9 screen 3x3 Videowall, Debian 10, NVS 510 Cards
As a fun experiment I have been struggling for a while now trying to use a box with 3 x NVS 510 videocards to drive a 3x3 videowall using Debian 10 Buster and ideally xrandr 1.5 (instead of the old Xinerama way).
I feel like I just need a solid foodhold, but here is where I am so far:
To simplify everything I’ve done, I’ll delete xorg.conf and run the following command:
nvidia-xconfig --sli=Mosaic --metamodes="GPU-0.DP-0: 1920x1080+0+0, GPU-0.DP-1: 1920x1080+1920+0, GPU-0.DP-2: 1920x1080+3840+0, GPU-0.DP-3: 1920x1080+0+1080, GPU-1.DP-0: 1920x1080+1920+1080, GPU-1.DP-1: 1920x1080+3840+1080, GPU-1.DP-2: 1920x1080+0+2160, GPU-1.DP-3: 1920x1080+1920+2160, GPU-2.DP-0: 1920x1080+3840+2160"
This is straight out of Chapter 30 of the README for this driver (460.73.01 from Buster-backports).
Central problem is that the Xorg log seems to totally disregard SLI and put me in BaseMosaic mode, which doesn’t work either. The pertinent section from the X log is here:
[   720.009] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[   720.009] (==) NVIDIA(0): RGB weight 888
[   720.009] (==) NVIDIA(0): Default visual is TrueColor
[   720.009] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[   720.009] (**) NVIDIA(0): Option "SLI" "Mosaic"
[   720.009] (**) NVIDIA(0): NVIDIA SLI Mosaic mode selected.
[   720.009] (**) NVIDIA(0): Option "MetaModes" "GPU-0.DP-0: 1920x1080+0+0, GPU-0.DP-1: 1920x1080+1920+0, GPU-0.DP-2: 1920x1080+3840+0, GPU-0.DP-3: 1920x1080$
[   720.009] (**) NVIDIA(0): Enabling 2D acceleration
[   720.009] (II) Loading sub module "glxserver_nvidia"
[   720.009] (II) LoadModule: "glxserver_nvidia"
[   720.010] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[   720.015] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[   720.015]    compiled for 1.6.99.901, module version = 1.0.0
[   720.015]    Module class: X.Org Server Extension
[   720.015] (II) NVIDIA GLX Module  460.73.01  Thu Apr  1 21:35:16 UTC 2021
[   720.015] (II) NVIDIA: The X server does not support PRIME Render Offload.
[   720.016] (WW) NVIDIA(GPU-0): The "BaseMosaic" X configuration option should be used for
[   720.016] (WW) NVIDIA(GPU-0):     this configuration instead of the "SLI" "Mosaic" option.
[   720.016] (WW) NVIDIA(GPU-0):     The "BaseMosaic" option will be assumed.  Please see
[   720.016] (WW) NVIDIA(GPU-0):     Chapter 30: Configuring SLI and Multi-GPU Mosaic and
[   720.016] (WW) NVIDIA(GPU-0):     Appendix B: X Config Options for more information.
[   720.017] (II) NVIDIA(GPU-0): NVIDIA SLI enabled.
[   720.017] (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
[   720.017] (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
[   720.017] (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:2:0:0 is part of an active SLI
[   720.017] (EE) NVIDIA(GPU-0):     configuration and is currently unavailable for single GPU
[   720.017] (EE) NVIDIA(GPU-0):     rendering.  Please see Chapter 30: Configuring SLI and
[   720.017] (EE) NVIDIA(GPU-0):     Multi-GPU Mosaic in the README for troubleshooting
[   720.017] (EE) NVIDIA(GPU-0):     information.
[   720.017] (EE)  *** Aborting ***
[   720.017] (EE) NVIDIA(0): Failing initialization of X screen
[   720.017] (II) UnloadModule: "nvidia"
[   720.017] (II) UnloadSubModule: "glxserver_nvidia"
[   720.017] (II) Unloading glxserver_nvidia
[   720.017] (II) UnloadSubModule: "wfb"
[   720.017] (II) UnloadSubModule: "fb"
[   720.017] (**) NVIDIA(G0): Depth 24, (--) framebuffer bpp 32
[   720.017] (==) NVIDIA(G0): RGB weight 888
[   720.018] (==) NVIDIA(G0): Default visual is TrueColor
[   720.018] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[   720.018] (**) NVIDIA(G0): Option "SLI" "Mosaic"
[   720.018] (**) NVIDIA(G0): NVIDIA SLI Mosaic mode selected.
[   720.018] (WW) NVIDIA(G0): SLI is available only on screen 0.  Disabling SLI.
[   720.018] (EE) NVIDIA(G0): Only one X screen is supported when SLI is enabled.  Disabling
[   720.018] (EE) NVIDIA(G0):     this screen.
