615.71.09 / RTX 5090: WoW DX12 freezes with ray tracing enabled. Xid 109 / VK_ERROR_DEVICE_LOST
World of Warcraft Retail repeatedly freezes while moving around a city with DirectX 12 and ray-traced shadows enabled. The picture stops updating, but the process remains running and audio continues. Three hangs were captured on September 12, 2026.
WoW worked before my latest NVIDIA driver update. Disabling ray-traced shadows appears to avoid the issue in initial testing. I suspect a driver regression, but the exact last-known-good driver version and long-term stability with RT disabled are not yet confirmed.
Environment
  • GPU: NVIDIA GeForce RTX 5090, 32 GB
  • Driver: 615.71.09, open kernel module; loaded userspace libraries match
  • OS/kernel: CachyOS, 7.2.4-1-cachyos
  • Desktop: KDE Wayland / KWin 6.7.5; WoW runs through Xwayland
  • Game: WoW Retail 12.1.0.69814
  • Launcher: Faugus 2.3.0 → Battle.net → Proton-CachyOS cachyos-11.0-20260703-slr, UMU steamrt4
  • VKD3D-Proton: 3.1.0, build 3dfc6f07d0953b1
  • Graphics: DX12, ray-traced shadows level 3, Reflex+Boost, 5120×2160, 8× MSAA
Reproduction
  1. Launch WoW through the above setup with DirectX 12 and ray-traced shadows enabled.
  2. Load a character and move into another part of the city.
  3. The picture freezes while audio continues. No precise action or coordinate has been identified. The logged reproduction failed about 50 seconds after launch; earlier runs lasted several minutes.
Captured failure: September 12, 2026, PDT (UTC−07:00)
At 15:33:14.225, WoW reports “GPU Hung” and a Direct queue timeout (0x80070102). At 15:33:15.019, the kernel records:
NVRM: Xid (PCI:0000:01:00): 109, pid=82301, name=WoW.exe, channel 0x0000002b, errorString CTX SWITCH TIMEOUT, Info 0x26c03a
VKD3D reports failed Vulkan timeline-semaphore waits (vr -4) and marks the device lost with VK_ERROR_DEVICE_LOST / 0x887a0005. WoW attempts recovery but remains frozen.
KWin logs a temporary main-thread stall at 15:33:15.030 and continues without restarting. No full-GPU reset, AMD GPU hang, or OOM kill was logged during the failure window.
Ray-tracing acceleration-structure address-reuse warnings appear 4–10 seconds before device loss. These are included as context, without assuming they identify the cause. Allocator-reset/release errors occur after device loss.
  • nvidia-bug-report.log.gz - generated at 15:48 PDT after reproduction; includes all three WoW Xid 109 events and NVIDIA driver diagnostics.
  • wow-gpu-freeze-evidence.tar.gz - preserved Proton/UMU logs, WoW graphics log, kernel/KWin events, and relevant excerpts. Personal home paths and session activation information have been replaced in these log copies.
nvidia-bug-report.log.gz (669.5 KB)
wow-gpu-freeze-evidence.tar.gz (376.4 KB)
Same here, needed to restore a snapshot
Adding a similar report from an RTX 5080 running WoW Classic through Lutris on CachyOS with driver 615.71.09.
Environment
  • RTX 5080, 16 GB; NVIDIA 615.71.09, open kernel module
  • CachyOS, kernel 7.2.4-3-cachyos; KDE Wayland / KWin 6.7.5
  • Lutris 0.5.22 → Battle.net → WoW Classic 1.15.9.69722 (WoWClassic.exe, classic_era)
  • Wine reports 11.0.0; exact runner package and VKD3D version not yet identified
  • DirectX 12, 2560x1440 at 144 Hz, 200% render scale (5120x2880 internally), ray-traced shadows level 3
Observed failure
Two crashes on September 12, 2026, correspond to kernel Xid 109 / CTX SWITCH TIMEOUT errors naming WoWClassic.exe:
  • 20:11:47 PDT: PID 10507, PCI 0000:02:00, channel 0x0000000d, Info 0x24c00d
  • 20:16:01 PDT: PID 14248, PCI 0000:02:00, channel 0x0000000d, Info 0x28c00d
At 20:16:00.689, WoW reports “GPU Hung. Timeout when waiting for queue: Direct (0x80070102)”, device loss, and “Disabling Ray Tracing as a potential workaround…”. It then attempts device recovery.
