System
- Laptop: ASUS ROG Zephyrus G14 2023 (GA402XZ-), BIOS 318
- CPU/iGPU: Ryzen 9 7940HS / Radeon 780M
- dGPU: GeForce RTX 4080 Laptop GPU
- Driver: 615.78.08, open kernel modules
- OS: CachyOS, kernel 7.2.10, KDE Plasma 6 (Wayland)
- Module parameters:
nvidia_modeset.hdmi_deepcolor=Y,nvidia_modeset.disable_hdmi_frl=N
Display
- Samsung S95H OLED TV (2026). The EDID reports the product name “S95F”. All HDMI inputs support up to 4K@165.
- TV settings: Game Mode = On, Input Signal Plus = On for the input in use
- TV firmware: 1301
Problem
On the laptop’s native HDMI port, the driver only exposes modes up to 600 MHz pixel clock, i.e. TMDS only. 4K@60, 2560x1440@120 and 1080p@165 are available. Everything that needs FRL is missing: VIC 117/118, 4K@144/165. Adding custom modes via KWin (3840x2160@120 and @100, reduced and full blanking) is rejected: “The driver rejected the output configuration”.
Driver debug log With nvidia_modeset debug=1 and hot-plugging the TV (Game Mode on), the log shows:
nvidia-modeset: GPU:0: HdmiPacketLibrary: ERROR - RM call to set HDMI FRL failed.
After that, only TMDS modes are offered. Without debug logging nothing is printed, and there is no “HDMI FRL link training failed” warning. From the open-gpu-kernel-modules source, this appears to be the link assessment on hotplug: nvDpyProbeMaxPixelClock() → nvHdmiFrlAssessLink() → NvHdmi_AssessLinkCapabilities2()
On a Samsung Odyssey Neo G7 Monitor 4k@165 with HDR enabled works, with my Desktop PC (RTX 4080, Windows 11) 4k@165Hz with HDR enabled works with the S95H TV also.
So the laptop’s HDMI port and the Linux driver can do FRL, the cable can do FRL, and the TV accepts FRL from an NVIDIA source on Windows. Only the combination of this laptop on Linux and the S95H fails at the FRL step. Not tested: this laptop on Windows with the TV, because Windows is no longer installed.
Also tried, no change:
- HDR on/off
- TV power cycle via power button
- Re-plugging the cable after enabling Game Mode
- Other TV inputs: all are specified for 4K@165
Attached
- nvidia-bug-report.log.gz, generated with the TV connected via native HDMI (HDMI-0). The journal of the previous boot in the report contains the five “RM call to set HDMI FRL failed” lines (Okt 16 14:24:26–27), and
/proc/driver/nvidia-modeset/dpyscontains the full TV EDID. At the time of the report,enhanced_pcon_support=Ywas set from the PCON test; it was not set during the failing hotplug. - EDID of the S95H, decoded with di-edid-decode
s95h-edid.txt (9.5 KB)
nvidia-modeset-log.txt (5.6 KB)
nvidia-bug-report.log.gz (631.5 KB)
