Dear,
We implement camera on our carried board.
@ our system hw structure
CMSO 12bit → MAX96705(SER) Removes the lower 4 bits of 12 bits = RAW 8bit - MAX9286(DESRI) - MIPI 2 CSI
@ device node
mode0 {
mclk_khz = “24000”;
num_lanes = “4”;
tegra_sinterface = “serial_a”;
discontinuous_clk = “yes”;
dpcm_enable = “false”;
cil_settletime = “0”;
active_w = "1280"; //3840
active_h = "800"; //2160
pixel_t = "RAW_RGGB"; //user code
readout_orientation = "90";
line_length = "4200"; //4208
inherent_gain = "1";
mclk_multiplier = "24";
pix_clk_hz = "756000000"; //576000000 sensor data rate per lane (Mbps) * number of lanes / bits per pixel
min_gain_val = "1.0";
max_gain_val = "16.0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "1.5";
max_framerate = "60";
min_exp_time = "16.165";
max_exp_time = "666637";
embedded_metadata_height = "1";
@ 8-bit Bayer RGRG/GBGB
nvidia@tegra-ubuntu:/media/nvme$ v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘RGGB’
Name : 8-bit Bayer RGRG/GBGB
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 1920x1080
@ v4l2-ctl by recording of the size = 1280x800
nvidia@tegra-ubuntu:/media/nvme$v4l2-ctl -d /dev/video0 --set-fmt-video=width=1280,height=800,pixelformat=RGGB --set-ctrl bypass_mode=0 --stream-mmap --stream-count=200 --stream-to=t.raw --verbose;
After saving in RGGB format, when playing back to mplayer Y8 video format, it will scroll up and down.
Is there anything else that needs to be fixed on the kernel side?