Workaround tested
With the game closed, I changed only shadowRt from 3 to 0. Subsequent play has been stable so far; DirectX 12 and 200% render scale were left unchanged. Long-term stability and the exact underlying cause are not yet confirmed. I do not have a confirmed last-known-good driver version or a precise in-game action that triggers the crash.
Attached are the preserved WoW graphics log and kernel NVIDIA error excerpts, with hostname and GPU UUID removed. This attachment is not the full nvidia-bug-report diagnostic bundle.
wow-classic-crash-logs.tar.gz (1.9 KB)
Adding another reproduction with nearly identical hardware and the same failure signature.
Environment
  • CPU: AMD Ryzen 9 9950X3D
  • Driver: 615.71.09, open kernel module; kernel module and user-space libraries match
  • OS/kernel: CachyOS, 7.2.5-1-cachyos
  • Desktop: KDE Plasma/KWin 6.7.5, Wayland session
  • Launcher: Lutris 0.5.22 → Battle.net → Proton-CachyOS 11.0.20260703
  • Graphics API: DirectX 12
  • Resolution: 3840x2160 at 240 Hz
The failure is reliably triggered while moving around Silvermoon. I have not reproduced it in the other areas I normally play.
I tested the following combinations:
  1. Ray-traced shadows level 3 with 2x MSAA: crashed
  2. Ray-traced shadows level 3 with MSAA disabled and CMAA2 enabled: crashed
  3. Ray-traced shadows level 1 with 2x MSAA: crashed
Reducing the ray-tracing quality therefore did not prevent the failure, and replacing MSAA with CMAA2 did not prevent it either.
I also reproduced it using native Wine-Wayland, so changing from Xwayland to Wine-Wayland did not resolve the WoW crash.
During the most recent controlled test, WoW initialized RTShadows level 1 at 22:43:35 and failed approximately 36 seconds later:
Device Removed Reason: GPU Hung. Timeout when waiting for queue: Direct (0x80070102) count:1
Device Lost on NVIDIA driver version 999.99.
Disabling Ray Tracing as a potential workaround...
The corresponding kernel event was:
NVRM: Xid (PCI:0000:01:00): 109, pid=5981, name=WoW.exe, channel 0x0000000b, errorString CTX SWITCH TIMEOUT, Info 0xdc009
Five WoW-related Xid 109 events were captured on September 14. The last three used channel 0x0000000b with Info 0xdc009.
GPU telemetry during the level-1 RT test peaked at approximately 51 C. No thermal or power-limit violation was recorded. After the Xid, new
nvidia-smi invocations could no longer communicate with the driver, requiring a reboot.
Setting shadowRt to 0 has prevented the Silvermoon crashes so far while leaving DX12 and 2x MSAA enabled.
My system upgraded from NVIDIA 610.57.04 to 615.71.09 on September 10, but WoW also updated to build 12.1.0.69814 shortly afterward. I
therefore cannot yet prove which update introduced the regression. I have not performed a driver rollback.
Same thing, intermittently tonight.
System
  • GPU: RTX 5090 (GB202)
  • Driver: nvidia-open-dkms 615.71.09-1
  • Kernel: 7.2.6-1-cachyos (CachyOS/Arch)
  • Compositor: Hyprland 0.56.2-3.1, Wayland session; game forced to XWayland (PROTON_ENABLE_WAYLAND=0)
  • Launcher chain: Battle.net through Faugus 2.3.0-1 (Flatpak), Proton-GE-WC3Fix, umu-steamrt4, gamemode enabled
  • Game: World of Warcraft Forever Beta, build 69913, GxApi "D3D12"
I’ve gotten Xid 109 (‘CTX SWITCH TIMEOUT’) a few times tonight at multiple different options of graphics settings. No raytracing or anything’s on as that’s disabled in the client.
