a compiler error not caught by PVF 12.10
Hi, everyone,
I tried to compile the source code below where an IMPORT statement is ignored in the second abstract interface area on purpose.
The Intel Visual Fortran compiler 2013 issues a compiler error saying that error #8169: The specified interface is not declared @ the second abstract interface, while the same source code can be compiled using the Portland Visual Fortran 12.10.
Based on the outcome generated by PVF 12.10 above, I am wondering if PVF has accepted the convention of Fortran 2008 already. Can anyone help me out with this question?
Thanks,
Li
MODULE toolbox
    IMPLICIT NONE
    REAL, DIMENSION(:), POINTER :: fvec1p, fvec2p
    ABSTRACT INTERFACE
        FUNCTION functions_system(x) RESULT(y)
        IMPLICIT NONE
        REAL, DIMENSION(:), INTENT(IN) :: x
        REAL, DIMENSION(SIZE(x)) :: y
        END FUNCTION
    END INTERFACE
    ABSTRACT INTERFACE
        FUNCTION middle_function_template(x,fvec_p,proc_p) RESULT(y)
        ! IMPORT                    !<---------------- COMMENT OUT ON PURPOSE
        IMPLICIT NONE
        REAL, DIMENSION(:), POINTER :: fvec_p
        PROCEDURE(functions_system), POINTER :: proc_p       ! <----- the error line caught by IVF
        REAL :: y
        END FUNCTION
    END INTERFACE
    PROCEDURE(functions_system), POINTER :: proc1p, proc2p
CONTAINS
    FUNCTION func_system1(x) RESULT(y)
        IMPLICIT NONE
        REAL, DIMENSION(size(x)) :: y
        y(1)=x(1)
        y(2)=x(2)
    END FUNCTION func_system1
    ! the major program returns the normalization of
    ! a given vector
    SUBROUTINE MajorSolver(ans,x,fvec_p,proc_p)
        IMPLICIT NONE
        REAL, DIMENSION(:), POINTER :: ans
        PROCEDURE(middle_function_template), POINTER :: proc3p
        REAL, DIMENSION(SIZE(x)), TARGET :: y ! kept for other use
        REAL :: z
        fvec_p=>y
        proc3p=>MiddleFunction
        z=AssistantSolver(x,proc3p,fvec_p,proc_p)
        ans=fvec_p**2/z
    END SUBROUTINE MajorSolver
    FUNCTION AssistantSolver(x,func,fvec_p,proc_p)
        IMPLICIT NONE
        procedure(middle_function_template), pointer :: func
        REAL :: AssistantSolver
        AssistantSolver=func(x,fvec_p,proc_p)
    END FUNCTION AssistantSolver
    ! return the innder product of the vector proc_p evaluated at x
    FUNCTION MiddleFunction(x,fvec_p,proc_p)
        IMPLICIT NONE
        REAL :: MiddleFunction
        fvec_p=proc_p(x)
        MiddleFunction=dot_product(fvec_p,fvec_p)
    END FUNCTION
END MODULE toolbox
PROGRAM main
USE toolbox
IMPLICIT NONE
REAL :: data2(2)
data2=[1.,2.]
proc1p=>func_system1
allocate(ans(size(data2)))
call MajorSolver(ans,data2,fvec1p,proc1p)
write(*,'(a,2(f7.3))'),'Equations system 1: Ans= ',ans
nullify(ans,proc1p)
END PROGRAM main
Hi Li,
I’ve asked one of our engineers to look into this. He’s trying to find case and versus as to why this is an error. Intel and NAG flag it, but PGI and Gfortran do not.
Does the code run correctly?
  • Mat
Hi Mat,
Yes, the code runs correctly in PVF. Thanks for the reply.
Li
Hi Li,
Our engineer thinks that this should be flagged as an error so I added a problem report (TPR#19504).
Though, he’s wondering why you think this would be ok under F2008.
His reponse:
I am curious what the user meant by “F2008 conventions” because I did not see anything in the language spec that would indicate F2008 allowing the user to not specify IMPORT in this case.
I did see the following difference in the spec for host association, but I don’t believe it applies in this case:
F2003 Host association (from section 16.4.1.3, first paragraph, Host association page 441 F2003 language spec):
An interface body has access via host association to the named entities from its host that are made accessible by IMPORT statements in the interface body.
F2008 Host association (from 16.5.1.4, first paragraph, Host association page 443 in F2008 language spec):
An interface body interface that is not a separate interface body has access via host association to the named entities from its host that are made accessible by IMPORT statements in the interface body.
I wonder if the user is referring to the “separate interface body” exception. However, I don’t think this applies based on the following definition of “separate interface body”:
(from section 12.4.3.2 Interface block, 4th note on page 280 of F2008 language spec)
A separate interface body is an interface body whose initial statement contains the keyword MODULE….
Based on the above definition, the exception doesn’t apply to the user’s code, so I believe IMPORT is required under both F2003 and F2008 conventions. I’m curious what the user meant by “F2008 conventions” in case I’m just missing something here. Please ask him for a clarification.
  • Mat
Hi Mat,
I mean the second interface body can have access to the first interface body via host association by IMPORT because both of the interface bodies reside in the same module. Please correct me if my understanding is wrong. Thanks.
Li
TPR 19504 ABSTRACT INTERFACE problem has been corrected in the current
13.10 release.
thanks,
dave
