The tp 6 solutions, uses all 6 nodes processing power or only 4 and the rest are only to hold the weights? Can you share the yaml and docker build solution please? I want to compare the speed to the 8 nodes solution, if close enough, I gain 2 nodes to use for other model/mcp :)
Thanks! RE: TP=6 → Part of my setup, I have to utilize b12x in order to do the virtual padding. I run a little server that switched profiles/recipes for me, which includes mods, patches, scripts, etc…
with GLM 5.2, I was able to get 2-4 concurrent streams working decently around 16-24t/s on the decode each. Very usable. I am more excited to see what I can get from the new DeepSeek v4 flash though.
I am not really impressed with GLM. 5.2 for coding. I was using it as escalation for coding tasks flash couldn’t complete but it fails on the same tasks.