A few bits from the kernel log:
NVRM: Xid (PCI:0000:01:00): 109, pid=25269, name=WowB.exe, channel 0x0000002d, errorString CTX SWITCH TIMEOUT, Info 0x12c02e
NVRM: Xid (PCI:0000:01:00): 109, pid=428668, name=WowB.exe, channel 0x00000032, errorString CTX SWITCH TIMEOUT, Info 0x12c038
NVRM: Xid (PCI:0000:01:00): 109, pid=446043, name=WowB.exe, channel 0x00000032, errorString CTX SWITCH TIMEOUT, Info 0x8c038
I’ve ruled out graphicsQuality/shadow/SSAO tier as the deciding factor because it crashed at all of these:
  • graphicsQuality 8, shadowMode 4, graphicsShadowQuality 5, shadowNumCascades 4, SSAO 4
  • graphicsQuality 6, shadowMode 3, graphicsShadowQuality 3, shadowNumCascades 3, SSAO 3
Probably the same thing here
System
  • Lenovo ThinkPad P16 Gen 3, Intel Core Ultra 9 285HX, 128 GB RAM
  • NVIDIA RTX PRO 5000 Blackwell Generation Laptop GPU 24 GB (GB203GLM), hybrid graphics with Intel Arrow Lake iGPU
  • Bazzite 44 (Fedora 44 based), NVIDIA open kernel module (akmods), KDE Plasma 6.7 Wayland
  • Kernel 7.2.3 + driver 610.57.04, and kernel 7.2.4 + driver 615.71.09 (both reproduce)
  • Game: World of Warcraft: Forever beta client (WowB.exe 1.60.1, builds 69893 and 69913), Lutris + umu-run, UMU-Proton 10.0-4 (Wine 11.0)
Symptom
GPU hang while loading into the world, or during the first in-engine cutscene. The kernel logs Xid 109 ... CTX SWITCH TIMEOUT for WowB.exe; the game reports Device Removed Reason: GPU Hung. Timeout when waiting for queue: Graphics (0x80070102), then its watchdog fires ERROR #109: A thread has become unresponsive. Audio keeps playing, rendering stops. The GPU is not thermally limited (~57 °C, no throttle reasons active).
Reproducibility: 7 out of 7 world-load attempts, on both drivers
Driver API / translation layer Graphics settings Result
610.57.04 D3D12 / vkd3d-proton Ultra Xid 109 (3× on Sep 17 + 1× on Sep 18)
610.57.04 D3D11 / DXVK Ultra Xid 109
610.57.04 D3D11 / DXVK Reduced (compute effects off, SSAO/shadows/volumetric fog low, sun shafts off) Xid 109: the world loads and the cutscene starts, then it hangs
615.71.09 D3D12 / vkd3d-proton Ultra Xid 109
Notes
  • It happens on both DXVK and vkd3d-proton, so it does not look specific to either translation layer.
  • Reducing GPU load delays the hang but does not prevent it.
  • Ray tracing is not in play here: the client reports rt:None under both APIs, and there is no shadowRt CVar in Config.wtf. So unlike the RTX 5090/5080 reports in this thread, disabling RT shadows cannot be the workaround here, and D3D11/DXVK hangs as well. The trigger seems broader than the RT path.
  • 615.71.09 (release notes mention an Xid 109 fix and a Blackwell thread-divergence reconvergence fix) does not resolve it.
  • Looks like the same class as open-gpu-kernel-modules #1097 (Crimson Desert, RTX 5090) and #1146 (Forza Horizon 6), here on a mobile GB203.
Xid 109 kernel log lines (all 7 hangs)
610.57.04 / kernel 7.2.3
2026-09-17T22:55:41 NVRM: Xid (PCI:0000:01:00): 109, pid=7989, name=WowB.exe, channel 0x00000013, errorString CTX SWITCH TIMEOUT, Info 0xc01f
2026-09-17T23:28:48 NVRM: Xid (PCI:0000:01:00): 109, pid=13419, name=WowB.exe, channel 0x00000013, errorString CTX SWITCH TIMEOUT, Info 0x19c01f
2026-09-17T23:41:24 NVRM: Xid (PCI:0000:01:00): 109, pid=15963, name=WowB.exe, channel 0x0000001d, errorString CTX SWITCH TIMEOUT, Info 0x258025
2026-09-18T07:04:26 NVRM: Xid (PCI:0000:01:00): 109, pid=11529, name=WowB.exe, channel 0x0000001d, errorString CTX SWITCH TIMEOUT, Info 0x198025
2026-09-18T07:09:28 NVRM: Xid (PCI:0000:01:00): 109, pid=12835, name=WowB.exe, channel 0x0000001e, errorString CTX SWITCH TIMEOUT, Info 0x13c027
2026-09-18T07:18:53 NVRM: Xid (PCI:0000:01:00): 109, pid=15987, name=WowB.exe, channel 0x00000024, errorString CTX SWITCH TIMEOUT, Info 0x11c02e
615.71.09 / kernel 7.2.4
2026-09-18T08:06:50 NVRM: Xid (PCI:0000:01:00): 109, pid=9803, name=WowB.exe, channel 0x0000001c, errorString CTX SWITCH TIMEOUT, Info 0x12c01e
Logs and bug report: sent privately, not attached here
I have not attached nvidia-bug-report.log.gz to this public thread, because it contains system-identifying information (hostname, network interfaces, hardware identifiers, user name). I sent it by email to linux-bugs@nvidia.com instead, together with the full Xid list above, under this subject:
Xid 109 CTX SWITCH TIMEOUT on RTX PRO 5000 Blackwell Laptop (GB203GLM) - WoW: Forever beta via Proton, 610.57.04 and 615.71.09, D3D11 and D3D12
NVIDIA staff can match the report by this subject. If anyone needs specific sections of the log, I’m happy to post excerpts here.
