615: Xid 109 with VK_KHR_opacity_micromap on RTX 3090 Ti
System
  • GPU: NVIDIA GeForce RTX 3090 Ti (GA102, 10de:2203), VBIOS 94.02.A0.00.71
  • Driver: 615.78.08, open kernel module
  • Kernel: 7.3.0-4-cachyos (CachyOS)
  • Session: Hyprland (Wayland), games on native Wayland (PROTON_ENABLE_WAYLAND=1)
  • Proton: GE-Proton11-9 (vkd3d-proton 3.1.0, DXVK-NVAPI 0.9.2)
RTXPT v1.8.1 (prebuilt binaries from Releases · NVIDIA-RTX/RTXPT · GitHub , default settings, OMM enabled)
  • The GPU hangs 11–17 s after startup:
    NVRM: Xid (PCI:0000:01:00): 109, pid=8426, name=Rtxpt.exe, channel 0x0000000b, errorString CTX SWITCH TIMEOUT, Info 0x6c00f
  • vkd3d-proton exposes SM 6.9 / DXR 1.2. No NVAPI OMM calls appear in the log.
  • With VKD3D_DISABLE_EXTENSIONS=VK_KHR_opacity_micromap, vkd3d-proton exposes SM 6.8 / DXR 1.1, and RTXPT refuses to start (“Shader Model 6.9 is required”).
  • With VKD3D_CONFIG=descriptor_heap: no hang during a 120 s run. SM 6.9 / DXR 1.2 are still exposed, and the log shows NvAPI_D3D12_GetRaytracingOpacityMicromapArrayPrebuildInfo and NvAPI_D3D12_BuildRaytracingOpacityMicromapArray being called.
RTXPT v1.7.0 (OMM enabled, “Force 2 state”, tested on GE-Proton11-7, same vkd3d-proton 3.1.0)
  • No hang. NvAPI_D3D12_GetRaytracingOpacityMicromapArrayPrebuildInfo and NvAPI_D3D12_BuildRaytracingOpacityMicromapArray are called.
Cyberpunk 2077 (v2.31, GOG), ray tracing or path tracing enabled
  • The GPU hangs when loading the game:
    NVRM: Xid (PCI:0000:01:00): 109, pid=100818, name=GameThread, channel 0x00000013, errorString CTX SWITCH TIMEOUT, Info 0x2c013
  • With VKD3D_DISABLE_EXTENSIONS=VK_KHR_opacity_micromap: no hang, and path tracing works.
  • With VKD3D_CONFIG=descriptor_heap: still hangs.
  • Under XWayland (PROTON_ENABLE_WAYLAND=0): still hangs.
  • Path tracing works on this card under Windows.
Driver 610.57.04
  • It exposes VK_EXT_opacity_micromap but not VK_KHR_opacity_micromap.
  • vkd3d-proton 3.1.0 reports OMM as unsupported and exposes DXR 1.1 only.
  • Cyberpunk 2077 with path tracing loads a save and runs, with no Xid.
Related
nvidia-bug-report.log.gz attached, captured right after an RTXPT 1.8.1 hang.
Analysis (Claude Opus 5.5 Medium)
The hang happens whenever opacity micromaps go through VK_KHR_opacity_micromap on 615. With descriptor_heap, RTXPT 1.8.1 builds its OMMs through NVAPI instead of DXR 1.2. That looks like a different code path, not a workaround, and matches RTXPT 1.7.0’s NVAPI path working. Driver 610 “fixing” Cyberpunk is most likely because 610 has no KHR extension, so OMM is never used, the same effect as disabling the extension on 615. Since some uses of the extension work and others hang, the bug probably depends on how the OMMs are built or used. Ampere has no hardware OMM support, so the driver’s non-hardware OMM path is a plausible place for it.
nvidia-bug-report.log.gz (1002.6 KB)
