Summary: With 615.71.09, when my monitor switches PBP (picture-by-picture) mode on or off, the display never comes back. The first switch, into PBP, is enough. There is no signal and the compositor never gets the monitor back, and the only way to recover is a reboot. With 610.57.04, on the same kernel, compositor, cable and monitor, the connector drops and a reconnect hotplug arrives about 1.3 s later, both entering and leaving PBP, and everything recovers on its own.
System
- GPU: ZOTAC RTX 5080 Solid OC (10DE:2C02, subsystem 19DA:1765), VBIOS 98.03.3B.C0.0B
- Driver: nvidia-open-dkms 615.71.09 (bad), 610.57.04 (good)
- Kernel: 7.2.5-4-omarchy (Arch-based), nvidia_drm modeset=1, fbdev=1
- Compositor: Hyprland 0.56.2 (aquamarine 0.15.1), Wayland
- Monitor: LG UltraGear 39GX950B (5120x2160 @ 165 Hz), single DisplayPort 2.1 connection. In PBP mode it presents 2560x2160 @ 75 Hz to this input.
- CPU/board: Ryzen 9 5950X, ASUS TUF X470-PLUS GAMING
Steps to reproduce
- Desktop running at 5120x2160 @ 165 Hz on DP-1.
- Switch the monitor into PBP from its OSD.
- (With 610.57.04 only, since 615 never gets this far:) switch PBP off again.
615.71.09: after step 2 the monitor shows no signal, DP-1 never reappears in the compositor, and the display only comes back after a reboot. Reproduced several times.
610.57.04: each switch makes DP-1 drop and reconnect about 1.3 s later: 2560x2160 @ 75 Hz in PBP, then 5120x2160 @ 165 Hz after PBP is turned off. The compositor recovers on its own.
Log on 610.57.04 (working)
This was captured with a logger polling connector status each second, plus udev drm uevents and Hyprland’s monitor events. Each disconnect and each reconnect produced two HOTPLUG=1 change uevents on card1 (8 in total).
18:27:55.819 poll: card1-DP-1=connected | DP-1 5120x2160 @ 165.058 (normal)
18:28:36.463 hypr: monitorremovedv2>>DP-1 (enter PBP)
18:28:37.133 poll: card1-DP-1=disconnected | FALLBACK 1920x1080
18:28:37.831 hypr: monitoraddedv2>>DP-1
18:28:38.147 poll: card1-DP-1=connected | DP-1 2560x2160 @ 74.991 (PBP)
18:28:51.702 hypr: monitorremovedv2>>DP-1 (leave PBP)
18:28:52.241 poll: card1-DP-1=disconnected | FALLBACK 1920x1080
18:28:53.113 hypr: monitoraddedv2>>DP-1
18:28:53.250 poll: card1-DP-1=connected | DP-1 5120x2160 @ 165.058 (recovered)
I don’t have an equivalent 615.71.09 capture, because the forced reboot needed to recover discarded the journal.
This may be related to 615.71.09 regression: DisplayPort link never re-established after monitor DPMS sleep. There too the DP link or connector doesn’t come back after the monitor drops it. The Windows 617.14 driver lists a fix for “Certain monitors may not wake from sleep when connected via DisplayPort after updating to R615 drivers” [6757568]. Is that fix, or one for this PBP case, coming to the Linux driver?
For now I’m holding the driver at 610.57.04.
