Upon connecting external HDMI monitor Xsession drops and I get logged out. Problem is resolved if I delete the auto-generated 90-nvidia.conf but in this case GPU doesn’t work even though it appears loaded on prime-select. nvidia-bug-report.log.gz (930.9 KB)
thanks for the info. I’m running Opensuse Leap 15.4 (kernel 5.14.21-150400.22-default) with KDE Plasma. Unfortunately some of the info in the referred thread was inapplicable.
I’m trying to get the GPU to work without forcibly logging me off upon connection with an external monitor. I’ll be happy to provide other info.
Please see attached the bug reports before (pre) and after (post) the external monitor is connected. Both were obtained after I deleted the 90-nvidia.conf and rebooted. As mentioned earlier:
the GPU did not load as a result of deleting 90-nvidia.conf even though prime-select says its loaded.
thanks but unfortunately I couldn’t find how/where this should be done. I’m attaching /etc/X11/xinit/xinitrc and /etc/X11/xinit/xinitrc.common where I suspect this should be done and would appreciate any additional guidance. Thanks xinitrc (1.1 KB) xinitrc.common (5.1 KB)
thank you but unfortunately it didn’t seem to have made a difference. If I delete 90-nvidia.conf, upon reboot the GPU does not load (despite what prime-select says) and it goes into the Intel. I attach the updated /etc/dracut.conf.d/60-nvidia-default.conf and bug-report. 60-nvidia-default.conf (125 Bytes) nvidia-bug-report.log.gz (893.6 KB)
thank you for the suggestion. Unfortunately the problem persists and seems to be closely tied to the 90-nvidia.conf file, i.e. something important points to it and unless it’s in place the load collapses. I would try a complete unistall/re-install. Is there anything I’d be particularly mindful of?
