Summary
I am experiencing recurring application rendering hangs on Linux with the NVIDIA 615.78.08 open kernel modules.
At or immediately before multiple rendering hangs, the kernel prints the following warning:
NVRM: GPU0 memoryMapperWorker: Worker is called , with reference count = 0x1 and pMemoryMapper not null
In one captured incident, this warning appeared approximately three seconds before GPU utilization dropped from approximately 99% to 0%. The game process remained alive and continued consuming significant CPU resources, but rendering stopped indefinitely.
I suspect a possible issue involving memory-mapper worker lifetime, reference counting, or GPU memory mapping. This is a hypothesis, not an established root cause.
System information
GPU: NVIDIA GeForce RTX 4060 Laptop GPU, 8 GiB VRAM
Laptop: Lenovo LOQ
CPU: AMD Ryzen 7 7435HS
RAM: 16 GiB
Distribution: CachyOS
Kernel:
7.3.0-rc6-2-cachyos-rc-gcc -
NVIDIA driver:
615.78.08 -
Kernel module package:
nvidia-open-dkms 615.78.08-2 -
NVIDIA module path:
/lib/modules/7.3.0-rc6-2-cachyos-rc-gcc/updates/dkms/nvidia.ko.zst -
Workload: Nioh 3 (Direct3D 12 through Proton-CachyOS / VKD3D-Proton)
Kernel log evidence
The same warning appeared three times on October 26, 2026 (local time, Europe/Warsaw):
17:07:54 NVRM: GPU0 memoryMapperWorker:
18:18:58 NVRM: GPU0 memoryMapperWorker:
20:50:36 NVRM: GPU0 memoryMapperWorker:
The final event was correlated with separately recorded GPU and CPU telemetry:
| Time | Observation |
| Immediately before 20:50:36 | GPU under heavy rendering load, reaching approximately 99% |
| 20:50:36 | memoryMapperWorker warning logged |
| Approximately 20:50:39 | GPU utilization falls to 0% |
| After the stall | Game process remains CPU-active, approximately 900–1070% of one logical CPU |
| After the stall | GPU rendering does not recover |
VRAM occupancy was approximately 7.3 GiB around the final incident.
There were no NVIDIA GPU Xid errors in the supplied filtered kernel logs. A separate XID 541 message belongs to the Realtek r8169 Ethernet driver, not the NVIDIA GPU.
Observed behavior
Rendering freezes permanently during gameplay.
In-game music can continue playing.
Some UI interactions remain audible or responsive.
Game logic and rendering no longer advance normally.
GPU utilization drops to approximately zero while the game process continues consuming substantial CPU time.
The issue has occurred across multiple sessions and graphical configurations.
High VRAM usage is common, but available evidence does not establish a GPU out-of-memory condition.
Relevant source code
The warning originates from memoryMapperWorker in:
src/nvidia/src/kernel/gpu/mem_mgr/mem_mapper.c
In the relevant branch, the worker logs the warning if pMemoryMapper remains non-NULL while numRefs == 1, and returns without calling memmapperProcessWork() for that invocation.
Source:
Could this state represent an unexpected lifecycle or synchronization condition, or is the warning expected and benign?
Reproduction
The problem is intermittent rather than deterministically reproducible.
Run a sustained Direct3D 12 workload via Proton / VKD3D-Proton.
Continue normal gameplay with high GPU utilization and substantial VRAM occupancy.
In some sessions, rendering stops permanently.
The
memoryMapperWorkerwarning appears near the failure.
Changing Proton settings, synchronization mechanisms, frame-rate limits and graphics quality has not reliably eliminated the hangs.
Questions for NVIDIA
Under what conditions is
memoryMapperWorkerexpected to run withnumRefs == 1whilepMemoryMapperremains non-NULL? -
Can this warning indicate pending or skipped memory mapping work that could affect GPU execution?
Is there a known issue or fix affecting this worker in driver 615.78.08?
What additional tracing or debugging data would best establish whether the worker warning is causal or merely a consequence of an earlier stall?
I can provide timestamped kernel logs, GPU/CPU/VRAM telemetry, Proton logs and additional diagnostic data if needed.
Thank you for investigating.
