I recently updated from L4T 32.6.1 to 35.1.0. I use the Jetsone Xavier NX devkit with eMMC and had set up unified bootloader/rootfs A/B slots redundancy with the 32.6.1 release of L4T. This basically meant using the following elements:
- flash_l4t_t194_spi_emmc_p3668_rootfs_ab.xml
- smd_info.rootfs_AB.cfg and nv_smd_generator
- nv_update_engine and nvbootctrl
With the latest release, I could partition my eMMC correctly using the newer .xml. However, the nv_smd_generator is no longer available, and other tools report an error:
root@myboard:~# /usr/sbin/nv_update_engine -v
Nvidia A/B-Redundancy Update tool Version 2.0
verifying update
Verify bootloader update begins.
Warning: not support yet!
SM: S21
Checking whether Slot-A/B Redundancy and autosync are enabled.
Error: Verify bootloader update failed!
Verify rootfs update begins.
RootFS A/B is not enabled, verification finishes.
root@myboard:~# nv_update_engine -e
enabling A/B redundancy
Segmentation fault
root@COM21000000:~# nvbootctrl is-autosync-enabled
Error querying the status of autosync: Operation not supported
root@myboard:~# nvbootctrl verify
Info: variable BootChainFwStatus is not found.
root@myboard:~# nvbootctrl toggle-autosync
root@myboard:~# nvbootctrl dump-slots-info
Current bootloader slot: A
Active bootloader slot: A
num_slots: 2
slot: 0, status: normal
slot: 1, status: normal
The documentation regarding how to set up slots redundancy seems to have been updated and indeed shows support for some features is not yet available. However it does state that slots redundancy should work and be enabled by default despite the limited tools. Yet, I can’t use nvbootctrl to boot on the second (B) slot with the following command:
nvbootctrl set-active-boot-slot 2
reboot
My queries are the following:
- How can I make slots redundancy work on my hardware and current L4T version?
- Is there planned support for the missing features of the tools I mentioned?
Thank you kindly for your assistance,
Regards
