A bug in cusolverDnXgeev with repeated zero eigenvalues
Hi all, I ran into a bug when I tried to solve a nonsymmetric eigenvalue problem with cusolverDnXgeev.
The issue seems to be that if the matrix has many exactly zero eigenvalues, cusolverDnXgeev gives wrong (right) eigenvectors (with NaNs as their entries), while the reference LAPACK gives correct answers.
I attached a minimum reproducer for your references.
! Minimal reproducer: cusolverDnXgeev right eigenvectors for repeated zero eigenvalues, compared with LAPACK dgeev.
! Build: nvfortran -cuda -cudalib=cusolver xgeev_repeat.f90 -llapack -lblas -o xgeev_repeat.f90
! Test output with NVHPC 26.5
! $ ./xgeev_repeat
! diag(0, 0, 1)
! LAPACK dgeev info 0
!   j 1 lambda   0.000   0.000  vr  1.0000E+00  0.0000E+00  0.0000E+00
!   j 2 lambda   0.000   0.000  vr  0.0000E+00  1.0000E+00  0.0000E+00
!   j 3 lambda   1.000   0.000  vr  0.0000E+00  0.0000E+00  1.0000E+00
! cuSOLVER Xgeev status 0, info 0
!   j 2 lambda   0.000   0.000  vr         NaN         NaN         NaN
! diag(0, 1, 1)
!   j 1 lambda   1.000   0.000  vr  1.0000E+00  0.0000E+00  0.0000E+00
!   j 2 lambda   1.000   0.000  vr  0.0000E+00  1.0000E+00  0.0000E+00
!   j 3 lambda   0.000   0.000  vr  0.0000E+00  0.0000E+00  1.0000E+00
! diag(1, 1, 1)
MODULE xgeev
  USE iso_c_binding
  USE cusolverDn
  IMPLICIT NONE
  INTERFACE
    INTEGER(C_INT) FUNCTION cusolverDnXgeev_bufferSize(handle, params, jobvl, jobvr, n, &
      data_type_a, a, lda, data_type_w, w, data_type_vl, vl, ldvl, data_type_vr, vr, ldvr, &
      compute_type, ws_device, ws_host) BIND(C, NAME = 'cusolverDnXgeev_bufferSize')
      IMPORT
      TYPE(cusolverDnHandle), VALUE :: handle
      TYPE(cusolverDnParams), VALUE :: params
      INTEGER(C_INT), VALUE :: jobvl, jobvr
      INTEGER(C_INT64_T), VALUE :: n
      INTEGER(C_INT), VALUE :: data_type_a
      TYPE(*), DEVICE :: a(*)
      INTEGER(C_INT64_T), VALUE :: lda
      INTEGER(C_INT), VALUE :: data_type_w
      TYPE(*), DEVICE :: w(*)
      INTEGER(C_INT), VALUE :: data_type_vl
      TYPE(*), DEVICE :: vl(*)
      INTEGER(C_INT64_T), VALUE :: ldvl
      INTEGER(C_INT), VALUE :: data_type_vr
      TYPE(*), DEVICE :: vr(*)
      INTEGER(C_INT64_T), VALUE :: ldvr
      INTEGER(C_INT), VALUE :: compute_type
      INTEGER(C_SIZE_T) :: ws_device, ws_host
    END FUNCTION cusolverDnXgeev_bufferSize
    INTEGER(C_INT) FUNCTION cusolverDnXgeev(handle, params, jobvl, jobvr, n, &
      compute_type, buf_device, ws_device, buf_host, ws_host, info) &
      BIND(C, NAME = 'cusolverDnXgeev')
      IMPORT
      TYPE(*), DEVICE :: buf_device(*)
      INTEGER(C_SIZE_T), VALUE :: ws_device
      TYPE(*) :: buf_host(*)
      INTEGER(C_SIZE_T), VALUE :: ws_host
      INTEGER(C_INT), DEVICE :: info
  END INTERFACE
END MODULE xgeev
PROGRAM xgeev_repeat
  USE cudafor
  USE cusolverDn
  USE xgeev
  IMPLICIT NONE
