(I’m posting this (after discussing the matter on StackOverflow) here after having been sort-of convinced this is probably a CUDA issue rather than a bug in my code.)
Consider the following code:
#include <string>
#include <unordered_map>
int main()
std::string s("hello");
std::unordered_map<std::string, int> map;
map.emplace(s, 123);
return 0;
This builds fine with:
- GCC 4.9.3 , no CUDA
- GCC 5.3.1 , no CUDA
- GCC 4.9.3 via CUDA 7.5 (with file extension .cu)
- GCC 4.9.3 via CUDA 8 RC (with file extension .cu)
but fails to compile with GCC 5.3.1 via CUDA 8 RC.
The error I get is:
/usr/include/c++/5/bits/hashtable.h(1526): error: no instance of overloaded function "std::forward" matches the argument list
argument types are: (std::__cxx11::string)
detected during:
instantiation of "std::pair<std::_Hashtable<_Key, _Value, _Alloc, _ExtractKey, _Equal, _H1, _H2, _Hash, _RehashPolicy, _Traits>::iterator, __nv_bool> std::_Hashtable<_Key, _Value, _Alloc, _ExtractKey, _Equal, _H1, _H2, _Hash, _RehashPolicy, _Traits>::_M_emplace(std::true_type, _Args &&) [with _Key=std::__cxx11::string, _Value=std::pair<const std::__cxx11::string, int>, _Alloc=std::allocator<std::pair<const std::__cxx11::string, int>>, _ExtractKey=std::__detail::_Select1st, _Equal=std::equal_to<std::__cxx11::string>, _H1=std::hash<std::__cxx11::string>, _H2=std::__detail::_Mod_range_hashing, _Hash=std::__detail::_Default_ranged_hash, _RehashPolicy=std::__detail::_Prime_rehash_policy, _Traits=std::__umap_traits<true>, _Args=<std::__cxx11::string &, int>]"
(726): here
instantiation of "std::_Hashtable<_Key, _Value, _Alloc, _ExtractKey, _Equal, _H1, _H2, _Hash, _RehashPolicy, _Traits>::__ireturn_type std::_Hashtable<_Key, _Value, _Alloc, _ExtractKey, _Equal, _H1, _H2, _Hash, _RehashPolicy, _Traits>::emplace(_Args &&...) [with _Key=std::__cxx11::string, _Value=std::pair<const std::__cxx11::string, int>, _Alloc=std::allocator<std::pair<const std::__cxx11::string, int>>, _ExtractKey=std::__detail::_Select1st, _Equal=std::equal_to<std::__cxx11::string>, _H1=std::hash<std::__cxx11::string>, _H2=std::__detail::_Mod_range_hashing, _Hash=std::__detail::_Default_ranged_hash, _RehashPolicy=std::__detail::_Prime_rehash_policy, _Traits=std::__umap_traits<true>, _Args=<std::__cxx11::string &, int>]"
/usr/include/c++/5/bits/unordered_map.h(380): here
instantiation of "std::pair<std::unordered_map<_Key, _Tp, _Hash, _Pred, _Alloc>::iterator, __nv_bool> std::unordered_map<_Key, _Tp, _Hash, _Pred, _Alloc>::emplace(_Args &&...) [with _Key=std::__cxx11::string, _Tp=int, _Hash=std::hash<std::__cxx11::string>, _Pred=std::equal_to<std::__cxx11::string>, _Alloc=std::allocator<std::pair<const std::__cxx11::string, int>>, _Args=<std::__cxx11::string &, int>]"
a.cu(8): here
1 error detected in the compilation of "/tmp/tmpxft_000035f7_00000000-9_a.cpp1.ii".
Why is this happening? Is it indeed a CUDA bug? If so, is this forum the place to report it?
