A custom tile config for for Gst-nvmultistreamtiler
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1
• Issue Type( questions, new requirements, bugs) need example
I am trying to slightly customise nvmultistreamtiler so I can have a nice 1 row 2 col display with each tile with resolution 1280x1080 (what I have works functionally but the two tile resoltion is not right)
I tried tricks like having the tiler with 2xwidth 1xheight but for some reason it doesn’t look good. (my display is about 13 inch 1920x1080)
the information on custom-tile-config parameter where we can set custom resolutio for each tile is a bit too thin.
Gst-nvmultistreamtiler — DeepStream documentation 6.4 documentation. only says
“Custom tile position and resolution. Can be configured programmatically for all or none of the sources.”
Can you please give an example for custom-tile-config
P.S.
similar question asked in 2020 (after nearly half a decade ago :P )
The feature isn’t live yet. Could you try to use the nvcompositor to cover your needs?
Thanks I will look into that and I trust your that nvcompositor will do the trick so I will close the issue.
Cheers,
Ganindu.
