ModelImporter.cpp:726: ERROR: builtin_op_importers.cpp:2985 In function importPad:
[8] Assertion failed: inputs.at(1).is_weights() && “The input pads is required to be an initializer.”
Environment
TensorRT Version: 8.0.3.4 GPU Type: 2080Ti Nvidia Driver Version: 495 CUDA Version: 11.3 CUDNN Version: Operating System + Version: 18.04 Python Version (if applicable): TensorFlow Version (if applicable): PyTorch Version (if applicable): Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
I checked it before and know that tensorrt doesnot support dynamic padding size, however, what I want to do is to solve the problem, for example, using graphsurgeon to modifiy the Padding node’s inputs pads to be a constant, do you know is that solution viable and how to do that?
You can try following. If you still face issue, we recommend you to please share issue reproducible onnx model to try from our end for better debugging.