  INTEGER, PARAMETER :: dp = KIND(1.d0)
  REAL(dp) :: a(3, 3)
  ! Case 1: diagonal, eigenvalue 0 twice
  a = 0.d0
  a(3, 3) = 1.d0
  CALL compare('diag(0, 0, 1)', 3, a)
  ! Case 2: diagonal, eigenvalue 1 twice
  a = 0.d0
  a(1, 1) = 1.0
  a(2, 2) = 1.0
  CALL compare('diag(0, 1, 1)', 3, a)
  ! Case 3: diagonal, eigenvalue 1 three times
  a = 0.d0
  a(1, 1) = 1.d0
  a(2, 2) = 1.d0
  a(3, 3) = 1.d0
  CALL compare('diag(1, 1, 1)', 3, a)
  CONTAINS
  SUBROUTINE compare(label, n, a_in)
    CHARACTER(LEN = *), INTENT(in) :: label
    INTEGER, INTENT(in) :: n
    REAL(dp), INTENT(in) :: a_in(n, n)
    TYPE(cusolverDnHandle) :: handle
    TYPE(cusolverDnParams) :: params
    REAL(dp) :: a(n, n), vr(n, n), wr(n), wi(n), vldum(1, 1), qw(1)
    REAL(dp), ALLOCATABLE :: work(:)
    COMPLEX(dp) :: w(n)
    REAL(dp), DEVICE :: a_d(n, n), vr_d(n, n)
    COMPLEX(dp), DEVICE :: w_d(n)
    INTEGER(C_INT8_T), DEVICE, ALLOCATABLE :: buf_d(:)
    INTEGER(C_INT8_T), ALLOCATABLE :: buf_h(:)
    INTEGER(C_SIZE_T) :: ws_d, ws_h
    INTEGER(C_INT), DEVICE :: info_d
    INTEGER :: stat, info, j
    WRITE(*, '(/a)') label
    a = a_in
    CALL dgeev('N', 'V', n, a, n, wr, wi, vldum, 1, vr, n, qw, -1, info)
    ALLOCATE(work(INT(qw(1))))
    CALL dgeev('N', 'V', n, a, n, wr, wi, vldum, 1, vr, n, work, SIZE(work), info)
    WRITE(*, '(a,i0)') 'LAPACK dgeev info ', info
    DO j = 1, n
      WRITE(*, '(a,i0,a,2f8.3,a,3es12.4)') '  j ', j, ' lambda', wr(j), wi(j), '  vr', vr(:, j)
    ENDDO
    stat = cusolverDnCreate(handle)
    stat = cusolverDnCreateParams(params)
    a_d = a_in
    info_d = 0
    stat = cusolverDnXgeev_bufferSize(handle, params, CUSOLVER_EIG_MODE_NOVECTOR, &
      CUSOLVER_EIG_MODE_VECTOR, INT(n, C_INT64_T), CUDA_R_64F, a_d, INT(n, C_INT64_T), &
      CUDA_C_64F, w_d, CUDA_R_64F, vr_d, INT(n, C_INT64_T), CUDA_R_64F, vr_d, &
      INT(n, C_INT64_T), CUDA_R_64F, ws_d, ws_h)
    ALLOCATE(buf_d(MAX(1_C_SIZE_T, ws_d)), buf_h(MAX(1_C_SIZE_T, ws_h)))
    stat = cusolverDnXgeev(handle, params, CUSOLVER_EIG_MODE_NOVECTOR, &
      INT(n, C_INT64_T), CUDA_R_64F, buf_d, ws_d, buf_h, ws_h, info_d)
    info = info_d
    w = w_d
    vr = vr_d
    WRITE(*, '(a,i0,a,i0)') 'cuSOLVER Xgeev status ', stat, ', info ', info
    DO j = 1, n
      WRITE(*, '(a,i0,a,2f8.3,a,3es12.4)') '  j ', j, ' lambda', REAL(w(j)), AIMAG(w(j)), &
        '  vr', vr(:, j)
    ENDDO
    stat = cusolverDnDestroyParams(params)
    stat = cusolverDnDestroy(handle)
  END SUBROUTINE compare
END PROGRAM xgeev_repeat
Hi @kimtaeyun ,
Thanks for reporting this. Please let me know the following:
  • which version of cuSOLVER are you using?
  • which GPU is exhibiting this behavior?
Chris
Hi @cgbaker, thank you for the quick response.
I’m using NVHPC 26.5, CUDA 13.2, so cuSOLVER seems to be 12.2.0.1based on the release note.
As to GPU, I’m using A100.
Thanks,
Tae Yun