I’m happy to test debug builds or options.
Confirming the non-RT scope described in posts 5 and 6. Ray tracing is not merely disabled on my system, it is unavailable: the client reports rt:None under both APIs, crash dumps carry 0, and WowB.exe ships only dx_6_0 shader permutes while DXR requires SM 6.3+. The hang occurs regardless.
System
GPU NVIDIA GeForce RTX 5090 (VBIOS 98.02.2E.00.03)
Driver 615.71.09 (open kernel module)
Vulkan 1.4.351
Kernel 7.2.6-1-cachyos-bore
OS CachyOS, KDE Plasma, Wayland session
Wine 11.0.0 (GE-Proton11-5, and proton-cachyos CachyOS-11.0-100)
Client WoW “Forever” Beta 1.60.1, builds 69893 and 69913
Signature — 18 occurrences, identical every time:
NVRM: Xid (PCI:0000:01:00): 109, name=WowB.exe,
channel 0x0000000e / 0x10 / 0x11 / 0x12 / 0x1f,
Client-side, gx.log:
Failure in WaitForFence
The frozen thread’s stack is the same on all 18: ntdll → kernelbase → d3d12core → dxgi → WowB.exe. It deadlocks in Present().
The GPU is idle when it hangs. Client telemetry taken seconds before each fault: Freq 0.28–1.00 GHz, Temp 38–46 °C, VRAM 2.5 GB / 28.8 GB. nvidia-smi -q shows zero thermal and power-brake slowdown events for the entire uptime, and no channel or TPC repair pending. Card is at stock — 575 W limit against a 575 W default, no undervolt or overclock.
The finding I think is useful: a warm renderer survives what a cold load cannot.
Affected zones are Stormwind (MapId 0) and the Deeprun Tram (MapId 369); most zones are unaffected. At maximum settings:
  • Cold load into either zone in a fresh process: hangs roughly 7 times in 8, within 3–5 seconds of the loading screen being dismissed.
  • Walking in overland from an adjacent zone with the renderer already running: renders the entire city without fault, at 69% GPU utilisation and 397 W, sustained.
Same character, same coordinates, same settings, same on-disk shader cache — the only variable is whether render state was constructed during a cold load or streamed in progressively. Every fault I have occurs during scene construction or a Render Settings Changed event, never during steady-state rendering of already-constructed geometry. The consistent ~3 s delay from settings change to fault, and the non-deterministic rate, both suggest a race rather than a pathological workload.
Eliminated by direct test (so nobody repeats them): D3D12/vkd3d-proton vs D3D11/DXVK — both hang; GE-Proton11-5 vs proton-cachyos — both hang; native Wayland vs XWayland — both hang; VKD3D_CONFIG=single_queue, verified live in /proc//environ — no effect; NVIDIA Reflex disabled — no effect; Battle.net scan-and-repair, which did re-fetch data — no effect; MSAA, and the refraction CVar forced off — no effect.
Possibly relevant: the same trigger is reported on AMD RX 7900 XTX under Windows 11 (Blizzard bug report 2353286, confirmed by a second user on a 9070XT) — driver timeout loading into Stormwind under DX12, consistently on zone-in. That suggests the client submits work that stresses schedulers generally rather than anything NVIDIA-specific.
But the part that seems squarely a driver issue is that it is unrecoverable. After the hang, recovery never completes — gx.log repeats Failure in WaitForFence every 3 seconds indefinitely, and Dx12 Device Destroy never returns. The process must be SIGKILLed. Whatever the application submits, a context-switch timeout ought to be recoverable by engine reset rather than wedging the channel permanently.
Also noting for scope: 615.71.09’s release notes mention an Xid 109 fix, which does not cover this case. Post 5 reports 610.57.04 affected as well, so a rollback is not a workaround.
