10 minutes until I power-cycled the machine. The rest of the GPU kept running and reporting normally throughout.
Timeline
08:57:00  boot
09:02:26  KWin session starts
16:06:24  last notable compositor activity (gwenview entering fullscreen)
16:32:32  NVRM: Xid (PCI:0000:05:00): 56, CMDre 00000007 00000000 00000000 00000001 00000000
16:32:33  kwin_wayland: Pageflip timed out! — repeats 1/sec, 621 occurrences
16:36:41  Krunner1Adaptor::Teardown — my Ctrl+Alt+T attempt; input and D-Bus still alive
16:42:56  [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [GPU ID 0x00000500] Flip event timeout on head 0
16:54:26  journal ends (hard power-off)
Exactly one Xid 56. No cascade, no repeat, no subsequent fault. Everything after it is KWin retrying a flip that never completes.
Context at the time of the fault
No game, no brightness or colour temperature change, no display hotplug.
A video was playing in a browser tab with hardware decode active. Decode continued normally while scanout was dead.
Browser stack:
  • Vivaldi 8.1.4087.68 (Flatpak, com.vivaldi.Vivaldi), Chromium-based
  • org.freedesktop.Platform.GL.nvidia-610-57-04 (exact match to host driver)
  • org.freedesktop.Platform.VAAPI.nvidia 25.08
  • vivaldi://gpu reports Video Decode: Hardware accelerated, Compositing: Hardware accelerated, Vulkan: Enabled
The VA-API stack was correctly configured and functioning — this is not a fallback or misconfiguration case.
System state during the hang
A GPU logger was running, giving 500 ms samples covering 16:41:31 to 16:42:31 — nine minutes into the hang, while flip timeouts were still being emitted:
Metric During hang After reboot, under load
GPU / hotspot temp 42 / 53 °C 54 / 64 °C
Power draw 11.5 W (285 W cap) 71.6 W
Core clock 210 MHz (P8) 2700 MHz
Memory clock 405 MHz, pinned 10501 MHz
VRAM used 1.6 / 16 GB 1.5 GB
The memory clock stayed pinned at the 405 MHz idle state for the entire duration, while two 1440p165 outputs were still nominally active — bandwidth that cannot sustain scanout for those modes.
The session itself was never lost: the Krunner D-Bus teardown at 16:36:41 shows input events and D-Bus were still being processed four minutes after the fault. Only the display was gone.
Thermal, power delivery, VRAM exhaustion and memory pressure are all excluded by the telemetry above — the GPU was in deep idle at 42 °C drawing 11 W of a 285 W cap. glmark2 after reboot scores 16747 with no artefacts, so the card is functionally healthy.
Recovery attempts, all unsuccessful
  • Unplug/replug DisplayPort → black screen
  • Moving a display to the motherboard DP output → nothing; the amdgpu side did attempt DP link training at 16:45:57 but the compositor was already wedged
  • Ctrl+Alt+T → no window ever drawn
  • sudo reboot → the journal ends with no shutdown sequence, so it never executed
Hard power-off was the only way out, 22 minutes in.
Attached
  • nvidia-bug-report.log.gz — generated on the following boot; verified to contain the Xid and flip timeout from the previous boot
  • kwin-prevboot.txtjournalctl --user-unit plasma-kwin_wayland -b -1
nvidia-bug-report.log.gz (551.2 KB)
kwin-prevboot.txt (224.4 KB)
4070 Ti SUPER here and same, on wayland kubuntu 26.04 with nvidia 610.57 getting very bad stutter during media playback.
reverting to 595.84 fixes it.
I’m seeing what looks like the same issue on my RTX 4070.
My setup:
  • RTX 4070
  • NVIDIA 610.57.04
  • nvidia-open
  • CachyOS
  • Kernel 7.2.2-1-cachyos
  • KDE Plasma / Wayland
  • Dual DisplayPort monitors
  • Vivaldi
In my case, I was simply browsing Twitter/X when the whole system froze. Ctrl+Alt+F3 and even Magic SysRq stopped responding. The screens briefly flashed, but the desktop never recovered, so I had to force a shutdown.
After rebooting, the previous boot log was full of:
NVRM: Xid (PCI:0000:07:00): 56
I also got:
kwin_wayland: A graphics reset attributable to the current GL context occurred.
kwin_wayland: The main thread was hanging temporarily!
and:
[nvidia-drm] [GPU ID 0x00000700] Flip event timeout on head 1
So this seems extremely similar to the issue reported here, especially since we’re both on 610.57.04, KDE Wayland and Chromium-based browsers.
I’ll test with browser hardware acceleration disabled to see if I can reproduce it again. I can also provide an nvidia-bug-report.log.gz if it would be useful.
Hopefully this helps confirm that the issue is not isolated to one GPU/system.
This is frustrating, i’m trying to use linux but this is a bad experience because nvidia
