hello sanaurrehman,
please ignore UEFI, that’s necessary only for JP-5.0.1 or later.
and… sorry about the confusion. you know, too many Jetpack release versions we’re supported right now.
let’s focus on RootfsA/B with JP-4.6 release version.
you should refer to this documentation. Root File System Redundancy.
the Cboot will decrease the
retry_count
of the current rootfs slot. -
When the device boot into the rootfs, there will run a background service
nv_update_verifier.service
, this service will triggerl4t-rootfs-validation-config.service
to say the boot is successful.
however, if the validation script doesn’t exist or returns true, that means the rootfs boot-up successful also. -
If the rootfs validation is true, then the “nv_update_verifier.service” will run “/usr/sbin/nv_update_engine --verify”, the nv_update_engine will increase the retry_count and update slot status.
it’s
nvbootctrl
to switch the rootfs slot.l4t-rootfs-validation-config.service
to validate the rootfs.
so,
you should also have a script, l4t-rootfs-validation-config.sh
to handle it.
you may found this sample within release image.
i.e. ./rootfs/opt/nvidia/l4t-rootfs-validation-config/l4t-rootfs-validation-config.sh
please have a try, looking forward your test results.
see-also topics, Topic 198703, Topic 197124.