I have discovered the login hang issue to be fixed with this in config.wtf
Forever Secondary Lighting is now Fair:
SET graphicsLightMode “0”
SET raidGraphicsLightMode “0”
SET giQuality “1”
SET RAIDgiQuality “1”
Sucks, but it does work.
nvidia-bug-report.log.gz (914.2 KB)Adding an Ampere (GA102) data point — WoW Classic Beta, driver 595.99.02, no ray tracing, reproduces on both D3D12 and D3D11
Most reports in this thread are Blackwell on the 615 branch. I’m seeing the same failure signature on a 3080 Ti on 595, which suggests the issue is broader than one architecture or branch.
Environment
  • GPU: NVIDIA GeForce RTX 3080 Ti, 12 GB (GA102)
  • CPU: AMD Ryzen (ASUS PRIME B650-PLUS, BIOS 3057)
  • Driver: 595.99.02, open kernel module; userspace libraries match
  • OS/kernel: Nobara 44, 7.2.4-202.nobara.fc44.x86_64
  • Session: XWayland (winex11.drv loaded in the Wine process)
  • Game: WoW Classic Beta (project Camelot), 1.60.1.69893, WowB.exe
  • Launchers tested: Steam Proton and Heroic — both reproduce
Failure signature
NVRM: Xid (PCI:0000:01:00): 109, pid=…, name=WowB.exe,
channel 0x0000002b, errorString CTX SWITCH TIMEOUT, Info 0x3ac028
Captured across multiple boots with channels 0x21, 0x2b and 0x2e, Info values 0x208020 through 0x7cc028. Always WowB.exe, always Xid 109, never any other process.
Not ray tracing. The Classic client has no RT path and RTShadows is 0 in the crash dumps. The shadowRt workaround reported upthread does not apply here.
Not the translation layer. This is the part I think is most useful. I reproduced the identical hang on both APIs:
  • GxApi "D3D12" → vkd3d-proton
  • GxApi "D3D11" → DXVK
The client’s watchdog reports ERROR #109 A thread has become unresponsive, with the frozen thread parked in Present. On the D3D11 run the stack every second for 20 consecutive seconds was:
ntdll (wait) → kernelbase (wait) → d3d11.dll → dxgi.dll → WowB.exe
Meanwhile dxvk-queue and dxvk-frame were both inside winevulkan.dll. Client header for that run: GxDeviceLostCount 1, GxRestarts 1, GxFailedFrameStartRestarts 1.
Since vkd3d-proton and DXVK are separate codebases and both hang the same way, the fault appears to sit below them.
Possibly related: GPU VA space exhaustion. Five seconds before one of the Xids, the kernel logged:
NVRM: dmaAllocMapping_GM107: can't alloc VA space for mapping.
NVRM: nvAssertOkFailedNoLog: Assertion failed: Out of memory [NV_ERR_NO_MEMORY] (0x00000051)
returned from pReuseMappingDb->pMapCb(...) @ mapping_reuse.c:273
This was not VRAM or system memory pressure — 12 GB VRAM and ~20 GB system RAM were free at the time. I haven’t seen this reported alongside the Xid 109 cases in this thread and don’t know whether it’s causal or coincidental.
Trigger. The hang correlates strongly with entering the world server, not with the login screen, character select, or steady-state play. Crash dumps show Time in World of about 15 seconds. Sessions that survive zone-in have then run for hours. That’s the heaviest concentrated resource-mapping window in the client, which may connect to the VA space error above.
Versions tested
  • 595.99.02 — fails
  • 595.91.07 — fails (same signature, ~314s into the session)
  • 595.84 — could not test; does not build against kernel 7.2.4
So the fault spans at least two builds within 595, and per the reports upthread also 615.71.09. Combined with the earlier report of a fallback to 590.44.01, the affected range looks wide.
Post-fault state: consistent with other reports, nvidia-smi becomes unusable after the Xid and a reboot is required.
I have not tested the proprietary kernel module
Adding an Ada data point and, I think, the cause. Short version: on the Forever Beta build this does not look like a driver bug. One of the game’s compute shaders never terminates on the first frame after a cold world load, and Xid 109 is the driver correctly giving up on a context that will not yield.
System: RTX 4060 Laptop (AD107, 8 GB), 615.71.09 open kernel modules, Linux 7.2, Arch, Hyprland (XWayland), GE-Proton11-7 (vkd3d-proton 3.1.0), WowB.exe 1.60.1.69913, 3840x2160. nvidia-bug-report.log.gz attached.
