I’m just getting started with CUDA and I am going through Super Computing for the masses found here
http://www.ddj.com/architect/207200659
When I build the code below using Visual Studio I get this
Error 1 fatal error LNK1112: module machine type ‘x64’ conflicts with target machine type ‘X86’ c:\Users\Michael\Documents\Visual Studio 2008\Projects\cudafun\cudafun\Debug\moveArrays.cu.obj 1 cudafun
I’m using a build rule I found somewhere on the internet(can’t seem to figure out exactly where now).
Everything I have is 64-bit. I’ve even went through and double checked. Visual studio is 64-bit(I double checked to make sure I installed everything), windows 7 is 64-bit and I did install the 64-bit version of CUDA.
I’m guessing some Project option isn’t set right.
[codebox]// moveArrays.cu
// demonstrates CUDA interface to data allocation on device (GPU)
// and data movement between host (CPU) and device.
#include <stdio.h>
#include <assert.h>
#include <cuda.h>
int main(void)
float *a_h, *b_h; // pointers to host memory
float *a_d, *b_d; // pointers to device memory
int N = 14;
int i;
// allocate arrays on host
a_h = (float *)malloc(sizeof(float)*N);
b_h = (float *)malloc(sizeof(float)*N);
// allocate arrays on device
cudaMalloc((void **) &a_d, sizeof(float)*N);
cudaMalloc((void **) &b_d, sizeof(float)*N);
// initialize host data
for (i=0; i<N; i++) {
a_h[i] = 10.f+i;
b_h[i] = 0.f;
// send data from host to device: a_h to a_d
cudaMemcpy(a_d, a_h, sizeof(float)*N, cudaMemcpyHostToDevice);
// copy data within device: a_d to b_d
cudaMemcpy(b_d, a_d, sizeof(float)*N, cudaMemcpyDeviceToDevice);
// retrieve data from device: b_d to b_h
cudaMemcpy(b_h, b_d, sizeof(float)*N, cudaMemcpyDeviceToHost);
// check result
for (i=0; i<N; i++)
assert(a_h[i] == b_h[i]);
// cleanup
free(a_h); free(b_h);
cudaFree(a_d); cudaFree(b_d);
}[/codebox]
