Could you please tell me a complete list of supported DXGI formats for cudaExternalMemoryGetMappedMipmappedArray?
I’d like to implement CUDA D3D11 interoperability. I have done with the old cudaGraphicsD3D11RegisterResource. The document says that a complete list of supported DXGI formats for cudaGraphicsD3D11RegisterResource is
https://docs.nvidia.com/cuda/cuda-runtime-api/group__CUDART__D3D11.html#group__CUDART__D3D11_1g85d07753780643584b8febab0370623b
A complete list of supported DXGI formats is as follows. For compactness the notation A_{B,C,D} represents A_B, A_C, and A_D.
- DXGI_FORMAT_A8_UNORM
- DXGI_FORMAT_B8G8R8A8_UNORM
- DXGI_FORMAT_B8G8R8X8_UNORM
- DXGI_FORMAT_R16_FLOAT
- DXGI_FORMAT_R16G16B16A16_{FLOAT,SINT,SNORM,UINT,UNORM}
- DXGI_FORMAT_R16G16_{FLOAT,SINT,SNORM,UINT,UNORM}
- DXGI_FORMAT_R16_{SINT,SNORM,UINT,UNORM}
- DXGI_FORMAT_R32_FLOAT
- DXGI_FORMAT_R32G32B32A32_{FLOAT,SINT,UINT}
- DXGI_FORMAT_R32G32_{FLOAT,SINT,UINT}
- DXGI_FORMAT_R32_{SINT,UINT}
- DXGI_FORMAT_R8G8B8A8_{SINT,SNORM,UINT,UNORM,UNORM_SRGB}
- DXGI_FORMAT_R8G8_{SINT,SNORM,UINT,UNORM}
- DXGI_FORMAT_R8_{SINT,SNORM,UINT,UNORM}
Now I’d like to use cudaExternalMemoryGetMappedMipmappedArray for faster performance, but I could not find the document about the supported DXGI formats.
The document gives a sample code as follows:
cudaChannelFormatDesc getCudaChannelFormatDescForDxgiFormat(DXGI_FORMAT dxgiFormat)
cudaChannelFormatDesc d;
memset(&d, 0, sizeof(d));
switch (dxgiFormat) {
case DXGI_FORMAT_R8_UINT: d.x = 8; d.y = 0; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindUnsigned; break;
case DXGI_FORMAT_R8_SINT: d.x = 8; d.y = 0; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindSigned; break;
case DXGI_FORMAT_R8G8_UINT: d.x = 8; d.y = 8; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindUnsigned; break;
case DXGI_FORMAT_R8G8_SINT: d.x = 8; d.y = 8; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindSigned; break;
case DXGI_FORMAT_R8G8B8A8_UINT: d.x = 8; d.y = 8; d.z = 8; d.w = 8; d.f = cudaChannelFormatKindUnsigned; break;
case DXGI_FORMAT_R8G8B8A8_SINT: d.x = 8; d.y = 8; d.z = 8; d.w = 8; d.f = cudaChannelFormatKindSigned; break;
case DXGI_FORMAT_R16_UINT: d.x = 16; d.y = 0; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindUnsigned; break;
case DXGI_FORMAT_R16_SINT: d.x = 16; d.y = 0; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindSigned; break;
case DXGI_FORMAT_R16G16_UINT: d.x = 16; d.y = 16; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindUnsigned; break;
case DXGI_FORMAT_R16G16_SINT: d.x = 16; d.y = 16; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindSigned; break;
case DXGI_FORMAT_R16G16B16A16_UINT: d.x = 16; d.y = 16; d.z = 16; d.w = 16; d.f = cudaChannelFormatKindUnsigned; break;
case DXGI_FORMAT_R16G16B16A16_SINT: d.x = 16; d.y = 16; d.z = 16; d.w = 16; d.f = cudaChannelFormatKindSigned; break;
case DXGI_FORMAT_R32_UINT: d.x = 32; d.y = 0; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindUnsigned; break;
case DXGI_FORMAT_R32_SINT: d.x = 32; d.y = 0; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindSigned; break;
case DXGI_FORMAT_R32_FLOAT: d.x = 32; d.y = 0; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindFloat; break;
case DXGI_FORMAT_R32G32_UINT: d.x = 32; d.y = 32; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindUnsigned; break;
case DXGI_FORMAT_R32G32_SINT: d.x = 32; d.y = 32; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindSigned; break;
case DXGI_FORMAT_R32G32_FLOAT: d.x = 32; d.y = 32; d.z = 0; d.w = 0; d.f = cudaChannelFormatKindFloat; break;
case DXGI_FORMAT_R32G32B32A32_UINT: d.x = 32; d.y = 32; d.z = 32; d.w = 32; d.f = cudaChannelFormatKindUnsigned; break;
case DXGI_FORMAT_R32G32B32A32_SINT: d.x = 32; d.y = 32; d.z = 32; d.w = 32; d.f = cudaChannelFormatKindSigned; break;
case DXGI_FORMAT_R32G32B32A32_FLOAT: d.x = 32; d.y = 32; d.z = 32; d.w = 32; d.f = cudaChannelFormatKindFloat; break;
default: assert(0);
return d;
According to the code, cudaExternalMemoryGetMappedMipmappedArray does not support all DXGI formats supported by cudaGraphicsD3D11RegisterResource.
My project uses DXGI_FORMAT_R8_UNORM, and DXGI_FORMAT_R16_UNORM, which is not written in the sample code above.