[   720.018] (EE) NVIDIA(G0): Failing initialization of X screen
[   720.018] (II) NVIDIA(G1):  (GPU-2) already has an X screen assigned; skipping this GPU
[   720.018] (II) NVIDIA(G1):     screen
[   720.018] (EE) NVIDIA(G1): Failing initialization of X screen
[   720.018] (II) UnloadModule: "nvidia"
[   720.018] (II) UnloadSubModule: "wfb"
[   720.018] (II) UnloadSubModule: "fb"
[   720.018] (EE) Screen(s) found, but none have a usable configuration.
[   720.018] (EE)
Fatal server error:
[   720.018] (EE) no screens found(EE)
[   720.018] (EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
[   720.018] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   720.018] (EE)
[   720.019] (EE) Server terminated with error (1). Closing log file.
I cannot figure out why it’s refusing to support the SLI mode explicitly recommended in Nvidia’s documentation. Can anyone point me to something I’m missing?
nvidia-bug-report.log.gz (857.8 KB)
Attached nvidia bug report log.
Additional info:
There are 3 cards which have PCI Bus IDs 1 2 and 3.
There are 9 total monitors connected (all via displayport, interfaces named DP-0, DP-1 etc)
4 monitors connected to a card, 4 monitors connected to the second card, 1 monitor connected to the final card.
Looks like the NVS cards are not SLI capable, so you’ll have to use BaseMosaic instead of SLIMosaic.
Gladly, but I see this in the X log when BaseMosaic is enabled:
[ 15351.516] (II) NVIDIA GLX Module  460.73.01  Thu Apr  1 21:35:16 UTC 2021
[ 15351.516] (II) NVIDIA: The X server does not support PRIME Render Offload.
[ 15351.517] (II) NVIDIA(GPU-0): NVIDIA Base Mosaic enabled.
[ 15351.518] (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
[ 15351.518] (EE) NVIDIA(GPU-0): Only one GPU will be used for this X screen.
[ 15351.518] (EE) NVIDIA(GPU-0): The NVIDIA graphics device PCI:2:0:0 is part of an active SLI
[ 15351.518] (EE) NVIDIA(GPU-0):     configuration and is currently unavailable for single GPU
[ 15351.518] (EE) NVIDIA(GPU-0):     rendering.  Please see Chapter 30: Configuring SLI and
[ 15351.518] (EE) NVIDIA(GPU-0):     Multi-GPU Mosaic in the README for troubleshooting
[ 15351.518] (EE) NVIDIA(GPU-0):     information.
[ 15351.518] (EE)  *** Aborting ***
[ 15351.518] (EE) NVIDIA(0): Failing initialization of X screen
[ 15351.518] (II) UnloadModule: "nvidia"
[ 15351.518] (II) UnloadSubModule: "glxserver_nvidia"
[ 15351.518] (II) Unloading glxserver_nvidia
[ 15351.518] (II) UnloadSubModule: "wfb"
[ 15351.518] (II) UnloadSubModule: "fb"
[ 15351.518] (**) NVIDIA(G0): Depth 24, (--) framebuffer bpp 32
[ 15351.518] (==) NVIDIA(G0): RGB weight 888
[ 15351.518] (==) NVIDIA(G0): Default visual is TrueColor
[ 15351.518] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 15351.518] (**) NVIDIA(G0): Option "nvidiaXineramaInfo" "FALSE"
[ 15351.518] (**) NVIDIA(G0): Option "BaseMosaic" "TRUE"
[ 15351.518] (WW) NVIDIA(G0): Base Mosaic is available only on screen 0.  Disabling Base
[ 15351.518] (WW) NVIDIA(G0):     Mosaic.
[ 15351.518] (EE) NVIDIA(G0): Only one X screen is supported when Base Mosaic is enabled.
[ 15351.519] (EE) NVIDIA(G0):     Disabling this screen.
[ 15351.519] (EE) NVIDIA(G0): Failing initialization of X screen
[ 15351.519] (II) NVIDIA(G1):  (GPU-2) already has an X screen assigned; skipping this GPU
[ 15351.519] (II) NVIDIA(G1):     screen
[ 15351.519] (EE) NVIDIA(G1): Failing initialization of X screen
[ 15351.519] (II) UnloadModule: "nvidia"
[ 15351.519] (II) UnloadSubModule: "wfb"
[ 15351.519] (II) UnloadSubModule: "fb"
[ 15351.519] (EE) Screen(s) found, but none have a usable configuration.
[ 15351.519] (EE)
Fatal server error:
[ 15351.519] (EE) no screens found(EE)
[ 15351.519] (EE)
 for help.
[ 15351.519] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 15351.519] (EE)
[ 15351.520] (EE) Server terminated with error (1). Closing log file.
Do you know why X seems to insist the cards are actively in an SLI configuration if this is impossible?
I guess this is a driver bug introduced with the recent SLI drop. Can you try this with an earlier driver, or even the 390 legacy diver?
Dropping to 418 fixed this issue and I can see all 9 connected screens.
Mosaic still not working but I am confident this is a configuration issue and unrelated to my original thread problem. So research continues.