Symptom: identical to the posts above. `NVRM: Xid (PCI:0000:01:00): 109, name=WowB.exe, errorString CTX SWITCH TIMEOUT`, then VK_TIMEOUT / VK_ERROR_DEVICE_LOST on the graphics queue, gx.log “GPU Hung”, client ERROR #109. No ray tracing involved (rt:None on this build). 12 of 12 cold world loads, D3D12 and D3D11/DXVK alike.
Repro: Secondary Lighting = High, restart the client, log in, Enter World. It does not reproduce with Secondary Lighting = Fair, and switching Fair → High inside an already loaded world keeps working until the next relaunch, which matches the “cold loads hang, walking in does not” observation above.
What I did
- Ruled out by real world entries: clean boot with nothing else on the GPU; D3D11 vs D3D12; every optional vkd3d-proton extension (descriptor_buffer, descriptor_heap, mesh shaders, fragment shading rate, NV low latency, DXR).
- Captured the Vulkan stream with GFXReconstruct. Replaying the capture reproduces the same Xid 109 with the process name gfxrecon-replay, so the game, Wine and CPU-side timing are out of the picture.
- Stopping the replay after the loading screen is clean; stopping after the first world frame already hangs.
- Replacing compute shaders with an empty main at replay time (`–replace-shaders`) and halving: exactly one shader matters. It is a small job, 8x8x8 groups of 4x4x4 threads, run 8 times in that frame; it samples a cube map, walks a tree stored in structured buffers with an explicit stack, and writes a storage image. Its two traversal loops have no iteration limit.
- The same shader with a 4096-iteration cap added to those two loops, nothing else changed: the first world frame and the whole 1122-frame capture replay clean.
- Rewriting the shader’s SPV_NV_raw_access_chains accesses as plain access chains did not help, so that extension is not involved. Memory barriers are present between all dispatches in that command buffer.
So the tree data the shader walks is not terminating on the first frame after a cold load, and the shader has no bound to fall back on. macOS users on the Blizzard forum isolated the same setting (Secondary Lighting) for whole-system freezes on Apple GPUs, which fits an application bug better than a driver one. I have reported it to Blizzard through the in-game bug reporter (my account cannot post on their forums); if someone here can, the Mac thread “WoW: Forever Beta freezes entire Mac when entering the world” in their Bug Report forum is the place where a pointer would help.
Workaround without losing the setting globally: Secondary Lighting = Fair before Enter World; it can be raised again once in the world, until the next relaunch.
I can provide the GFXReconstruct capture to NVIDIA engineers privately if it is useful; I am not attaching it publicly because it contains game assets.
This covers the non-ray-tracing beta case only. The shadowRt reports earlier in this thread (Retail 12.1 / Classic 1.15.9) may be a different shader; I have not tested those clients.
I have the same issue with Cyberpunk 2077 + Ray Tracing enabled after updating to 615.71.09
I tried going going back to 610 and did not have the issue anymore
Enabling ray tracing locks up the game and crashes it everytime, this is what the kernel shows
NVRM: Xid (PCI:0000:01:00): 109, pid=5975, name=GameThread, channel 0x0000000a, errorString CTX SWITCH TIMEOUT, Info 0x1c007 =51094 LEN=420
NVRM: Xid (PCI:0000:01:00): 109, pid=74343, name=GameThread, channel 0x00000015, errorString CTX SWITCH TIMEOUT, Info 0xfc016
Same happens on different distros, tested on Ubuntu 26.04 and CachyOS latest, doesn’t matter the kernel, tried also different Proton versions and parameters
Asus Tuf Dash F15 Laptop + NVIDIA RTX 3060 Mobile 6GB + 24GB RAM + 11th Gen Intel(R) Core™ i7-11370H @ 3.30GHz
I am also getting this ray tracing crash in Cyberpunk 2077, same Xid log.
| NVIDIA-SMI 615.78.08 KMD Version: 615.78.08 CUDA UMD Version: 13.4
Operating System: CachyOS Linux
KDE Plasma Version: 6.8.2
KDE Frameworks Version: 6.31.0
Qt Version: 6.12.0
Kernel Version: 7.3.0-4-cachyos (64-bit)
Graphics Platform: Wayland
Processors: 32 × AMD Ryzen 9 5950X 16-Core Processor
Memory: 32 GiB of RAM (31.2 GiB usable)
Graphics Processor: NVIDIA GeForce RTX 3090
